1个回答
edp屏添加
edp驱动被分成两个文件,一个是rk驱动文件: analogix_dp-rockchip.c, 另一个是drm驱动文件analogix_dp_core.c 1.硬件原理图: 电源IO对应gpio1_b5,gpio1_b5所在模块的电源供电是VCC_3V0,在rk808电源模块对应VLDO8,在对应dtsi里查找其名称 对应流程如下 EDP屏硬件直接按照上电时序连接好控制,软件无需干预。 EDP_HPD pin可接可不接。 所以要做的就是配置edp屏的背光使能脚以及edp屏的供电脚, 对应的是GPIO4_D6与GPIO1_B5 eDP屏参数 3.板级dts配置 + edp_panel: edp-panel { + status = "disabled"; + + ports { + panel_in_edp: endpoint { + remote-endpoint = <&edp_out_panel>; + }; + }; + }; +&edp { + force-hpd; + status = "okay"; + + ports { + edp_out: port@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + edp_out_panel: endpoint { + reg = <0>; + remote-endpoint = <&panel_in_edp>; + }; + }; + }; +}; + +&edp_panel { + status = "okay"; + compatible = "lg,lp079qx1-sp0v","simple-panel";// + backlight = <&backlight>; + //enable-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>;//gpio4_c6 backlight使能 + enable-delay-ms = <120>; + power-supply = <&vcc_lcd>; + + edp_disp_timings: display-timings { + native-mode = <&timing2>; + + timing2: timing2 { + clock-frequency = <139000000>; + hactive = <1920>; + vactive = <1080>; + hfront-porch = <60>; + hsync-len = <40>; + hback-porch = <60>; + vfront-porch = <13>; + vsync-len = <5>; + vback-porch = <13>; + hsync-active = <0>; + vsync-active = <0>; + de-active = <0>; + pixelclk-active = <0>; + + + }; + }; +}; + + +&route_edp { + status = "okay"; + connect = <&vopb_out_edp>; }; + +&edp_in_vopb { + status = "okay"; +}; +&edp_in_vopl { + status = "disabled"; +}; 所遇问题 1.edp屏:当时我用的是hdmi+edp屏,设备uboot有显示,起kernel后,黑屏没输出 设备刷屏打印: rockchip-vop ff8f0000.vop: [drm:vop_isr] ERROR POST_BUF_EMPTY irq err 原因:表示带宽不足,要调整vopl与vopb,ff8f0000–对应vopl,绑定的是hdmi,出现带宽不足, 解决:hdmi绑定vopb ;edp绑定vopl 2.pwm没回应 设备起不来 设备刷屏打印: rockchip_dp_component_ops): -517 17:33:17[ 4.035073] rockchip-drm display-subsystem: master bind failed: -517 17:33:17[ 4.036974] panel-simple edp-panel: failed to find backlight: -517 17:33:17[ 4.038823] rockchip-drm display-subsystem: devfreq is ready 17:33:17[ 4.039073] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) 17:33:17[ 4.039459] rockchip-vop ff900000.vop: missing rockchip,grf property 17:33:17[ 4.039964] rockchip-vop ff900000.vop: unable to request PWM 17:33:17[ 4.040073] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) 17:33:17[ 4.040337] rockchip-vop ff8f0000.vop: missing rockchip,grf property 17:33:17[ 4.040629] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) 17:33:17[ 4.040753] rockchip-vop ff8f0000.vop: unable to request PWM 17:33:17[ 4.040932] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) 17:33:17[ 4.041523] rockchip-drm display-subsystem: failed to bind ff970000.edp (ops 原因:有两个情况1.backlight没使能,没找到backlight节点 2.backlight的使能管脚被其他处用到(管脚被重复用) 解决:找到对应的节点 加上正确的gpio即可,其他处有引用的看是否写错或者没用到的屏掉 3.设备闪屏或设备黑屏打印如下 AUX CH command reply failed! analogix_dp_read_byte_from_dpcd: Aux Transaction fail! analogix_dp_read_byte_from_dpcd: Aux Transaction fail! 原因:edp屏线路接触不良 导致 没应答 解决:测电路是否能通 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1133 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1367 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7082 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2170 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2715 浏览 0 评论
/9
GMT+8, 2025-12-14 15:57 , Processed in 0.429601 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2118
