电子发烧友论坛|
我安装了Xilink ISE 11.1,卸载并重新安装。
每次程序打开,但当我尝试打开一个新项目时,我收到以下消息: Fatal_error:GuiUtilities:GuiClip_ApplicationBase.c:316:1.20 - 此应用程序执行了一个illigal操作,必须关闭。 流程将终止。 有关此问题的技术支持,请打开一个WebCase,该项目附在http:www.xilinx.com/support上。 随后是关闭程序的消息。 这是一台Windows XP平板电脑。 在安装过程中没有错误消息,应用程序似乎正确安装。 我也能够毫无问题地安装xilinx.lic文件。 任何帮助将不胜感激。 谢谢。 以上来自于谷歌翻译 以下为原文 I have installed Xilink ISE 11.1, uninstalled and reinstalled. Each time the program will open, but when I try to open a new project I receive the following message: Fatal_error:GuiUtilities:GuiClip_ApplicationBase.c:316:1.20 - This application has performed an illigal operation and must be shut down. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http:www.xilinx.com/support. Followed by a message closing the program. This is a Windows XP Tablet PC. During the install there were no error messages and the application appeared to install properly. I was also able to install the xilinx.lic file with no problems. Any help would be greatly appreciated. Thank you. |
4个回答
如果你使用win vista& win 7 pls open program as admin如果你不这样做,你会看到错误。
以上来自于谷歌翻译 以下为原文 if you use win vista &win 7 pls open program as admin if you don't you will seen error. |
我使用ISE 11.1开发了同样的问题。
除了创建一个新项目(包括cloding和打开已经创建的项目),我可以做任何事情。 我在安装ISE webpack之后没有立即得到这个错误,而是我已经创建了大约4个项目,而现在又遇到了这个问题! oolesen80,你有没有找到修复? 以上来自于谷歌翻译 以下为原文 I've developed this very same problem using ISE 11.1. I can do everything but create a new project (including cloding and opening already created projects). I didn't get this error right away after installing ISE webpack, rather I've created about 4 projects and hav now just run into this issue! oolesen80, did you ever find a fix? |
请参阅:http://www.xilinx.com/support/answers/32800.htm
以上来自于谷歌翻译 以下为原文 See: http://www.xilinx.com/support/answers/32800.htm |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 16:01 , Processed in 0.931208 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2236
