电子发烧友论坛|
亲爱的,
我需要通过UART接收数据的帮助,因为当我把数据通过PC工具,进程不中断功能,但如果我用xx_uartputchar()发送回来的数据,我可以通过PC工具得到的数据,这意味着董事会已经收到的数据,但它为什么不能进入中断函数?我很欣赏,如果有人能提供一些帮助,非常感谢! 图1:设计资源引脚,引脚21和引脚22是UART RX和TX我的名字是UART UART总线。 图片2:UART配置。 图片3:主要功能。 图4:默认的中断功能。 中断功能 47.4 K MIN JPG 26.4 K UP.JPG 93.8 K JPG 116 K 以上来自于百度翻译 以下为原文 dear , I need help about Receiving Data by UART, because when I send data by PC tool, the process can not interrupt function, but if I use XX_UartPutChar() to send the data back, I can receive the data by PC tool, that means the board had received data, but why it can not enter the interrupt function ? I am very appreciate if anyone can give some help , thank you very much ! picture 1: pins of Design Wide Resource, pin 21 and pin 22 are UART rx and UART tx. my UART's name is DBUS. picture 2: UART config. picture 3: main fuction. picture 4: default interrupt function.
2个回答
亚历山大
检查这个PSoC4 UART代码示例(从终端接收/发送命令字符串并改变LED亮度) (SCB模式) http://www. Cypop.com /评论/ 389231 类似于UDB模式 http://OrgIn www. CyPress 上面的例子是PSOC4200,我相信你有PSoC4100,所以可能有一些不同。 对于未来,不要发布JPEG代码片段,有共享项目的标准解决方案。 1。清洁项目,顶部菜单-建立和清洁。2。在左侧的项目资源管理器窗口中选择项目名称,并在文件-GT中创建工作空间束-gt;三。打开创建的存档文件(zip)并删除生成的源文件夹。现在您可以发布小型存档项目进行审核。 ODISSEY1 以上来自于百度翻译 以下为原文 alexsh, Check this PSOC4 UART code example (receiving/sending command string from terminal and changing LED brightness) (SCB mode) http://www.cypress.com/comment/389231#comment-389231 And similar for UDB mode http://origin-www.cypress.com/comment/235306#comment-235306 The examples above are for PSoC4200, and I believe you have PSoC4100, so there may be some differences. For the future, do not post JPEG snippets of the code, there is standard solution for sharing the project. 1. Clean the project, Top Menu->Build->Clean. 2. Select Project Name in the Project Explorer window on the left and File->Create Workspace Bundle->Minimal. 3. Open created Archive file (zip) and delete Generated Source folder. Now you can post small archived project for review. /odissey1 |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 00:47 , Processed in 0.700448 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
445
