电子发烧友论坛|
我们知道定时器4是STM8S10X和20X系列的通用定时器,
具有定时器4中断的代码在STM8S20X系列中可以正常工作,但在STM8S103F3或K3 IC中尝试时无法产生定时器4中断, 有没有人遇到STM8S103系列定时器4中断失败的问题? 或者在设置中可能需要注意什么? 以上来自于谷歌翻译 以下为原文 As we know that timer 4 is the common timer for STM8S10X and 20X series, A code with timer 4 interrupt can work fine in STM8S20X series,but fails to generate timer 4 interrupt when trying in STM8S103F3 or K3 IC, Has anyone encounter the same problem that timer 4 interrupt failed in STM8S103 series? or what may be need to notice in the setting? |
嗨,
更新/溢出中断适用于STM8S103K3上的TIM4 在stm8s.h文件中,您可以根据应用程序中使用的STM8S设备选择目标。 感谢检查这一点,让我知道是否再次出现问题 问候 mozra 以上来自于谷歌翻译 以下为原文 Hi, The Update/Overflow interrupts works fine for TIM4 on STM8S103K3 In the stm8s.h file you can select the target according to the STM8S device used in your application. Thanks to check this point and let me know if have again the issue Regards mozra |
亲爱的先生,
我对STM8S103F2上的所有定时器(UPD / OV)都有同样的问题! 在调试时,计数器不计算在内。你说编辑STM8S.h。编辑什么? 如果我使用TIM2更新/溢出中断,请举个例子。 谢谢。 [此消息由以下人员编辑:keskintaylan于19-11-2009 11:58发表] 以上来自于谷歌翻译 以下为原文 Dear Sir, I have a same problem with all timers(UPD/OV) on STM8S103F2! In debuging the counters aren't counting. You said Edit STM8S.h . Editing what? Please give me an example if i use TIM2 Update/Overflow interrupt. Thank You. [ This message was edited by: keskintaylan on 19-11-2009 11:58 ] |
与STM8S103F3P6相同的问题(在发现代码中的STM8S105上工作正常): 建立: TIM4_CR1 = 1; TIM4_PSCR = 7; TIM4_IER = 1; 轮缘(); 打断: TIM4_SR& = ~1; 在调试器中TIM4_IER == 0 以上来自于谷歌翻译 以下为原文 >> Has anyone encounter the same problem that timer 4 interrupt failed in STM8S103 series? The same problem with STM8S103F3P6 (on STM8S105 in Discovery code works fine): setup: TIM4_CR1 = 1; TIM4_PSCR = 7; TIM4_IER = 1; rim(); interrupt: TIM4_SR &= ~1; in debugger TIM4_IER == 0 |
问题是包含错误的头文件(iostm8s.h而不是iostm8s103.h),现在工作正常
以上来自于谷歌翻译 以下为原文 The problem was in inclusion of wrong header file (iostm8s.h instead of iostm8s103.h), now works ok |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 03:34 , Processed in 0.764477 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2067
