电子发烧友论坛扫一扫,分享给好友
各位大牛,这边有两个问题请教下各位:
1、我这边在使用EMAC启动时候无法从网络启动,使用的网络芯片是TLK105,为MII模式,晶振25MHZ,cpu芯片AM3352,cpu晶振24MHz,串口打印信息如下: U-Boot SPL 2013.01.01 (Sep 29 2014 - 10:41:06) Could not probe the EEPROM; something fundamentally wrong on the I2C bus. Could not get board ID. mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory USB Peripheral mode controller at 47401000 using PIO, IRQ 0 mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory USB Host mode controller at 47401800 using PIO, IRQ 0 Using default environment PHY reset timed out cpsw link up on port 0, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 Retry count exceeded; starting again link up on port 0, speed 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 BOOTP broadcast 5 BOOTP broadcast 6 BOOTP broadcast 7 BOOTP broadcast 8 BOOTP broadcast 9 BOOTP broadcast 10 Retry count exceeded; starting again link up on port 0, speed 1000, full duplex BOOTP broadcast 1 2、我另一个板子使用的是USB启动,这个可以正常启动kernel并且也可以把内核和文件系统烧录到eMMC,但是调试网络部分的时候,能够识别到TLK105的百兆网,但是无法获取ip,打印如下: Starting kernel ... Uncompressing Linux... done, booting the kernel. [ 0.000000] Linux version 3.2.0 (zhyf@ECU-SERVER) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013 .03) ) #4 Fri Oct 31 09:07:27 CST 2014 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache [ 0.000000] Machine: am335xevm [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] AM335X ES2.1 (neon ) [ 0.000000] ------------[ cut here ]------------ [ 0.000000] WARNING: at arch/arm/mach-omap2/clkt_clksel.c:194 omap2_clksel_re calc+0xc8/0x134() [ 0.000000] clock: Could not find fieldval 0 for clock dpll_core_m6_ck parent dpll_core_x2_ck [ 0.000000] Modules linked in: [ 0.000000] Backtrace: [ 0.000000] [ tack+0x18/0x1c) [ 0.000000] r6:c0030b28 r5:00000009 r4:c05d3e78 r3:c05f450c [ 0.000000] [ th_common+0x54/0x6c) [ 0.000000] [ arn_slowpath_fmt+0x38/0x40) [ 0.000000] r8:80000200 r7:c06504a4 r6:00000000 r5:c05e6c38 r4:00000000 [ 0.000000] r3:00000009 [ 0.000000] [ 2_clksel_recalc+0xc8/0x134) [ 0.000000] r3:00000000 r2:c0500fe8 [ 0.000000] [ ropagate_rate+0x34/0x54) [ 0.000000] r6:c06504dc r5:c05e6b38 r4:c05e6c38 [ 0.000000] [ te_rate+0x40/0x54) [ 0.000000] r5:c05e6adc r4:c05e6b24 [ 0.000000] [ te_rate+0x40/0x54) [ 0.000000] r5:c05e6a24 r4:c05e6ac8 [ 0.000000] [ te_rate+0x40/0x54) [ 0.000000] r5:c05e6910 r4:c05e6a10 [ 0.000000] [ late_root_clocks+0x40/0x58) [ 0.000000] r5:c05f3c6c r4:c05e68fc [ 0.000000] [ (am33xx_clk_init+0x84/0xa0) [ 0.000000] r5:c05e678c r4:c05e678c [ 0.000000] [ xx_clk_init+0xe0/0x314) [ 0.000000] r5:c086a840 r4:00003517 [ 0.000000] [ 3xx_init_early+0x3c/0x40) [ 0.000000] r7:c06504a4 r6:c06504dc r5:c086a840 r4:c05c3464 [ 0.000000] [ p_arch+0x714/0x804) [ 0.000000] [ el+0x78/0x2dc) [ 0.000000] [ 40) [ 0.000000] r6:c05c48e0 r5:c05d4084 r4:10c53c7d [ 0.000000] ---[ end trace 1b75b31a2719ed1c ]--- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 65024 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 r o rootfstype=ext3 rootwait ip=none [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 256MB = 256MB total [ 0.000000] Memory: 253288k/253288k available, 8856k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc0596000 (5688 kB) [ 0.000000] .init : 0xc0596000 - 0xc05d1000 ( 236 kB) [ 0.000000] .data : 0xc05d2000 - 0xc063aa30 ( 419 kB) [ 0.000000] .bss : 0xc063aa54 - 0xc0669824 ( 188 kB) [ 0.000000] NR_IRQS:396 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup ts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz [ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 13 1071999ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000335] Calibrating delay loop... 298.59 BogoMIPS (lpj=1492992) [ 0.067657] pid_max: default: 32768 minimum: 301 [ 0.067932] Security Framework initialized [ 0.068115] Mount-cache hash table entries: 512 [ 0.068847] CPU: Testing write buffer coherency: ok [ 0.096466] omap_hwmod: