大家好,
我们需要使用默认情况下使用英特尔Aero Board的R200凸轮进行切换。 我们需要将micro u*** 3.0端口用于其他设备。 我们如何将D435 RealSense连接到Intel Aero Board上的现有端口,该端口目前由R200摄像头使用(在英特尔RTF无人机上)。 请问关于集成的建议? 以上来自于谷歌翻译 以下为原文 Hi all, We need to switch from using R200 cam delivered by default with Intel Aero Board. We need to use micro u*** 3.0 port for other device. How we could connect D435 RealSense to existing port on Intel Aero Board, which is currently used by R200 camera( on intel RTF drone). Please could you advice on integration? |
4个回答
Hellotrgiman,感谢您对英特尔Aero Ready to Fly无人机的兴趣。遗憾的是,来自英特尔Aero Ready to fly无人机的雷神R25相机无法替代RealSense D435相机。但是,如果您想添加RealSense
D435到您的Aero Rady飞行请考虑功耗。您还必须注意无人机的重量,如规格中所述。 (最大起飞重量为1900克。)如果您有其他问题,请告诉我。最好的问候,伊丽莎 以上来自于谷歌翻译 以下为原文 Hello trgiman, Thank you for your interest in the Intel Aero Ready to Fly drone. Unfortunately, the RealSense R200 camera from the Intel Aero Ready to fly Drone cannot be substituted with the RealSense D435 camera. If you, however, would like to also add the RealSense D435 to your Aero Rady to Fly please take the power consumption into consideration. You will also have to pay attention to the weight of the drone, as mentioned in the specifications. (maximum take off weight is 1900 g.) Please let me know if you have further questions. Best regards, Eliza |
jerry1978 发表于 2018-10-11 14:03 嗨Elisa, 体重没问题。 问题是,r200是终身产品的终结。 那么我们是否正确理解,u*** 3.0引脚无法与d435一起使用? 例如,通过一些反向插入器,例如安装在rtf上的r200可以通过rtf上的常规u*** 3.0端口或通过普通pc 3.0端口插入器的示例使用,但其他方式就是这个。 你能建议吗? r200插入器的示例恰好相反:https://cz.mouser.com/ProductDetail/?qs = 33AqgSIO4a4tekb9r%2foHPw%3dd3d 以上来自于谷歌翻译 以下为原文 Hi Elisa, weight is no issue. issue is, that r200 is end of the life product. So do we understand correctly, that u*** 3.0 pins can not be by any means used with d435 ? For instance trough some reversed interposer like for instance r200 installed on rtf can be used trough regular u*** 3.0 port on rtf or trough regular pc 3.0 port example of interposer but other way around is this one. Can you advice? Example of r200 interposer just other way around: https://cz.mouser.com/ProductDetail/?qs=33AqgSIO4a4tekb9r%2foHPw%3d%3d |
Hellotrgiman,我们不建议更改Aero RTF无人机的实际配置。如果您愿意在无人机上使用D435相机,请注意您需要specialIntel USB3-OTG线缆。 没有其他USB3-OTG电缆可以工作。最好的问候,伊丽莎 以上来自于谷歌翻译 以下为原文 Hello trgiman, We do not recommend changing the actual configuration of the Aero RTF drone. If you willing to use the D435 camera on your drone, please note that you will need the special Intel USB3-OTG cable. No other USB3-OTG cable will work. Best regards, Eliza |
嗨Elisa,
谢谢。 我们正在使用您提到的USB 3.0电缆。 但是因为我们正在整合我们的特定平台。 我们正在基于英特尔Aero Board开发它。 我们努力获取这些细节。 我有附图。 您能否确认,图片中的引脚无法与D400系列的其他英特尔实感相机一起使用? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi Elisa, Thank you. We are using USB 3.0 cable you mentioned. But since we are integrating our specific platform. And we are developing it based on Intel Aero Board. We strive to get these details. I have attached picture. Can you confirm, that pin in the picture is not possible to use by any means with other Intel Real Sense cameras of D400 series? Thank you. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-11 20:28 , Processed in 0.867954 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3358
