电子发烧友论坛|
我有一台HP8753C,经过多年的忠诚服务已经发生了故障。
我已经使用了不同版本的8753超过25年,所以这不是手指麻烦。 首次打开分析仪时,它会启动并且显示正常。 然后我选择通过校准,一切正常。 执行完所有之后仍然可以。 选择完成响应时:菜单键的上部标签已损坏,但较低的标签仍然正常。 如果我然后将设置保存在寄存器2中(我无法读取标签,因为它已损坏,但我知道菜单很好,我不必阅读它们)然后从寄存器2中调用它,显示仍然是 已损坏,但在选择MKR时,菜单标签有时会恢复并且显示正常。 最近即使这个小技巧并不总是有效,所以情况正在恶化。 有没有人知道从哪里开始寻找原因? 我没有任何电路图,并怀疑它们从未发布过。 以上来自于谷歌翻译 以下为原文 I have a HP8753C which after many years of faithful service has developed a fault. I have been using different versions of the 8753 for over 25 years, so this is not finger trouble. When the analyser is first turned on it starts up and the display is normal. I then select a thru calibration and all is normal. After performing the thru all is still OK. On selecting done response: the upper labels for the menu keys become corrupted but the lower ones remain OK. If I then save the set up in register 2 (I can’t read the label because it is corrupted but I know the menus so well that I do not have to read them) and then recall it from register 2, the display is still corrupted, but on selecting MKR the menu labels sometimes recover and the display is normal. Recently even this little trick does not always work so the condition is deteriorating. Does anybody have any idea of where to start to look for the cause? I do not have any circuit diagrams and suspect that they have never been published. |
2个回答
听起来有点像数字痴呆...我猜有些位有点错误。
可能在公羊。 以上来自于谷歌翻译 以下为原文 sounds a bit like digital dementia...I guess some bits are getting a bit faulty. Might be in the ram. |
谢谢。 我记得它可能是一个RAM问题,因为菜单经常更改,因此需要一些临时存储,但不知道在哪里找到RAM。 它可能在哪个组装? 虽然这个分析仪引起了问题,但我一直在使用我的备用分析仪。 这完成了一份工作然后就死了。 看起来像08753-60202 A19图形处理器,因为有+65 V进入但没有出来。 进入+5 V并且维修手册指出此情况表明A19有故障并且必须更换。 是否有08753-60202 A19图形处理器的电路图,以便我自己修复? 它们在英国不可用,但它们在美国的价格加上非常昂贵的帖子,我不愿意支付。 我正在研究没有付费的天线,我必须以非常低的预算完成所有工作。 以上来自于谷歌翻译 以下为原文 Thank you. I had it in mind that it may be a RAM problem because the menus are frequently changed and therefore need some temporary storage, but have no idea where to find the RAM. Which assembly is it likely to be in? Whilst this analyser is causing problems I have been using my spare one. This completed one job and then died on me. Looks like the 08753-60202 A19 Graphics Processor because there is +65 V going in but not coming out. There is +5 V going in and the service manual states that this condition indicates that A19 is faulty and has to be replaced. Is there a circuit diagram for the 08753-60202 A19 Graphics Processor so that I can repair it myself? They are not available in the UK but they are in America at a price plus a very expensive post which I am loath to pay. I am doing research on antennas which is unpaid and I have to do everything on a very low budget. |
只有小组成员才能发言,加入小组>>
285 浏览 0 评论
1870 浏览 0 评论
2756 浏览 1 评论
2658 浏览 1 评论
2478 浏览 5 评论
1871浏览 0评论
434浏览 0评论
288浏览 0评论
/9
GMT+8, 2025-12-14 11:44 , Processed in 0.826006 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1850
