电子发烧友论坛|
你好,
FX2LP的控制中心应用程序在WindowsXP上运行良好,但它与Windows 10.1的工作原理不一致,是驱动程序问题吗?让我知道。 当做, 吉瑟纳利 以上来自于百度翻译 以下为原文 Hello, control center application for fx2lp is working fine with windows xp but its not working same with the windows 10.1 pro.is it driver issues?let me know. regards, geethanjali. |
12个回答
请阐述你的意思不是在Win 10.1 Pro的工作吗?
司机,FX2LP被捆绑在Win 10.1 Pro是什么?检查驱动程序版本在WindowsXP和Win 10.1 PRO? 以上来自于百度翻译 以下为原文 Can you please elaborate what do you mean by Not working in Win 10.1 Pro? What is the driver that the Fx2LP being bound in Win 10.1 Pro? Check the driver version in Windows Xp and Win 10.1 Pro? |
yahan52 发表于 2018-9-4 10:09 你好, 当我们在WindowsXP中运行控制中心时,图像会正确地出现,但是在Windows 10.1 Pro图像中的代码是混乱的。 请参阅图片。 以上来自于百度翻译 以下为原文 hi srdr, when we will run the control center in windows xp the images are coming correctly but the same code in windows 10.1 pro images are jumbled i have attached images both . please refer the images. |
不cdvdhgdh 发表于 2018-9-4 10:22 你好,Geethanjali, 请更新cyu***3司机1.2.3.20在Windows 10 PC的驱动力随着FX3 SDK。 http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Geethanjali, Please update the CYUSB3 driver to 1.2.3.20 on the Windows 10 PC. The driver comes along with the FX3 SDK. http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit Best regards, Srinath S |
wangcong12138 发表于 2018-9-4 10:37 你好,克里斯纳特, 在更新驱动程序之后,问题也是一样的。 谢谢。 以上来自于百度翻译 以下为原文 Hello shrinath, after updating the driver also,the problem is same. thanks. |
你好,Geethanjali, -你能建立在Windows 10.1 PC主机应用程序和运行应用程序吗?请检查这让知道,如果问题依然存在。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Geethanjali, - Can you please build the host application on the Windows 10.1 PC and run the application? Kindly, check this and let know if the problem still persists. Best regards, Srinath S |
wangcong12138 发表于 2018-9-4 11:03 你好,克里斯纳特, 我们在Windows 10.1的PC主机应用程序的唯一建筑。 当做, 吉瑟纳利 以上来自于百度翻译 以下为原文 Hello shrinath, we are building the host application on windows 10.1 PC only. regards, geethanjali. |
wangcong12138 发表于 2018-9-4 11:03 你好,克里斯纳特, Windows 10 Pro有什么不对?问题是一样的。 当做, 吉瑟纳利 以上来自于百度翻译 以下为原文 Hello shrinath, whats wrong with windows 10 pro.?issue is same. regards, geethanjali. |
你好, 更新Windows10()的驱动程序后,问题是SAM.但是它的工作原理是Windows XP和Windows7.FX2LP/FX3驱动程序支持Windows 10 Pro。 请找到下面的屏幕截图窗口细节。 以上来自于百度翻译 以下为原文 hello, After updating driver for windows 10(),problem is same.but its work fine with windows xp and windows 7.is fx2lp/fx3 drivers supports for windows 10 pro. please find the below screenshots regadring windows details. |
不cdvdhgdh 发表于 2018-9-4 11:41 你好,Geethanjali, 赛普拉斯尚未发布Win 10 RS4司机(1803建)。好,测试它在一个赢得10以下版本RS4和检查它是否工作正常。 最好的问候,Srinath S 以上来自于百度翻译 以下为原文 Hello Geethanjali, Cypress has not yet released the drivers for Win 10 RS4 (1803 Build). Kindly, test it on a Win 10 version below RS4 and check if it works fine. Best regards, Srinath S |
wangcong12138 发表于 2018-9-4 12:01 你好,克里斯纳特, 我们得到了30帧每秒(361472字节/帧。)在Windows xp.but在Windows 7中,我们用相同的固件到每秒10帧,硬件和software.why是失败几次。 我们收到10帧窗口(即361472bytes)与默认的控制中心。 在Windows XP中,将有两个头之间361472bytes(mindflow)。 但在windows7,之间的标题数据是不同的(小于361472bytes,超过361472bytes)。 那么问题是什么呢? 当做, 吉萨 以上来自于百度翻译 以下为原文 hello shrinath, we are getting 30 frames per second(361472 bytes per frame.) in windows xp.but in windows 7,we are getting 10 frames per second with same firmware,hardware and software.why it is failing some times. we recieved 10 frames in both windows(i.e. 361472bytes) with defualt control center. in windows xp,there will be 361472bytes between two consecutive hearder(MINDFLOW). but in windows7,data between the header is varying (less than 361472bytes ,more than 361472bytes). so what is the issue ? regards, geetha. |
wangcong12138 发表于 2018-9-4 12:01 你好,克里斯纳特, 塞浦路斯还没有发布10胜4(1803建设)的驱动程序。请测试一下RS4下的Win 10版本,并检查它是否正常运行。 -当我们可以获得10以上的RS4(1803建造)的车手? 当做, 吉萨 以上来自于百度翻译 以下为原文 Hello shrinath, Cypress has not yet released the drivers for Win 10 RS4 (1803 Build). Kindly, test it on a Win 10 version below RS4 and check if it works fine. ->when we can get drivers for win 10 above RS4(1803 Build)? regards, geetha. |
不cdvdhgdh 发表于 2018-9-4 12:15 你好,盖萨, 我们目前正在测试相同的,它很快就会发布。我们会通知你准备放行的时候。 最好的问候, 萨尼亚尼亚 以上来自于百度翻译 以下为原文 Hello Geetha, We are currently testing the same and it'll be released soon. We'll notify you when it is ready for release. Best Regards, Sananya |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 08:35 , Processed in 0.850607 second(s), Total 96, Slave 79 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2335
