电子发烧友论坛|
你好,
我正在使用D435相机避免无人机上的障碍物。 无人机安装了3个摄像头。 我使用的是在没有pointcloud的情况下启动RS,但是启动一个单独的depth_imag_proc节点以从摄像机获取xyz pointcloud。 我附加了启动文件,以便您查看使用的参数。 另外,我为所有相机设置了视觉预设为HIGH_ACCURACY。 现在的问题是,对象/点出现在没有的点云中。 这些斑点看起来不像我的平均噪音,因为它们实际上是小点群,而不仅仅是随机噪音。 他们有一个共同点,那就是它们是一种时间现象。 它们只存在于一个点云中并且在下一个点中消失。 我附上了试飞的视频。 您可以忽略所有彩色标记,对于这种情况,重要的是pointcloud的可视化。 我们在一棵高约4米的树上飞来飞去。 没有其他障碍存在,并且无人机右侧的所有较小的点群都对应于所提到的现象。 你知道它来自哪里吗? 你认为我需要改变任何参数吗? 任何帮助都非常感谢 出2018-09-19_14.28.45.mp4 4.6 MB rs_depthcloud.launch.zip 1.8 K. 以上来自于谷歌翻译 以下为原文 Hello, I'm using the D435 camera for obstacle avoidance on a drone. The drone has 3 cameras mounted. An I use launch the RS without pointcloud but launch a separate depth_imag_proc node to get an xyz pointcloud from the cameras. I attached the launch file so you see what parameters are used. Also I set the visual preset to HIGH_ACCURACY for all cameras. Now the problem is, that objects/spots appear in the pointcloud where there are none. Those spots do not look like the average noise to me, as they are really small point clusters and not just random noise. One thing they have in common is, that they are a temporal phenomenon. They only exist in one pointcloud and are gone in the next. I attached a video from a test flight. You can ignore all the colored markers, important for this case is the visualization of the pointcloud. We are flying around a single tree at a height of about 4 meters. There are no other obstacles present and all the smaller point clusters to the right of the drone correspond to the mentioned phenomenon. Do you have any idea where that is coming from? Do you think I need to change any of the parameters? Any help is highly appreciated
3个回答
它发生在我身上,因为它是一个户外环境,它可能只是在快速行驶的飞行昆虫反弹,以至于它们只会在摄像机砰地关上它们时立即注册。
因此他们不在下一个点云,因为他们真的已经走了! 以上来自于谷歌翻译 以下为原文 It occurs to me that as it is an outdoor setting, it may just be bouncing off flying insects that are traveling so fast that they only register for an instant as the camera pings off them. They are therefore not in the next point cloud because they really have gone! |
nywerwer 发表于 2018-10-30 09:49 谢谢你的快速回复! 但我不太相信,视频中较大的部分肯定对昆虫来说太大了。 无人机也引起了一些空气流动,所以我认为没有任何昆虫可以关闭。 你有什么其他想法可能导致他们? 因为严重限制了我们算法的性能,我们需要摆脱它们。 以上来自于谷歌翻译 以下为原文 Thank you for your fast reply! But I am not so convinced, the bigger spots in the video are definitely too large for insects. Also the drone causes quite some air movement, soI don't think there are any insects that close. Do you have any other idea to what could be causing them? Because the seriously limit the performance of our algorithm and we need to get rid of them. |
考虑到太阳光在录制中的亮度,可能值得一看英特尔相机调校指南的室外阳光部分。 左键单击下面的图像以全尺寸查看。 值得注意的是,建议在强光下,“曝光可以减少到接近1ms,这也可以减少运动伪影” 以上来自于谷歌翻译 以下为原文 Given how bright the sunlight is in the recording, it may be worth reviewing the outdoor sunlight section of Intel's camera tuning guidelines. Left-click on the image below to view in full size. Noteworthy is the advice that in strong light, "exposure can be reduced to near 1ms, which reduces motion artifacts as well" |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-13 22:08 , Processed in 0.727253 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2016
