大家好,我买了二手nuc6i5syk它工作正常。
注意到即使它关闭也总是温暖的。 在检查了它的BIOS之后我找到了原因。 这是便携式设备的u***充电状态,当我将其关闭时它在关闭时保持凉爽但是当它“在s3 / s4 / s5中充电”时,即使它关闭,我的nuc也会保持温暖。 它已经更新为最新的驱动程序和BIOS固件。 我想知道的是,这是一个需要通过英特尔纠正的问题。 任何帮助都非常感谢。 以上来自于谷歌翻译 以下为原文 hello everyone, I bought a second hand nuc6i5syk it works fine. noticed that it is always wARM even it is off. After checking its bios I found the reason. It is u*** charging status for portable devices, when I turn it "off" it stays cool when it is off but when it is "charging in s3/s4/s5" my nuc keeps being warm even it is off. It is already updated to the latest drivers and bios firmware. What I want to know is if this is an issue to be corrected by intel or not. Any help is muchly appreciated. |
4个回答
你好levocil,
您是否已将某些设备连接到前面的橙色USB端口? 我有NUC6i5SYH,虽然充电功能已启用,但在关闭时不是蠕虫。 因此,如果您尚未将任何设备连接到此端口,则此端口可能存在短路。 我建议您检查一下这个端口是否正常工作。 如果不起作用,最好在BIOS中禁用它。 莱昂 以上来自于谷歌翻译 以下为原文 Hello levocil , Do you have connected some device to the orange USB port at front? I've have NUC6i5SYH, and is is not worm while is OFF, although the charging function is enabled. So, if you have not connected any device to this port, probably is some short circuit in this port. I suggest that you should check if this port is working at all. If is not working, better disable it in bios. Leon |
要明确一点 - 你买了这个NUC的二手牌。 只有原始购买者才有权享受保修。 最重要的是,无论如何,英特尔都没有“纠正问题”。 有关详细信息,请参阅此处的国际保修:英特尔NUC 3年国际保修和澳大利亚保修:英特尔NUC 3年澳大利亚保修。 关于你的问题,如果你不喜欢它,你可以在S3 / S4 / S5中禁用USB充电并避免这种情况。 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 Just to be clear - You bought this NUC second-hand. Only the original purchaser is entitled to warranty coverage. Bottom line, regardless of anything else, there is no "issue for Intel to correct". For more information, you can consult the International warranty here: Intel NUC 3-Year International Warranty and the Australian warranty here: Intel NUC 3-Year Australian Warranty. Regarding your issue, if you do not like it warm, you can disable USB charging in S3/S4/S5 and avoid the situation. Hope this helps, ...S |
您好莱昂,非常感谢您的回复,所有USB端口都正常运行,我只是在BIOS中关闭它。 正如你所说,很可能是一个短路造成的。 无论如何,我可以忍受。 祝你有美好的一天。 以上来自于谷歌翻译 以下为原文 Hello Leon, thank you very much for your kind reply, all u*** ports are operating normally, I just turned it off in bios. great probably a short circuit causing this as you said. Anyway I can live with that . Have a good day. |
我不打算要求你关闭所有的USB端口。 如果您想将USB用作USB主机端口(即主机端口启动总线上的所有通信并提供5VDC),则应将此端口开关保持为ON。 否则,例如,如果您将设备连接到此端口,例如外部驱动器,鼠标或键盘,它将无法运行。 我的目的是检查有问题的端口(橙色)是否没有短路。 无论如何,将其他3个USB端口保持打开状态,以便能够将它们用作主机端口。 莱昂 以上来自于谷歌翻译 以下为原文 I did not intend to ask you to turn OFF all your USB ports. In case that you want to use your USB as a USB host port (i.e. The host port initiates all communication on the bus and supplies 5VDC), you should leave this port switch ON. Otherwise, if for example you will connect device to this port, such as external drive, mouse or keyboard, it will not function. My intention was to check if the problematic port (with orange color) has not a short circuit. Any way, leave the other 3 USB port ON in order to be able using them as a host ports. Leon |
只有小组成员才能发言,加入小组>>
412浏览 0评论
GMT+8, 2024-10-20 18:49 , Processed in 0.740687 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
