如题:STM8S系列单片机,tiM4作为基本的定时器,但是当中断打开以后,运行一段时间直接进入@far @interrupt void NonHandledInterrupt (void),不知道为啥,TIM4初始化:
void TIM4_Init(void) { CLK->PCKENR1 |= 0x10; //enable TIM4; TIM4->CR1 = 0x00 ; /*!< control register 1 */ TIM4->IER = 0x01; /*!< interrupt enable register */ //enable update interrupt TIM4->SR1 = 0x00; /*!< status register 1 */ TIM4->CNTR = 0x00; /*!< counter register */ TIM4->PSCR = 0x07; /*!< prescaler register */ TIM4->ARR = 249; /*!< auto-reload register */ //TIM4->EGR = 0x01; /*!< event generation register */ //enableInterrupts(); //TIM4->CR1 |= 0x01; // enable CEN } 中断函数: INTERRUPT_HANDLER(TIM4_UPD_OVF_IRQHandler, 23) { /* In order to detect unexpected events during development, it is recommended to set a breakpoint on the following instruction. */ //TIM4_ClearITPendingBit(TIM4_IT_UPDATE); TIM4->SR1 = 0xfe; //clear UIF flag //SysTaskFlag |= 0x01; Gpio_Reverse(GPIOB,0x10); SysTask10msCnt++; if(SysTask10msCnt >= SYSTASK_10MS_CNT) { SysTask10msCnt = 0; SysTaskTicksFlag |= 0x01; } SysTask100msCnt++; if(SysTask100msCnt >= SYSTASK_100MS_CNT) { SysTask100msCnt = 0; SysTaskTicksFlag |= 0x02; SysTask1sCnt++; if(SysTask1sCnt >= SYSTASK_1S_CNT) { SysTask1sCnt = 0; SysTaskTicksFlag |= 0x08; SysTask5sCnt++; if(SysTask5sCnt >= SYSTASK_5S_CNT) { SysTask5sCnt = 0; SysTaskTicksFlag |= 0x10; } SysTask1minCnt++; if(SysTask1minCnt >= SYSTASK_1MIN_CNT) { SysTask1minCnt = 0; SysTaskTicksFlag |= 0x20; } } } SysTask500msCnt++; if(SysTask500msCnt >= SYSTASK_500MS_CNT) { SysTask500msCnt = 0; SysTaskTicksFlag |= 0x04; } } 主函数: main() { SysClkInit(); Gpio_Init_Set(); TIM4_Init(); GPIOB->ODR = 0x00; delayxus(100); GPIOB->ODR |= 0x30; enableInterrupts(); TIM4->CR1 |= 0x01; while (1) { //delayxus(1000); //GPIOB->ODR = 0x00; //GPIO_TEST_Cnt++; //if( GPIO_TEST_Cnt == 40000) //{ GPIO_TEST_Cnt = 0; // Gpio_Reverse(GPIOB,0x30); //} if((SysTaskTicksFlag & 0x08) == 0x08) { SysTaskTicksFlag &= 0xf7; Gpio_Reverse(GPIOB,0x20); } } } 求大神们指教。 |
4个回答
如果屏蔽掉中断使能函数 enableInterrupts();程序可以正常运行
中断向量配置了吗
如果中断向量不设置,很容易报错的
stm8s和stm8L的向量还不同位置,楼主你检查一下
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 07:07 , Processed in 0.873640 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2068
