电子发烧友论坛扫一扫,分享给好友
大家好!
目前在调试Mcbsp接口,使用中发现连续调用例程中的函数mcbspSubmitChan发送数据,两次间隔时间较长,达到100ms左右。请问是否有方法改进其间隔时间,使其达到3ms内? 具体配置如下: #define NUM_BUFS 1 /* Max of 2 outstanding requests */ #define BUFSIZE 2048 /* 1K of data transceive */ #define NUM_OF_CHANNELS 1//8 /* Number of slots to be used */ Mcbsp_srgConfig mcbspSrgCfg = [ FALSE, /* No gsync to be used as input is not CLKS */ Mcbsp_ClkSPol_RISING_EDGE, /* Dont care as input clock is not clks */ Mcbsp_SrgClk_CLKCPU, /* McBSP internal clock to be used */ 166666667, /* Mcbsp internal clock frequency(PLL-SYSCLK6) */ 0 /* frame sync pulse width (val+1) is used */ ]; // ///** // * brief Mcbsp device creation default parameters. // * // */ const Mcbsp_Params Mcbsp_PARAMS = [ Mcbsp_DevMode_McBSP, /* Use the device as MCBSP */ Mcbsp_OpMode_DMAINTERRUPT, /* Use DMA mode of operation */ TRUE, /* cache coherency taken care of by driver */ Mcbsp_EmuMode_SOFT_STOP, /* Soft mode is to be enabled */ Mcbsp_Loopback_DISABLE, /* Loop back mode disabled */ &mcbspSrgCfg, /* sample rate generator configuration */ NULL, /* TX pending buffer queue from application */ NULL, /* TX floating buffer queue in DMA */ NULL, /* RX pending buffer queue from application */ NULL /* RX floating buffer queue in DMA */ ]; // #pragma DATA_ALIGN(loopJob, MCBSP_MAX_CACHE_ALIGN) static Int32 loopJob[16] = [ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ]; // ///**< settings to configure the TX or RX hardware sections */ Mcbsp_DataConfig mcbspChanConfig = [ Mcbsp_Phase_SINGLE, Mcbsp_WordLength_32, Mcbsp_WordLength_32, /* Dont care for single phase*/ NUM_OF_CHANNELS, NUM_OF_CHANNELS, // Only using single phase, hence num channels is 0 Mcbsp_FrmSync_DETECT, Mcbsp_DataDelay_0_BIT,//Mcbsp_DataDelay_1_BIT, Mcbsp_Compand_OFF_MSB_FIRST, Mcbsp_BitReversal_DISABLE, Mcbsp_IntMode_ON_SYNCERR, Mcbsp_RxJust_RZF, /* Dont care for TX */ Mcbsp_DxEna_OFF ]; // /**< clock setup for the TX section */ Mcbsp_ClkSetup mcbspClkConfigTx = [ Mcbsp_FsClkMode_INTERNAL, 1000000, /* 96KHz */ Mcbsp_TxRxClkMode_INTERNAL, Mcbsp_FsPol_ACTIVE_HIGH, Mcbsp_ClkPol_FALLING_EDGE ]; /**< clock setup for the RX section */ Mcbsp_ClkSetup mcbspClkConfigRx = [ Mcbsp_FsClkMode_EXTERNAL, 1000000, /* 96KHz */ Mcbsp_TxRxClkMode_EXTERNAL, Mcbsp_FsPol_ACTIVE_HIGH, Mcbsp_ClkPol_RISING_EDGE ]; /**< Multi channel setup */ Mcbsp_McrSetup mcbspMultiChanCtrl = [ Mcbsp_McmMode_ALL_CHAN_ENABLED_UNMASKED, Mcbsp_PartitionMode_CHAN_0_15, Mcbsp_PartitionMode_CHAN_16_31, Mcbsp_PartitionMode_2 ]; Mcbsp_ChanParams mcbspChanparamTx = [ Mcbsp_WordLength_32, /* wordlength configured */ &loopJob[0], /* loop job buffer internal */ 8, /* user loopjob length */ NULL, /* global error callback */ NULL, /* edma Handle */ 1, /* EDMA event queue */ 8, /* hwi number */ Mcbsp_BufferFormat_1SLOT,//Mcbsp_BufferFormat_MULTISLOT_NON_INTERLEAVED, TRUE, /* FIFO mode enabled */ &mcbspChanConfig, /* channel configuration */ &mcbspClkConfigTx, /* clock configuration */ &mcbspMultiChanCtrl, /* multi channel control */ 0x00, 0x00, 0x00, 0x00 ]; Mcbsp_ChanParams mcbspChanparamRx = [ Mcbsp_WordLength_32, /* wordlength configured */ &loopJob[0], /* loop job buffer internal */ 8, /* user loopjob length */ NULL, /* global error callback */ NULL, /* edma Handle */ 2, /* EDMA event queue */ 8, /* hwi number */ Mcbsp_BufferFormat_1SLOT,//Mcbsp_BufferFormat_MULTISLOT_NON_INTERLEAVED, TRUE, /* FIFO mode enabled */ &mcbspChanConfig, /* channel configuration */ &mcbspClkConfigRx, /* clock configuration */ &mcbspMultiChanCtrl, /* multi channel control */ 0x00, 0x00, 0x00, 0x00 ]; 具体工程见附件。 谢谢 |
1个回答
问题已解决。去掉systemprintf即可
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 17:52 , Processed in 0.596789 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1027
