电子发烧友论坛|
嗨!
HTS221传感器和LPS25HB压力传感器在开发板中。两个传感器的输出之间的温差太高。 HTS221温度值接近实际温度,LPS25HB输出比室温环境低5~10'C。 两个器件的输出温度是2的补码形式。 我不确定这种差异的原因是什么。 请就此事提出建议。 最好的祝福。 权 #lps25hb 以上来自于谷歌翻译 以下为原文 Hi! The HTS221 sensor and LPS25HB pressure sensor are together in the development board. The temperature difference between the output of the two sensors too high. HTS221 temperature value is close to the actual temperature, LPS25HB outputs 5~10'C lower than that at room temperature environment. The output temperature of the two devices is a 2's complement form of the same. I'm not sure about the cause of this difference is. Please give advice on this matter. Best regards. Kwon #lps25hb |
3个回答
你好,
我还想知道,为什么LPS25HB测量的环境温度(15-25厘米)比其他温度传感器低4厘升(例如) HTS221和 校准Sensirion的SHT21 a SHT31)。中提到的公式 http://www.st.com/content/ccc/resource/technical/document/technical_note/23/dd/08/f8/ac/cf/47/83/DM00242307.pdf/files/DM00242307.pdf/jcr:内容/翻译/ en.DM00242307.pdf 使用42.5厘米的偏移量。它是固定值,还是可以在设备中设置的值?我使用 http://www.st.com/en/ecosystems/x-nucleo-iks01a1.html 我希望可以排除不良的PCB设计和/或焊接。感谢您的任何建议。 大卫 以上来自于谷歌翻译 以下为原文 Hello, I would also like to know, why does LPS25HB measure ca 4 centigrades lower ambient temperature (15-25 centigrades) than other temperature sensors (for example HTS221 and calibrated Sensirion's SHT21 a SHT31).The formula mentioned in http://www.st.com/content/ccc/resource/technical/document/technical_note/23/dd/08/f8/ac/cf/47/83/DM00242307.pdf/files/DM00242307.pdf/jcr:content/translations/en.DM00242307.pdf uses an offset of 42.5 centigrades. Is it a fixed value, or value that can be set in the device?I use http://www.st.com/en/ecosystems/x-nucleo-iks01a1.html board, so I hope bad PCB design and/or soldering can be ruled out.Thank you for any advice. David |
LPS25HB主要用于压力测量,因此温度测量的准确度比HTS221或其他用于温度测量的校准传感器更差。数据表显示LPS25HB的温度精度为+ -2°C,但它是典型值,因此可能存在精度较差的部件,这可能是您的情况。
以上来自于谷歌翻译 以下为原文 The LPS25HB is primarily intended for pressure measurement, so the accuracy of temperature measurement is worse that HTS221 or other calibrated sensors which are intended for temperature measurement. The datasheet says that the temperature accuracy of LPS25HB is +-2°C but is it typical value so there could be parts with worse accuracy, which could be your case. |
谢谢你的回答。鉴于传感器特性应该是线性的,我将在固件中使用不同的偏移量,并希望获得更准确的结果。
以上来自于谷歌翻译 以下为原文 Thank You for the answer. Given the fact that the sensor characteristics should be linear, I will use a different offset in firmware and hope for more accurate results. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1469 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
748浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
727浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
968浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
771浏览 5评论
/9
GMT+8, 2025-12-12 01:25 , Processed in 0.767295 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3357
