电子发烧友论坛|
嗨,
我正在阅读综合和实施过程中发生的事情,我有一个问题: 在合成期间,例如使用Synplify Pro,该设计从RTL描述转换为Xilinx原语,其以门级网表的形式描述,例如, EDIF文件。 翻译过程将所有EDIF文件(来自综合)和/或其他NGC文件合并到NGD中(此时也添加所有UCF)。 在UG695中,它说MAP过程“为设计中的所有基本逻辑元素分配CLB和IOB资源”。 由于此处没有进行任何放置(仅在PAR期间),这里究竟发生了什么? MAP是否仅检查设计是否适合目标设备? (在资源和IO引脚方面) 我还希望获得用户指南的链接,详细说明每个过程中发生的情况。 谢谢 LVDS不是设计师手提包! 以上来自于谷歌翻译 以下为原文 Hi, I was reading up on what goes on during Synthesis and Implementation and I have a question: During Synthesis for example using Synplify Pro, the design is converted from RTL description into Xilinx Primitives which is described in the form of a gate level netlist e.g. EDIF file. The Translate Process merges all EDIF files (from synthesis) and/or additional NGC files into a NGD (all UCFs are also added at this point). In UG695, it says that the MAP process "Allocates CLB and IOB resources for all basic logic elements in the design". Since no placement is done here (only during PAR), what exactly happens here? Does MAP only check that the design fits into the Target Device? (In terms of Resources and IO Pins) I would also appreciate links to User Guides on detailed description of what happens during each process. Thanks LVDS is NOT a designer handbag! |
1个回答
根据您运行的ISE版本,Mapper会执行放置。
随着时间的推移,工具名称可能会有些误导...... ------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 Depending on which version of ISE you are running, the Mapper does do placement. The tool names may have become slightly misleading over time... ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1326浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1168浏览 1评论
/9
GMT+8, 2025-12-2 21:10 , Processed in 0.673896 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
351
