我使用Windows 7 X64位戴尔桌面和我下载ISE 11.1 Webpack它工作正常,我能够正确实现它,但当我模拟它(使用ISIM)我收到错误说
警告:找到了WEBPACK许可证。 警告:请使用Xilinx许可证配置管理器查看完整的ISim许可证。 警告:ISim将以精简模式运行。 有关Lite和完整版之间差异的更多信息,请参阅ISim文档。 这是ISim的Lite版本。 时间分辨率为1 ps 模拟器正在进行电路初始化过程。 完成电路初始化过程。 在0 ps,Instance / counter_tb / U_counter /:警告:在算术操作数中有一个'U'|'X'|'W'|'Z'|' - ',结果将是'X'(es) 。 在30 ns:错误:案例1失败 在40 ns:错误:案例2失败 在50 ns:错误:案例3失败 在60 ns:错误:案例4失败 在90 ns:错误:案例5失败 ISIM> 以上来自于谷歌翻译 以下为原文 Iam using windows 7 X64 bit dell desktop and i downloaded ISE 11.1 Webpack it worked fine and i am able to implent it properly but when i was simulating it (using ISIM) iam getting error saying that WARNING: A WEBPACK license was found. WARNING: Please use Xilinx License Configuration Manager to check out a full ISim license. WARNING: ISim will run in Lite mode. Please refer to the ISim documentation for more information on the differences between the Lite and the Full version. This is a Lite version of ISim. Time resolution is 1 ps Simulator is doing circuit initialization process. Finished circuit initialization process. at 0 ps, Instance /counter_tb/U_counter/ : Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es). at 30 ns: Error: Failed case 1 at 40 ns: Error: Failed case 2 at 50 ns: Error: Failed case 3 at 60 ns: Error: Failed case 4 at 90 ns: Error: Failed case 5 ISim> |
4个回答
在这种情况下,听起来你的代码存在问题。
您可能应该在Simulation and Verification板上询问这个问题:http://forums.xilinx.com/xlnx/board?board.id = SIMANDVERIBD 它可能有助于查看您正在模拟的代码。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 In that case it sounds like there's an issue with your code. You should probably ask about this on the Simulation and Verification board : http://forums.xilinx.com/xlnx/board?board.id=SIMANDVERIBD It would likely help to see what code you're simulating as well. View solution in original post |
您是否可以使用ISIM(文件 - >打开示例)成功模拟示例设计?
以上来自于谷歌翻译 以下为原文 Can you successfully simulate an example design with ISIM (File -> Open Example)? |
在这种情况下,听起来你的代码存在问题。
您可能应该在Simulation and Verification板上询问这个问题:http://forums.xilinx.com/xlnx/board?board.id = SIMANDVERIBD 它可能有助于查看您正在模拟的代码。 以上来自于谷歌翻译 以下为原文 In that case it sounds like there's an issue with your code. You should probably ask about this on the Simulation and Verification board : http://forums.xilinx.com/xlnx/board?board.id=SIMANDVERIBD It would likely help to see what code you're simulating as well. |
只有小组成员才能发言,加入小组>>
2300 浏览 7 评论
2707 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2192 浏览 9 评论
3274 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2340 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
615浏览 1评论
1673浏览 1评论
172浏览 1评论
637浏览 0评论
1827浏览 0评论
GMT+8, 2024-9-14 09:50 , Processed in 1.077020 second(s), Total 54, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
