电子发烧友论坛|
你好,
我喜欢在PSoC6上用一个3线SPI实现访问一个SPI从属器。组件SPI(SCB V2.0)似乎没有一个3线SPI实现/子模式。 我确实看到了国家半导体(微丝),但这仍然是4线。 在PSoC6中有没有办法支持这一点? 我看到这在其他PSoC家族中得到了支持。 谢谢! 以上来自于百度翻译 以下为原文 Hi, I like to access a SPI slave with 3-wire SPI implementation on PSOC6. The component SPI(SCB v2.0) doesn't seem to have a 3 wire SPI implementation/sub-mode. I do see National Semiconductor (microwire), but this is still 4 wire. Any there a way to support this in PSOC6? I see that this is supported in other PSOC family. Thanks! |
2个回答
你好,
三线SPI实现是高度特定于设备的。如果您连接到一个类似LM74三线实施的奴隶,这通常需要连接一个高值电阻(10kΩ的典型Ω)从MOSI为味噌电阻。从设备的SI/O引脚连接到这个节点。MISO和MOSI驱动器是互斥的你可以看到从时序图: 在某些情况下,你必须使用GPIO作为奴隶的选择和实现一个基于时间的自定义固件。请通过奴隶的数据表和试图实现其时序图匹配。 当做 尼丁 以上来自于百度翻译 以下为原文 Hello, Three wire SPI implementations are highly device-specific. If you're connecting to a slave with a 3 wire implementation similar to LM74, this is usually done with with connecting a high value resistor (typically 10kΩ) resistor from MOSI to MISO. Slave's SI/O pin is connected to this node. MISO and MOSI drives are mutually exclusive as you can see from the timing diagram: In some cases, you have to use a GPIO as the slave select and implement a custom firmware based timing. Please go through the slave's datasheet and try to match your implementation with its timing diagram. Regards Nidhin |
60user48 发表于 2018-8-17 08:21 你好, 另一个解决方案,如果你使用一个SPI端口8或9将是利用Smartio和内部数据单元路由数据自动MOSI和MISO。数据单元被配置为计数器控制通过LUT数据复用。应该使用芯片选择来重置数据单元。 第三解决方案和最复杂的是使用UDB中自定义组件。但这也有一些特殊情况下的SPI通信的时序要求最灵活。 亲切的问候, 阿希姆 以上来自于百度翻译 以下为原文 Hello, Another solution if you use an SPI on Port 8 or 9 would be to use SmartIO and the internal Data Unit to route the data automatically to MOSI and MISO. The Data Unit has to be configured as counter that controls the multiplexing of the data via the LUTs. Chip Select should be used to reset the Data Unit. Third solution and most complex would be a custom component using the UDBs. But this is also the most flexible in case the SPI communication has some special timing requirements. Kind Regards, Achim |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 20:27 , Processed in 0.823818 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
636
