亲爱的大家,
我在询问是否可以使用LPS25HB绝对压力传感器作为力传感器。我的想法是将传感器集成到橡胶或硅层(5-10毫米厚)中,使橡胶层充当传感器,压缩传感器的腔室。这会影响传感器的功能吗?你有什么建议吗?提前谢谢你的好意! 最好的祝福, 达里奥 #lps25hb压力 以上来自于谷歌翻译 以下为原文 Dear all, I am inquiring the possibility to use LPS25HB absolute pressure sensors as force sensors. My idea is to integrate the sensors into a rubber or silicon layer (5 - 10 mm thick) so that the rubber layer, acting as transducer, compresses the sensor's chamber. Would this compromise the sensors' functioning? Do you have any suggestions? Thank you in advance for you kindness! Best regards, Dario #lps25hb-pressure-force |
3个回答
你好,
如果你想测量体重,我会考虑使用称重传感器: https://learn.sparkfun.com/tutorials/getting-started-with-load-cells LPS25HB是一种气压传感器,内部有一层精致的膜,因此我不建议将其放入任何其他材料中。但是,您可以尝试将传感器嵌入某种气垫或盒子中,并在对盒子施加压力后测量气压变化。然而,这不仅对施加的力敏感,而且对温度变化敏感。除此之外,您需要小心不要破坏传感器的膜,它很容易超出压力边界。 (如果您将传感器放在密封良好的便当盒中并在盒子上施加压力或改变环境温度,您可以试试这个。) 大卫 以上来自于谷歌翻译 以下为原文 Hello, If you are trying to measure weight, I would consider using a load cell: https://learn.sparkfun.com/tutorials/getting-started-with-load-cells LPS25HB is constructed as an air pressure sensor and has a delicate membrane inside, so I wouldn't recommend putting it into any other material. However, you can try to embed the sensor into some kind of an air pillow or box and measure the air pressure change after applying pressure to the box. However, this is sensitive not only to applied force, but also to temperature changes. In addition to that, you need to be careful to not break the sensor's membrane, it is very easy to get outside the pressure boundaries. (You can try this if you put the sensor in a well sealed lunch box and applying pressure on the box, or changing the temperature of the environment.) David |
我只记得一个较旧的问题,我提供了一个估计,以了解通过踩在带有压力传感器的密封盒内可以产生多少压力:
https://community.st.com/0D50X00009XkY8gSAF 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 I just remembered an older question where I provided an estimate to get the idea of how much pressure can be generated by stepping on a sealed box with a pressure sensor inside: https://community.st.com/0D50X00009XkY8gSAF Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
, 亲爱的大卫, 谢谢您的回复。我想知道,如果将整个传感器密封到聚合物中,它自己的感应室是否可以作为你提到的密封盒。 Il 05 feb 2018 10:10 AM,David Koudela&lt;,st-microelectronics @ jiveon.com&gt ;, ha scritto: STMicroelectronics Community&lt ;,https://community.st.com/?et = watches.email.thread&gt;, Re:LPS25HB用于力读数 MEMS和传感器论坛中David Koudela&lt;,https://community.st.com/people/Koudela.David.001?et = watches.email.thread&gt;的回复 - 查看完整的讨论&lt;,https://社区.st.com / message / 184134-re-lps25hb-for-force-readingings?commentID = 184134&amp;,et =watches.email.thread♯comment-184134&gt;, 以上来自于谷歌翻译 以下为原文 , , Dear David, Thank you for your reply. I was wondering if, sealing the whole sensor into the polymer, its own sensing chamber could act as the sealed box you mentioned. Il 05 feb 2018 10:10 AM, David Koudela <,st-microelectronics@jiveon.com>, ha scritto: STMicroelectronics Community <,https://community.st.com/?et=watches.email.thread>, Re: LPS25HB for force readings reply from David Koudela<,https://community.st.com/people/Koudela.David.001?et=watches.email.thread>, in MEMS and Sensors Forum - View the full discussion<,https://community.st.com/message/184134-re-lps25hb-for-force-readings?commentID=184134&,et=watches.email.thread ♯ comment-184134>, |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2725 浏览 1 评论
3237 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1807 浏览 1 评论
3646 浏览 6 评论
6034 浏览 21 评论
1336浏览 4评论
197浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
442浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
273浏览 2评论
GMT+8, 2024-12-22 15:59 , Processed in 1.125069 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
