SPI效果很好。我可以睡觉传感器,但当我试图睡觉EnOcean模块时,我发现传感器消耗的电流接近500μA。我在SDI / SDO和SCL上放了两个下拉电阻,在CS_ACC和CS_MAG上拉了两个上拉电阻。
以上来自于谷歌翻译 以下为原文 The SPI works well. I can asleep the sensor but when I try to asleep the EnOcean module, I see that the sensor consume near 500µA. I have put two pull down on SDI/SDO and SCL and two pull up on the CS_ACC and CS_MAG. |
14个回答
你能分享你的原理图吗?
我不知道STM300模块,但为什么要把SDI / SDO和SCL引脚拉低? 以上来自于谷歌翻译 以下为原文 Can you share your schematic? I don't know STM300 module, but why do you put pull down on SDI/SDO and SCL pins? |
因为STM300模块引脚在休眠时是浮动的
以上来自于谷歌翻译 以下为原文 Because the STM300 module pins are floating when it is sleeping |
好的我明白了。
问题可能是浮动INT_MAG / DRDY引脚引起的。请尝试连接此引脚上的上拉或下拉。 以上来自于谷歌翻译 以下为原文 OK, I see. The problem could be caused by floating INT_MAG/DRDY pin. Please try to connect pull-up or pull-down on this pin. |
由于引脚无法接近,我无法拉起或拉下..见下文
我试图将STM32L151CC与LSM303AGR连接,但我没有功耗问题。我认为这个引脚可以悬空而不会对功耗产生任何影响。 以上来自于谷歌翻译 以下为原文 I cannot pull up or pull down because the pin is inaccessible.. see below I have tried to connect a STM32L151CC with the LSM303AGR and I don't have the power consumption problem. I think this pin can be left floating without having any influence on the power consumption. |
其他解决方案可以将CFG_REG_C_M中的INT_MAG位设置为1。
以上来自于谷歌翻译 以下为原文 Other solution could be set the INT_MAG bit in CFG_REG_C_M to 1. |
考虑到高电流消耗仅在EnOcean模块处于休眠模式且GPIO可能处于高阻态时,问题可能是由CS引脚上的未定义电平引起的。 10M的上涨非常周。您可以尝试降低该值。但这只是我的想法。
顺便说一句。你确定LSM303AGR吸收了大电流吗? 以上来自于谷歌翻译 以下为原文 Considering the high current consumption is only when the EnOcean module is in sleep mode and the GPIO are probably in high-Z, the problem could be cause by undefined level on the CS pins. The pull-up 10M are very week. You can try to decrease the value. But it is just my idea. Btw. are you sure the high current is drawn by LSM303AGR? |
嗨,
我降低了上拉电阻的值但没有发生任何事情。 我确信LSM303AGR吸收了大电流,因为我在EnOcean模块的VCC和LSM303的另一个VCC上放置了一个电流表 以上来自于谷歌翻译 以下为原文 Hi, I have decreased the value of the pull-up resistors but nothing happened. I'm sure that high current is drawn by LSM303AGR because I have put one ammeter on the VCC of the EnOcean module and another of VCC of LSM303 |
我不知道您使用的上拉值是多少,但请尝试以下方法:
在SDI / SDO和SCL上放置两个10k下拉电阻,在CS_ACC和CS_MAG上放置两个10k上拉电阻。输入引脚必须始终驱动为高/低(无浮动)。 以上来自于谷歌翻译 以下为原文 I don't know which value of the pull-up you used, but please try following: Put two 10k pull down resistors on SDI/SDO and SCL and two 10k pull up resistors on the CS_ACC and CS_MAG. Input pins must always be driven high/low (no floating). |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 15:24 , Processed in 1.059154 second(s), Total 98, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2041
