电子发烧友论坛|
CC1101的RX_OFF设置为接收,发送完成后都进入IDLE 接收使用中断方式,有CRC校验 发送非中断,有CCA, 问题1:CRC校验失败是否能进入接收中断 问题2:CCA校验失败后是否一直处于接收状态 |
3个回答
问题1:
你设置的中断事件是什么? 问题2:请看手册15.3.3, 15.3.3 CRC Filtering The filtering of a packet when CRC check fails is enabled by setting PKTCTRL1.CRC_AUTOFLUSH=1. The CRC auto flush function will flush the entire RX FIFO if the CRC check fails. After auto flushing the RX FIFO, the next state depends on the MCSM1.RXOFF_MODE setting. When using the auto flush function, the maximum packet length is 63 bytes in variable packet length mode and 64 bytes in fixed packet length mode. Note that when PKTCTRL1.APPEND_STATUS is enabled, the maximum allowed packet length is reduced by two bytes in order to make room in the RX FIFO for the two status bytes appended at the end of the packet. Since the entire RX FIFO is flushed when the CRC check fails, the previously received packet must be read out of the FIFO before receiving the current packet. The MCU must not read from the current packet until the CRC has been checked as OK. |
GDO0设置为0x06,中断为下跳沿中断 出中断时清除接收缓存,重新进入接收模式 自动刷新并未开启 CCA检测若有载波时,状态是如何切换的? |
问题1:CRC校验失败是否能进入接收中断 设置为0X06.CRC校验失败可以进入中断,可以用smartstudio测试一下。你这个设置只跟是否检测到同步字有关。 Asserts when sync word has been sent / received, and de-asserts at the end of the packet. In RX, the pin will also deassert when a packet is discarded due to address or maximum length filtering or when the radio enters RXFIFO_OVERFLOW state. In TX the pin will de-assert if the TX FIFO underflows. 问题2:CCA校验失败后是否一直处于接收状态 CCA是清洁信道检测,检测信号强度是否超过阀值。你不关闭接收状态,可定一直接收。建议你参考simpliciTI协议栈familiy 1->mifi_radio.c中MRFI_Transmit()的操作。他的想法是如果有载波,说明当前有通讯,关闭接收,随机退避一段时间,再try.超过设定次数发送失败,否则,发送。 http://www.ti.com/tool/simpliciti |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 20:29 , Processed in 0.703171 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4569
