电子发烧友论坛|
6 个讨论
试试加长host发opcode之间的时间间隔。
NOTE: SPI slave boot modes suffer from a bug during Opcode Synchronization. The bootloader will hang if an opcode is sent by the host before the bootloader is ready to receive it (for example., if the bootloader is still processing the previous opcode). Therefore, in SPI slave boot modes, the host should insert sufficient delay between opcodes that the bootloader is ready to receive the next opcode. This bug does not affect other slave boot modes (I2C, UART, etc.). http://www.ti.com/lit/an/sprabb1c/sprabb1c.pdf |
vuywsdfwf 发表于 2018-7-31 10:30 Each AIS command consists of an opcode, optionally followed by one or more arguments, followed by optional data 每个opcode后面都有参数,这些参数是跟随在opcode之后发给DSP吗?我现在就是这么做的,但是没有收到RECV opcode。 |
qksorl1994 发表于 2018-7-31 10:41 应该是我理解错了,opcode后面的参数需要收到应答后才发送。 8.3 The AIS_Util.cs Source Code The UART Boot Host includes a single C# source file named AIS_Util.cs, which serves as a reference implementation of the boot master requirements laid out in Section 7. This source file is used by the UART Boot Host application itself, and is provided as-is with no direct support. 我在看AIS_Util.cs的代码,参照这个代码应该能有个结果。 |
qksorl1994 发表于 2018-7-31 11:00 DSP SPI SLAVE BOOT成功! 最后一步 opcode synchronization,需要先单独发送opcode,收到RECV opcode后,再发送opcode后面的数据。 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 02:54 , Processed in 0.900812 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1277
