我正在尝试在LSM9DS1传感器上测试磁力计。
我可以应用与LIS3MDL指南针相同的自测范围值来检查LSM9DS1吗?事实是LSM9DS1中的磁力计似乎是LIS3MDL(寄存器的相同文档)。我正在使用 http://www.st.com/resource/en/application_note/dm00136626.pdf 第19页说明了自检程序,表17中给出了自检范围。我已经实现了LSM9DS1的自检程序,并且我在一个传感器上获得了该程序,我怀疑它有以下值: Average_X_self_test - Average_X_no_self_test = 2551(无比例)= 0,93高斯 Average_Y_self_test - Average_Y_no_self_test = 2682(无比例)= 0,98高斯 Average_Z_self_test - Average_Z_no_self_test = -415(无比例)= -0,15高斯 对于第二个似乎没问题的传感器,值是: Average_X_self_test - Average_X_no_self_test = -4476(无比例)= -1,64高斯 Average_Y_self_test - Average_Y_no_self_test = -4473(无比例)= -1,64高斯 Average_Z_self_test - Average_Z_no_self_test = -515(无比例)= -0,19高斯 在几次自测试中,值是一致的。如果我采用LIS3MDL应用笔记中提到的范围,则意味着第一个传感器坏了。 感谢您的支持。 最好, 大卫 #lsm9ds1#lis3mdl #magnetometer#self-test 以上来自于谷歌翻译 以下为原文 I am trying to test the magnetometer on LSM9DS1 sensors. Can I apply the same self-test range-values than the LIS3MDL compass to check the LSM9DS1? The fact is that the magnetometer in the LSM9DS1 seems to be a LIS3MDL (same documentation of the registers). I am using the http://www.st.com/resource/en/application_note/dm00136626.pdf , where the self-test procedure is explained in page 19, with self-test ranges indicated in table 17.I already implemented a self-test procedure for the LSM9DS1 and I obtained for one sensor on which I suspect a problem the following values: Average_X_self_test - Average_X_no_self_test = 2551 (no scale) = 0,93 gauss Average_Y_self_test - Average_Y_no_self_test = 2682 (no scale) = 0,98 gauss Average_Z_self_test - Average_Z_no_self_test = -415 (no scale) = -0,15 gauss And for a second sensor that seems ok, the values are: Average_X_self_test - Average_X_no_self_test = -4476 (no scale) = -1,64 gauss Average_Y_self_test - Average_Y_no_self_test = -4473 (no scale) = -1,64 gauss Average_Z_self_test - Average_Z_no_self_test = -515 (no scale) = -0,19 gauss Values are consistent on several runs of self-tests. And if I take the ranges mentioned in the application note of the LIS3MDL, it means that the first sensor is broken. Thank you for your support. Best, David #lsm9ds1 #lis3mdl #magnetometer #self-test |
1个回答
大卫你好,
如你可以使用的另一个线程中所提到的 http://www.st.com/content/ccc/resource/technical/document/application_note/69/d7/05/fe/a9/3e/4b/ea/DM00136626.pdf/files/DM00136626.pdf/jcr:内容/翻译/ en.DM00136626.pdf 用于LSM9DS1磁力仪自测包括极限。如果您提到的第一个传感器没有损坏,那么它至少是边缘的。注意, 切赫 以上来自于谷歌翻译 以下为原文 Hello David, as mentioned in another thread you can use http://www.st.com/content/ccc/resource/technical/document/application_note/69/d7/05/fe/a9/3e/4b/ea/DM00136626.pdf/files/DM00136626.pdf/jcr:content/translations/en.DM00136626.pdf for LSM9DS1 magnetometer selftest including the limits. If the first sensor you mentioned is not broken than it's at least marginal.Regards, Petr |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2187 浏览 1 评论
3001 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1579 浏览 1 评论
3389 浏览 6 评论
5707 浏览 21 评论
734浏览 4评论
1089浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
368浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1076浏览 3评论
1126浏览 3评论
GMT+8, 2024-7-27 10:54 , Processed in 1.262455 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
