嗨我正在使用PNA-X N5247A和6英寸同轴电缆作为DUT进行时域变换,以获得带通脉冲响应。
正如预期的那样,我观察到第一次脉冲的幅度和延迟(标记1,请参见附件)是有意义的,基于我用作DUT的6英寸同轴电缆。 但是我看到了一些凸起(标记2,3,4,5),考虑到电缆的长度短,我无法解释。 我发现,当我将Kaiser窗口β值从6改为8时,这些凸起变得更加明显(请参见附件)。 什么可能是这些颠簸的来源? 我的应用需要高动态范围,因此我的问题。 谢谢! 以上来自于谷歌翻译 以下为原文 Hi I am performing a time-domain transform using PNA-X N5247A with a 6-inch coax cable as DUT to obtain the band-pass impulse response. As expected I observe that the magnitude and delay of the first impulse (Marker 1, please see attached document) makes sense, based on the 6-inch coax I used as DUT. However I see certain bumps (Markers 2,3, 4, 5) which I am unable to explain considering the short length of the cable. Rather than a uniform roll-off, I see that these bumps become more pronounced when I change the Kaiser window beta value from 6 to 8 (please see attached document). What could be the source of these bumps? My application requires high dynamic range hence my question. Thanks! 附件
1个回答
这些是从电缆的连接中重新反射在主瓣处通过的信号从输出连接器反射回来,从输入连接器重新反射并在第一次反射时出现3倍。
KB6情况下的常见波纹和KB8情况当然是滤波器通常预期的旁瓣。 编辑:对不起,我想念了x轴。 这些额外的涟漪可能来自测试端口电缆,如果它们大约每个1米。编辑:Dr_joel于2014年11月19日下午12:05 以上来自于谷歌翻译 以下为原文 Those are re-reflection from the cable's connections The signal that passes through at the main lobe reflects off the output connector, re-reflects off the input connector and comes out a 3x the time of the first reflection. The common ripples in the KB6 case and KB8 case are of course the normally expected side lobes of the filter. edit: Sorry, I missread the x-axis. Those extra ripples might be rather from the test port cables, if they are about 1 meter each. Edited by: Dr_joel on Nov 19, 2014 12:05 PM |
只有小组成员才能发言,加入小组>>
2110 浏览 1 评论
1873 浏览 1 评论
1727 浏览 5 评论
2599 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1571 浏览 4 评论
519浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
374浏览 0评论
1433浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
285浏览 0评论
2267浏览 0评论
GMT+8, 2024-5-13 22:14 , Processed in 1.273724 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
