电子发烧友论坛扫一扫,分享给好友
最近,我开始玩一个CY8CKIT-059S,用于我正在做的一个项目。不幸的是,我无法让UBUART驱动程序安装。我试过了:
1)将DEV板插入4个不同的Windows 7 64位PCs. Windows寻找驱动程序,但最终给了我一个错误,并说它找不到设备的驱动程序。 2)通过设备管理器卸载设备,重新启动,并重复步骤1。这给出了相同的结果。 3)通过设备管理器卸载设备,从这里下载CyPress USB串行安装程序并安装驱动程序。设备仍然不工作,Windows没有看到驱动程序。 4)在安装CyPress驱动程序的文件夹下,运行CyDrReValueSerixx64.EXE。本文简要提出了命令提示符,并说“请重新运行程序修复的驱动程序的安装设置。“我试过了),然后再运行安装程序运行cydriveruninstaller_x64.exe,和b)去除所有的USB串口驱动程序的文件夹使用卸载程序,重新安装驱动程序,然后重新安装64位驱动程序。不管怎样,我还是把消息告诉我重新安装维修。 所有安装程序已经运行作为一个管理员,当我重新安装驱动程序包,我确信这样做在程序文件夹。 没有任何人有任何建议或想法,如何让这些驱动程序安装并正确运行? 以上来自于百度翻译 以下为原文 I recently started playing around with a couple of CY8CKIT-059s for a project that I'm working on. Unfortunately, I'm not able to get the USBUART drivers to install. I've tried: 1) Plugging the dev board into 4 different Windows 7 64bit PCs.Windows looks for the driver but eventually gives me an error and says that it can't find drivers for the device. 2) Uninstalling the device via the device manager, rebooting, and repeating step 1. This gives the same result. 3) Uninstalling the device via the device manager, downloading the Cypress USB-Serial installer from here and installing the drivers. The device still doesn't work and Windows doesn't see drivers for it. 4) Under the folder where the Cypress drivers were installed, running CyDriverInstaller_x64.exe. This briefly brings up the command prompt and says "Please rerun the driver installation setup for driver repair operation." I've tried both a) running CyDriverUninstaller_x64.exe and then rerunning the installer, and b) removing everything from the USB Serial Driver folder using their uninstaller, reinstalling the driver package, then reinstalling the 64 bit driver. Regardless, I still get the message telling me to rerun the installation setup for repair. All the installers have been run as an administrator, and when I reinstalled the driver package, I made sure to do so outside of the Program Files folder. Does anybody have any recommendations or ideas as to how to get these drivers installed and running correctly? |
2个回答
请安装PSoC程序员,然后在这条路径上你将得到KiPrasuBuART.INF文件:
C:程序文件(x86) CyPress 程序员驱动程序 以上来自于百度翻译 以下为原文 Please install the PSoC Programmer, then on this path you will get KitprogUSBUART .inf file : C:Program Files (x86)CypressProgrammerdriversKitProg |
是这样的,谢谢。 以上来自于百度翻译 以下为原文 That did it, thanks. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7070 浏览 0 评论
2474 浏览 1 评论
2165 浏览 1 评论
4030 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 16:19 , Processed in 0.626353 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2851
