你好,
在创建比特流并正确设计实现后,Vivado 2017.4仍未检测到我的设备。 请建议我应该尝试找到问题的选项。 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, After creating bit stream, and correct design implementation, my device is still not detected by Vivado 2017.4. Please suggest the options that I should try to find the problem. Thanks. |
7个回答
嗨@ soumya.91singh,
您正在显示的指南告诉您如何从SD卡启动linux(应该提供),从zedboard获取输出。 不是如何从vivado编程zedboard。 您可能需要查看Zedboard UG以获取有关如何使用zedboard的更多详细信息。 但是要在vivado中编程PL部分,您只需要JTAG(而不是UART)。 如果您只需要编写PS部件,则相同。 UART电缆用于从/向PS内部的UART控制器输入/输出 FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @soumya.91singh, The guide you are showing tells you how to get the output from the zedboard if you are booting linux from the SD card (which should be provided). Not how to program the zedboard from vivado. You might want to check the Zedboard UG for more detail on how to use the zedboard. But to program the PL part in vivado, you only need the JTAG (not the UART). Same if you just need to program the PS part. The UART cable is used to get input/output from/to the UART controller which is inside the PS Florent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. View solution in original post |
@ soumya.91singh尝试重新安装digilent驱动程序并重新启动
https://www.xilinx.com/support/answers/59128.html vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用论坛。 以上来自于谷歌翻译 以下为原文 @soumya.91singh Try reinstalling the digilent drivers and reboot https://www.xilinx.com/support/answers/59128.html vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead. |
尝试使用不同的电缆,直到Windows找到您未指定的单元。
安装有线驱动程序,在Linux上找到它们 /opt/Xilinx/Vivado/2017.4/data/xicom/cable_drivers/lin64/install_script/install_drivers至少与Digilent合作。 以上来自于谷歌翻译 以下为原文 Try different cables until Windows finds the unit, the one you did not specify. Install the cable drivers, on linux they are found at /opt/Xilinx/Vivado/2017.4/data/xicom/cable_drivers/lin64/install_script/install_driversand works with Digilent at least. |
我正在使用Win10,我尝试过使用CP210x_Universal_Windows_Driver和CodeDriverInstaller_1。
我的决定是Xilinx®XC7Z020-1CLG484CZynq-7000 AP SoC。 我只连接到指南中提到的UART USB端口。 我也需要JTAG连接器吗? 以上来自于谷歌翻译 以下为原文 I am working with Win10 and I have tried with both CP210x_Universal_Windows_Driver and CypressDriverInstaller_1. My decive is Xilinx® XC7Z020-1CLG484C Zynq-7000 AP SoC. I have only connected to UART USB port as mentioned in the guide. Do I need JTAG connector as well? |
嗨@ soumya.91singh,
是的,您需要使用JTAG电缆将电路板与硬件管理器一起使用。 您在哪个手册上看到UART足够了? 问候, FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 以上来自于谷歌翻译 以下为原文 Hi @soumya.91singh, Yes you need the JTAG cable to use the board with the Hardware Manager. On which manual did you see that UART was enough? Regards, Florent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. |
第11页的硬件设置或以下指南。
http://zedboard.org/sites/default/files/documentations/GS-AES-Z7EV-7Z020-G-14.1-V6%5B1%5D.pdf 那么,Vivado仅通过JTAG连接在Zynq-7000系列上工作? 还需要什么(SSh,串行等)? 谢谢。 以上来自于谷歌翻译 以下为原文 The hardware setup on page 11 or following guide. http://zedboard.org/sites/default/files/documentations/GS-AES-Z7EV-7Z020-G-14.1-V6%5B1%5D.pdf So, Vivado works on Zynq-7000 series only through JTAG connection? What else is required (SSh, serial, etc) ? Thanks. |
嗨@ soumya.91singh,
您正在显示的指南告诉您如何从SD卡启动linux(应该提供),从zedboard获取输出。 不是如何从vivado编程zedboard。 您可能需要查看Zedboard UG以获取有关如何使用zedboard的更多详细信息。 但是要在vivado中编程PL部分,您只需要JTAG(而不是UART)。 如果您只需要编写PS部件,则相同。 UART电缆用于从/向PS内部的UART控制器输入/输出 FlorentProduct应用工程师 - Xilinx技术支持EMEA ------------------------------------------ -------------------------------------------------- ----------------------------不要忘记回复,kudo,并接受作为解决方案。 以上来自于谷歌翻译 以下为原文 Hi @soumya.91singh, The guide you are showing tells you how to get the output from the zedboard if you are booting linux from the SD card (which should be provided). Not how to program the zedboard from vivado. You might want to check the Zedboard UG for more detail on how to use the zedboard. But to program the PL part in vivado, you only need the JTAG (not the UART). Same if you just need to program the PS part. The UART cable is used to get input/output from/to the UART controller which is inside the PS Florent Product Application Engineer - Xilinx Technical Support EMEA ------------------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. |
只有小组成员才能发言,加入小组>>
2387 浏览 7 评论
2802 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2269 浏览 9 评论
3337 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2437 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
764浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
548浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
378浏览 1评论
1971浏览 0评论
688浏览 0评论
GMT+8, 2024-11-27 01:12 , Processed in 1.311611 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
