电子发烧友论坛|
嗨......我正在使用PNA-X N5242A来产生脉冲射频信号。
我想从PNA的端口3生成脉冲RF信号。 我正在尝试从“脉冲设置”窗口配置脉冲。 我在下面列出我的配置以从端口3生成脉冲*内部脉冲发生器*“启用”脉冲0“启用”脉冲1 *内部脉冲调制器*“启用”启用源1调制器*调制器驱动器*脉冲1 *脉冲测量*标准 脉冲*跟踪S43 * *频率。 范围:3.1GHz至3.5 GHz *但是当我试图在CRO上看到生成的脉冲时。 我没有得到稳定的脉搏。 脉冲从左向右扫过。 是否有任何其他设置需要从PNA的端口3生成脉冲RF信号。 如果我错了,请纠正。 以上来自于谷歌翻译 以下为原文 Hi...I am using PNA-X N5242A to generate pulsed RF signal. I want to generate the pulsed RF signal from port 3 of PNA. I am trying to configure the pulse from "Pulse Setup" window. I am listing my configuration below to generate pulse from port 3 *INTERNAL PULSE GENERATOR* "Enable" Pulse 0 "Enable" Pulse 1 *INTERNAL PULSE MODULATORS* "Enable" Enable source 1 modulators *MODULATOR DRIVE* Pulse 1 *PULSE MEASUREMENT* Standard pulse *Trace S43* *Freq. Range: 3.1GHz to 3.5 GHz* But when I am trying to see the generated pulse on CRO. I am not getting a stable pulse. Pulse is sweeping from left to right. Is there any other setting which is require to generate Pulsed RF signal from Port 3 of PNA. Please correct if I am wrong. |
4个回答
如果查看“路径配置”对话框,您将看到端口3源自源2输出1.因此,您需要将调制器设置为源2.此外,对于初始设置,将扫描类型设置为CW频率。
创建迹线S43,R3,3,D,3(如果你有端口3和端口4连接在一起。或者只是做“脉冲轮廓”(它设置相同的东西。扫频的麻烦是你很难 获得一致的触发因为取决于扫描,源可能会在回扫时关闭,这会让您感到困惑。 以上来自于谷歌翻译 以下为原文 If you look at the Path Configuration dialog you will see that port 3 is derived from source 2 Output 1. So you need to set the modulator to source 2. Also, for initial setup set the sweep type to CW frequency. Create traces S43, R3,3, D,3 (if you have port 3 and port 4 connected together. Or just do "pulse profile" (which sets about the same thing. The trouble with sweeping frequency is that you have a hard time getting consistent triggering because depending on the sweep, the source might turn off at retrace and it will confuse you. |
您还必须在源2上启用调制器。这有点令人困惑:我们有2个合成器和4个端口。
每个合成器称为“源”,因此源1进入端口1和2,端口1上的脉冲调制器源2通过源3上的脉冲调制器进入端口3和4.在脉冲配置中,必须启用源2调制 在端口3上进行调制。 以上来自于谷歌翻译 以下为原文 You also have to enable the modulator on Source 2. It's a little confusing: we have 2 synthesizers and 4 ports. Each synthesiser is called a "source" so source 1 goes to ports 1 and 2, with pulse modulators on port 1 Source 2 goes to ports 3 and 4 with pulse modulator on source 3. In the pulse configuration, you must enable source 2 modulation to have modulation on port 3. |
脑洞大赛9 发表于 2019-1-28 08:43 感谢Joel博士,今天我读了* PNA帮助支持*仅支持81110A安捷伦脉冲发生器*(来自以下链接):http://na.tm.agilent.com/pna/help/latest/System/Configure_an_External_Pulse_Generator .htm#HowCreate我是否可以使用除81110A之外的任何其他脉冲发生器和PNA? 在脉冲发生器设置中配置脉冲发生器的帮助中也写了它。 那么有必要在PNA中配置脉冲发生器吗? 如果是,那么请告诉我在脉冲发生器设置中配置它的程序。 以上来自于谷歌翻译 以下为原文 Thanks Dr. Joel, Today I read *Only the 81110A Agilent Pulse Generator is supported* from the PNA help (from the below link): http://na.tm.agilent.com/pna/help/latest/System/Configure_an_External_Pulse_Generator.htm#HowCreate Whether can I use any other Pulse generator with PNA except 81110A? It was also written in the help to configure the pulse generator in pulse generator setup. So is it necessary to configure the pulse generator in PNA? if yes then please tell me procedure to configure it in pulse generator setup. |
asd004 发表于 2019-1-28 09:01 通常,没有必要在PNA-X上使用外部脉冲发生器。 内部脉冲发生器应该是您需要的全部。 如果你有选项008,它很容易设置; 只需设置脉冲周期和脉冲宽度,进入高级脉冲发生器,然后选择启用调制器2(您可以禁用调制器1)。 也许您可以更具体地了解以下内容:1)被测设备(DUT)是什么? 你可以发布连接图吗? 2)为什么使用端口3(使用端口3没问题,但通常使用端口1)。 3)您是否有安捷伦现场或销售工程师。 他可以让您联系当地的应用工程师,他们可以快速解决您的问题。 它可能比通过电子邮件做事更容易。 或者您是否直接尝试过Agilent Contact senter? 我想这是联系电话+1 800 829-4444一般来说,只需转到Chan:硬件设置:Pulse Gen Config; 启用源2(对于端口3),将调制器驱动设置为脉冲1,转到脉冲1线并设置PRF和脉冲宽度并启用它。 以上来自于谷歌翻译 以下为原文 In general, it is not necessary to use an external pulse generator with the PNA-X. The internal pulse generator should be all that you need. If you have option 008 it is very easy to setup; just set the pulse period and pulse width, the go to advanced, pulse generators, and select enable modulator 2 (and you may disable modulator 1). Perhaps you can be more specific about the following: 1) what is the Device Under Test (DUT)? Can you post a connection diagram? 2) why are you using port 3 (no problem to use port 3 but usually port 1 is used). 3) Do you have an Agilent Field or Sales Engineer. He can put you in touch with a local appication engineer who could quickly sort you out. It might be easier than trying to do things through email. Or have you tried the Agilent Contact senter directly? I think this is the contact number +1 800 829-4444 In general, just go to Chan:Hardware Setup: Pulse Gen Config; Enable source 2 (for port 3), set modulator drive to pulse 1, go to the pulse 1 line and set PRF and pulse width and enable it. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 04:22 , Processed in 0.696587 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1946
