电子发烧友论坛|
下载了 spiflash_writer_dsp 这个程序,运行正确,仔细分析了代码,有个疑惑的地方:
spi_xfer这个函数: int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) [ struct davinci_spi_slave *ds = to_davinci_spi(slave); unsigned int len; int i; const Uint8 *txp = dout; Uint8 *rxp = din; if (bitlen == 0) /* Finish any previously submitted transfers */ goto out; /* * It's not clear how non-8-bit-aligned transfers are supposed to be * represented as a stream of bytes...this is a limitation of * the current SPI interface - here we terminate on receiving such a * transfer request. */ if (bitlen % 8) [ /* Errors always terminate an ongoing transfer */ flags |= SPI_XFER_END; goto out; ] len = bitlen / 8; /* do an empty read to clear the current contents */ SPI_SPIBUF; /* keep writing and reading 1 byte until done */ for (i = 0; i < len; i++) [ /* wait till TXFULL is asserted */ while( SPI_SPIBUF & 0x20000000 ); /* write the data */ data1_reg_val &= ~0xFFFF; if(txp) [ data1_reg_val |= *txp & 0xFF; txp++; ] /* write to DAT1 is required to keep the serial transfer going */ /* we just terminate when we reach the end */ if((i == (len -1)) && (flags & SPI_XFER_END)) [ SPI_SPIDAT1 = data1_reg_val & ~(1 << 28); ] else [ SPI_SPIDAT1 = data1_reg_val; ] /* read the data - wait for data availability */ while ( SPI_SPIBUF & ( 0x80000000 ) ); if(rxp) [ *rxp = SPI_SPIBUF & 0xFF; rxp++; ] else [ SPI_SPIBUF; ] ] return 0; out: if (flags & SPI_XFER_END) [ SPI_SPIDAT1 = data1_reg_val & ~(1 << 28); ] return 0; ] 有一个语句: /* read the data - wait for data availability */ while ( SPI_SPIBUF & ( 0x80000000 ) ); 为什么需要这个?winbond SPI有些命令,比如 0x06,写允许命令,并不返回数据,岂不是一直等待! 请 TI 专家解释解释。 |
2 个讨论
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 10:33 , Processed in 0.708739 second(s), Total 68, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1858
