电子发烧友论坛|
大家好,
我是Vivado的新手。 我想提取已实现设计的LUT名称,但我没有找到合适的tcl命令。 以上来自于谷歌翻译 以下为原文 Hi every body, I am new with Vivado. I want to extract LUT names of the implemented design but I did not find an appropriate tcl command. |
5个回答
你好@ farzian
要提取已实现设计的LUT名称,请打开已实现的设计并在tcl控制台中运行以下命令: show_objects -name find_1 [get_cells -hierarchical -filter {PRIMITIVE_TYPE = ~LUT。*。*}] 您将获得所有LUT的列表及其名称。 问候 罗希特 RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @farzian To extract LUT names of the implemented design, Open the implemented design and run the below command in the tcl console: show_objects -name find_1 [get_cells -hierarchical -filter { PRIMITIVE_TYPE =~ LUT.*.* } ] You will get the list of all the LUTs along with their names. Regards Rohit Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- View solution in original post |
你好@ farzian
要提取已实现设计的LUT名称,请打开已实现的设计并在tcl控制台中运行以下命令: show_objects -name find_1 [get_cells -hierarchical -filter {PRIMITIVE_TYPE = ~LUT。*。*}] 您将获得所有LUT的列表及其名称。 问候 罗希特 RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @farzian To extract LUT names of the implemented design, Open the implemented design and run the below command in the tcl console: show_objects -name find_1 [get_cells -hierarchical -filter { PRIMITIVE_TYPE =~ LUT.*.* } ] You will get the list of all the LUTs along with their names. Regards Rohit Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨@ farzian,
您可以打开已实现的设计 - >查找(ctrl + f) - >选择PREMITIVE TYPE作为LUT,只有您可以找到相应的tcl命令。如果您点击确定,您将获得带有其单元格的LUT名称列表 单元引脚数。作为参考,我附上了快照。 谢谢和RegardsAsit ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @farzian, You can Open Implemented design --> find (ctrl +f) --> select PREMITIVE TYPE as LUT and there only you can find the corresponding tcl command. If yoo click on OK you will get the list of LUT names with their cells and cell pin count. For your reference I have attached the snapshot. Thanks and Regards Asit -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我不明白如何解释表达式:= ~LUT。*。*有人可以解释一下这个意思吗?谢谢
以上来自于谷歌翻译 以下为原文 I didn't understand how to interpret the expression : =~ LUT.*.* can someone explain the meaning? thanks |
你好@ pumaju1808
请为此查询打开一个新主题。 问候 罗希特 RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @pumaju1808 Please open a new thread for this query. Regards Rohit Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3150 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4109 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1366浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1205浏览 1评论
/9
GMT+8, 2025-12-18 04:52 , Processed in 0.661667 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1950
