大家好 ,
我试图在单脉冲模式下编程STM8S timer1,在读完STM8S003F3P6的数据手册后,我已经了解了如何在一个脉冲模式下编程timer1但我不明白在一个脉冲模式下编程后,在一次触发后事件,即在产生一个脉冲之后,我是否必须为每个脉冲重新初始化定时器。或者只是定时器运行信号就足够了?? Thanx 以上来自于谷歌翻译 以下为原文 Hello everyone , I am trying to program STM8S timer1 in One Pulse mode, after reading the data-sheet of STM8S003F3P6,I have understood that how to program timer1 in one pulse mode but I don't understand that after programming in one pulse mode,after one trigger event , i.e after generating one pulse, do I have to re-initialize the timer for every pulse..?? Or just timer run signal is enough??Thanx |
1个回答
我是否必须为每个脉冲重新初始化定时器
在单脉冲模式下,当您运行定时器并且它到达生成更新事件的点时(即,当CNT到达ARR然后返回到0时,在通常的上升模式下),它会清除自己的TIMx_CR1.CEN并停止。设置TIMx_CR1以重新启动它就足够了。 JW PS。这是一个STM32论坛,还有一个 https://community.st.com/community/stm8-community/stm8-mcus 您可以更好地回答与STM8相关的问题。幸运的是,STM32和STM8定时器都是相同的,细节上只有很小的差别。 以上来自于谷歌翻译 以下为原文 do I have to re-initialize the timer for every pulse No. In the One-Pulse mode, when you run the timer and it reaches the point where it generates the Update Event (i.e. in the usual upcounter mode when CNT reaches ARR and then returns to 0), it clears its own TIMx_CR1.CEN and stops. It's enough to set TIMx_CR1 to restart it. JW PS. This is an STM32 forum, and there's also an https://community.st.com/community/stm8-community/stm8-mcus where your STM8-related questions might be better answered. Luckily, both STM32 and STM8 timers are the same with only little differences in the very details. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 06:52 , Processed in 0.641981 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3347
