电子发烧友论坛|
嗨,
我们正在尝试使用Vivado工具链手动路由FPGA,并想知道应该使用什么工具来手动路由Virtex 7 FPGA。
感谢致敬, 赞歌。 以上来自于谷歌翻译 以下为原文 Hi, We are trying to maually route an FPGA using Vivado tool chain and wondering what tool should be used to manutally route a Virtex 7 FPGA. Also would it be possible to specify temperature and voltage values with in the Vivado timing analyser tool to estimate the design timing? How would we go about doing this? Thanks and Regards, Sanka. |
3个回答
嗨桑卡,
查看本教程的第三个实验。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug986-vivado-tutorial-implementation.pdf A)Vivado DesignSuitedoes没有等效的TEMPERATURE约束命令,因为从6系列设备开始,TEMPERATURE约束不会影响设计。 由于Vivado工具仅支持7系列器件,因此不需要等效的TEMPERATURE约束。实现工具在时序驱动算法中不使用'set_operating_conditions'。 在功率分析期间使用此命令。 问候 Sikta 以上来自于谷歌翻译 以下为原文 Hi Sanka, Check the third lab of the tutorial. http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug986-vivado-tutorial-implementation.pdf A) Vivado Design Suite does not have an equivalent command for TEMPERATURE constraint, because, starting from 6 series devices, the TEMPERATURE constraint does not affect the design. Since Vivado tools only support 7 series devices, there is no need of an equivalent TEMPERATURE constraint.the implementation tools do not use the ‘set_operating_conditions’ during the timing-driven algorithms. This command is used during the power analysis. Regards Sikta |
As Sikta,As Sanka提到,是否有可能放宽Virtex-7 FPGA的电压限制以改善时序.Regards,Benny
以上来自于谷歌翻译 以下为原文 Hi Sikta, As Sanka mentioned, is it possible to relax voltage constraints fot Virtex-7 FPGA to improve timing. Regards, Benny |
嗨本尼,
改变7系列器件的温度/电压范围没有限制。 如果您遇到任何时间问题,请在Timing论坛发布,我会尽力帮助。 :) 谢谢, 佳日 以上来自于谷歌翻译 以下为原文 Hi Benny, There is no constraint to change the temperature/voltage ranges for 7-series devices. If you are facing any timing issue please post that in Timing forum, I will try to help on that. :) Thanks, Yash |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:21 , Processed in 0.771730 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1246
