电子发烧友论坛|
大家好,
在LAN上唤醒工作从ACPI S1状态起作用,但在S3和S5中不起作用。 在Windows 7和debian拉伸下使用bios 080和132进行测试。 最近在两个操作系统上安装了LAN驱动 LAN LED在s3和s5上打开,但在路由器上,特定LAN端口的LED指示灯亮 任何提示都非常受欢迎,我花了数周时间试图解决这个问题。 谢谢 以上来自于谷歌翻译 以下为原文 Hi all, wake on lan works from ACPI S1 state but does not work from S3 nor S5. Tested with bios 080 and 132 on windows 7 and debian stretch. Recent LAN drivers installed on both os. LAN LEDs are turned of on s3 and s5 but on router the LED light for particular LAN port is on any hint is more than welcome, I have spent weeks trying to solve this issue. Thanks |
3个回答
本讨论中有一些链接可能会有所帮助:Re:在D525MW上为WoL禁用S5深度睡眠。
内容S 以上来自于谷歌翻译 以下为原文 There are some links in this discussion that may be helpful: Re: Disable S5 deep sleep for WoL on D525MW. ...S |
嗨斯科特, 谢谢你指着我的链接。 不幸的是,我没有看到讨论和相关的链接,它没有帮助。 “在D525MW上为WoL禁用S5深度睡眠”指出在D525mw上唤醒lan不起作用。 与Giacommo不同,我确认bios更新和降级无济于事。 我还认为魔术包正确地传播到网络,因为计算机可以从S1状态唤醒。 讨论中的链接指的是另一家拥有相同芯片组的制造商--GigaByte。 显然,使用英特尔NM10芯片组的技嘉主板能够将计算机从睡眠状态唤醒,但还有其他一些问题。 从我的结果来看,它看起来d525mw bios中存在一个错误 - 它忽略魔术包并且从S5唤醒根本不起作用。 如果copmputer在S1中,我猜想绕过了BIOS。 网卡和操作系统配合良好,因此计算机可以从S1唤醒。 最好... 以上来自于谷歌翻译 以下为原文 Hi Scott, thanks for pointing me to that link. Unfortunatelly i have seent the discussion and associated links and it did not help. "Disable S5 deep sleep for WoL on D525MW"points out that wake on lan on D525mw does not work. Unlike Giacommo, i confirmed that bios update and downgrade does not help. i also veriefied that magic packet is properly propagated to the network since computer can wake from S1 state. Links in the discussion refers to another manufacturer with the same chipset on board - GigaByte. Apparently, gigabyte motherboard with intel NM10 chipset is able to wake computer from sleep state but has some other issues. From my end it looks that there is a bug in the d525mw bios - it ignores magic packet and wake from S5 simply does not work. If the copmputer is in S1, i guess that BIOS is bypassed. Network card and OS cooperates well so computer can wake from S1. Best... |
你那时运气不好。 由于这个系统很长(很久!)超过其生命周期结束和交互结束支持日期,并且自从英特尔几年前退出桌面主板业务以来,您绝对没有机会看到修复 对于这个问题。 对不起,但这是现实, 内容S 以上来自于谷歌翻译 以下为原文 You are out of luck then. Since this system is long (long!) past its end-of-life and end-of-interactive-support dates and since Intel exited the Desktop Boards business a number of years ago, there is absolutely no chance that you will see a fix for this issue. Sorry, but this is reality, ...S |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-15 14:02 , Processed in 2.657797 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5710
