电子发烧友论坛扫一扫,分享给好友
目的:tftp下载内核,并且通过NFS挂载根文件系统出现以下错误
虚拟机IP:192.168.253.128 板子IP:192.168.253.183 /etc/exports 内容:/opt/DVRRDK_02.00.00.23/target/rfs *(rw,nohide,insecure,no_subtree_check,async,no_root_squash) IP-Config: Complete: device=eth0, addr=192.168.253.183, mask=255.255.255.0, gw=192.168.253.1, host=192.168.253.183, domain=, nis-domain=(none), bootserver=192.168.253.142, rootserver=192.168.253.142, rootpath= nfs相关设置信息截图: 虚拟机的防火墙也关闭了,启动延迟设置为8秒,内核配置也选择了ROOT FILE SYSTEM ON NFS选项 .config文件开启选项截图为 错误提示: ata2: EH complete ata1: EH complete VFS: Unable to mount root fs via NFS, trying floppy. VFS: Cannot open root device "nfs" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 2432 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 3072 mtdblock2 (driver?) 1f03 4352 mtdblock3 (driver?) 1f04 252160 mtdblock4 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) Backtrace: [ r7:c5bf8000 r6:00000000 r5:c002dbfc r4:c0551710 [ [ r3:00000000 r2:00000000 r1:c5825f58 r0:c0485b7c [ [ r4:c0550fa4 [ r5:c0008670 r4:c0550f40 [ r5:c0008670 r4:00000000 附件为板子启动的全部信息,希望高手指教! |
7个回答
检查出了一个问题,我的bootsever和rootsever的ip应该跟虚拟机ip统一,但是更改之后继续往下面跑还是会出错
Error opening /dev/fb0: No such file or directory Please wait: booting... Starting udev /etc/rcS.d/S03udev: line 50: can't create /tmp/uname: Read-only file system touch: /tmp/uname: Read-only file system Root filesystem already rw, not remounting Caching udev devnodes Populating dev cachetar: can't open '/etc/dev.tar': Permission denied mv: overwrite '/etc/udev/saved.uname'? 这又是什么原因引起的呢? 谁帮忙解答下! |
727634sf 发表于 2018-5-28 10:50 /etc/rcS.d/S03udev: line 50: can't create /tmp/uname: Read-only file system 挂载的这个文件系统是只读的,检查一下权限 |
sosolala 发表于 2018-5-28 11:08 是的,用户root权限登陆后问题解决了! |
727634sf 发表于 2018-5-28 10:50 请问一下,你的bootsever和rootsever的IP是怎么设置的? |
sosolala 发表于 2018-5-28 11:08 大哥 我也碰到了 这个问题 。 想问一下要怎么样以 root身份登录? 在虚拟机上还是开发板上 ? |
727634sf 发表于 2018-5-28 10:50 我是使用的虚拟机安装的linux,root登录时也报这样的错误,不知道是什么原因,能不能帮忙解决一下。谢谢! |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 10:03 , Processed in 1.126421 second(s), Total 85, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1367
