电子发烧友论坛|
在Kintex-7 xc7k480tffg901 2013.4我得到:
I / O 179/366 GT 10/35 将设计移植到2014.2后,这变为: I / O 172/366 GT 8/35 经过一番检查后,似乎GT_COMMON计入2013年4,但不再是2014年.2这解释了GT计数的增量。 我还没有弄清楚I / O的不同之处。 有没有人注意到并想出来了? 以上来自于谷歌翻译 以下为原文 On a Kintex-7 xc7k480tffg901 In 2013.4 I got: I/O 179/366 GT 10/35 After porting the design to 2014.2 this changed to: I/O 172/366 GT 8/35 After some inspection it seems that GT_COMMON was counted in 2013.4 but no longer in 2014.2 That explains the delta in GT count. I have not yet figured out what is different for I/O. Has anyone else noticed and figured it out? |
4个回答
嗨,
是的,你的观察是对的。 CR 794250已于2014.2提交。 在利用率报告中,IO和GT部分显示CHANNEL单元格总数,但不显示COMMON。 COMMON总数出现在报告后面的“基元”部分中。 这将根据开发决策在未来版本中修复。 希望这可以帮助。 问候 Sikta 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Yes your observation is right. CR 794250 is already filed on 2014.2 for this. In the utilization report, the IO and GT section shows CHANNEL cell totals but not COMMON. The COMMON total is present in the Primitives section later in the report. This will be fixed in the future releases based on the development decision. Hope this helps. Regards Sikta View solution in original post |
嗨,
是的,你的观察是对的。 CR 794250已于2014.2提交。 在利用率报告中,IO和GT部分显示CHANNEL单元格总数,但不显示COMMON。 COMMON总数出现在报告后面的“基元”部分中。 这将根据开发决策在未来版本中修复。 希望这可以帮助。 问候 Sikta 以上来自于谷歌翻译 以下为原文 Hi, Yes your observation is right. CR 794250 is already filed on 2014.2 for this. In the utilization report, the IO and GT section shows CHANNEL cell totals but not COMMON. The COMMON total is present in the Primitives section later in the report. This will be fixed in the future releases based on the development decision. Hope this helps. Regards Sikta |
是否可以解释IO计数中的增量?
我做了一个针报告,我的设计报告在2013.4和2014.2中是相同的,所以我相当自信现在我的升级没问题了。 以上来自于谷歌翻译 以下为原文 Can the delta in IO count be explained too? I did a pin report and the reports are identical for 2013.4 and 2014.2 in my design so I am fairly confident now my upgrade went ok. |
是的,这两个错误都被提交了。
希望有所帮助。 问候 Sikta 以上来自于谷歌翻译 以下为原文 Yes the bug was filed for both. Hope that helps. Regards Sikta |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 04:15 , Processed in 1.182605 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3687
