电子发烧友论坛|
CTRL_REG3_M(22h)寄存器的“SPI only write”SIM位有什么意义?
如果SPI处于只写模式,如何读取磁力计值? 以上来自于谷歌翻译 以下为原文 What is the meaningful of 'SPI only write' SIM bit of CTRL_REG3_M (22h) register? How magnetometer values can be read if SPI is in write only mode? |
1个回答
我认为CTRL_REG3_M的条目中有一个令人震惊的错字。什么用途是只写SPI设备?大声笑!幸运的是,手册中的其他地方表明SIM位(为什么称为SIM?)控制磁力计是处于4线模式(0)还是3线模式(1)。
我怀疑CTRL_REG3_M条目的作者试图说明** SDI **(不是SPI!)是否可用于输出和输入(3线模式,将该位设置为1)或仅用于输入(4 -wire mode,将该位设置为0)。 在这个主题上,我刚刚发现在我的应用程序中,我需要先将0写入此位,然后才能在4线模式下从器件读取。数据表说0是SIM位的默认值。但是,如果我在4线SPI系统上电后尝试读取WHOAMI,除非我首先写出所谓的“默认”值,否则它将无法工作 CTRL_REG3_M到该寄存器。 因此,我怀疑CTRL_REG3_M的条目中不仅存在打字错误,而且SIM位的默认值也可能存在错误。 以上来自于谷歌翻译 以下为原文 I think there's an egregious typo in the entry for CTRL_REG3_M. What use is a write-only SPI device? LOL! Luckily, elsewhere in the manual it indicates that the SIM bit (why is it called SIM?) controls whether the magnetometer is in 4-wire mode (0) or 3-wire mode (1). I suspect the author of the entry for CTRL_REG3_M was trying to say whether **SDI** (not SPI!) is usable for output as well as input (3-wire mode, set the bit to 1) or for input only (4-wire mode, set the bit to 0). On this topic, I have just found that in my application, I need to write 0 to this bit before I can read from the device in 4-wire mode. The data sheet says 0 is the default value for the SIM bit. But if I try to read WHOAMI after power-up in a 4-wire SPI system, it won't work unless I first write the supposed 'default' value of CTRL_REG3_M to that register. So, I suspect that not only is there a knee-slapper of a typo in the entry for CTRL_REG3_M, there may also be an error in the default value for the SIM bit. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 03:37 , Processed in 0.892904 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1603