gfx: failed to hardreset [ 0.116577] omap_hwmod: pruss: failed to hardreset [ 0.118804] print_constraints: dummy: [ 0.119567] NET: Registered protocol family 16 [ 0.124053] OMAP GPIO hardware version 0.1 [ 0.129913] omap_mux_init: Add partition: #1: core, flags: 0 [ 0.134094] omap_i2c.1: alias fck already exists [ 0.135925] omap2_mcspi.1: alias fck already exists [ 0.136444] omap2_mcspi.2: alias fck already exists [ 0.138610] edma.0: alias fck already exists [ 0.138671] edma.0: alias fck already exists [ 0.138702] edma.0: alias fck already exists [ 0.200408] bio: create slab [ 0.205230] SCSI subsystem initialized [ 0.208801] u***core: registered new interface driver u***fs [ 0.209503] u***core: registered new interface driver hub [ 0.209930] u***core: registered new device driver u*** [ 0.210540] registerd cppi-dma Intr @ IRQ 17 [ 0.210571] Cppi41 Init Done Qmgr-base(d087a000) dma-base(d0878000) [ 0.210571] Cppi41 Init Done [ 0.210632] mu***-ti81xx mu***-ti81xx: mu***0, board_mode=0x13, plat_mode=0x3 [ 0.211242] mu***-ti81xx mu***-ti81xx: mu***1, board_mode=0x13, plat_mode=0x1 [ 0.213714] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz [ 0.216735] tps65910 1-002d: could not be detected [ 0.219757] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.222137] Switching to clocksource gp timer [ 0.257781] mu***-hdrc: version 6.0, ?dma?, otg (peripheral+host) [ 0.258117] mu***-hdrc mu***-hdrc.0: dma type: dma-cppi41 [ 0.258789] MUSB0 controller's USBSS revision = 4ea20800 [ 0.258850] mu***0: Enabled SW babble control [ 0.260894] mu***-hdrc mu***-hdrc.0: USB OTG mode controller at d083c000 using DMA, IRQ 18 [ 0.261199] mu***-hdrc mu***-hdrc.1: dma type: dma-cppi41 [ 0.261871] MUSB1 controller's USBSS revision = 4ea20800 [ 0.261932] mu***1: Enabled SW babble control [ 0.263000] mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver [ 0.263183] mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus numbe r 1 [ 0.263427] u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.263458] u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 0.263488] u*** u***1: Product: MUSB HDRC host driver [ 0.263488] u*** u***1: Manufacturer: Linux 3.2.0 mu***-hcd [ 0.263519] u*** u***1: SerialNumber: mu***-hdrc.1 [ 0.265380] hub 1-0:1.0: USB hub found [ 0.265441] hub 1-0:1.0: 1 port detected [ 0.266693] mu***-hdrc mu***-hdrc.1: USB Host mode controller at d083e800 using DMA, IRQ 19 [ 0.267547] NET: Registered protocol family 2 [ 0.267913] IP route cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.268493] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 0.268859] TCP bind hash table entries: 8192 (order: 3, 32768 bytes) [ 0.269104] TCP: Hash tables configured (established 8192 bind 8192) [ 0.269134] TCP reno registered [ 0.269134] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.269195] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.269653] NET: Registered protocol family 1 [ 0.270141] RPC: Registered named UNIX socket transport module. [ 0.270172] RPC: Registered udp transport module. [ 0.270202] RPC: Registered tcp transport module. [ 0.270233] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.270690] NetWinder Floating Point Emulator V0.97 (double precision) [ 0.290710] VFS: Disk quotas dquot_6.5.2 [ 0.290863] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.291992] msgmni has been set to 494 [ 0.298583] alg: No test for stdrng (krng) [ 0.299896] io scheduler noop registered [ 0.299926] io scheduler deadline registered [ 0.300079] io scheduler cfq registered (default) [ 0.302276] Could not set LED4 to fully on [ 0.305511] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0 [ 1.130126] console [ttyO0] enabled [ 1.135284] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 [ 1.143768] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 [ 1.152099] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3 [ 1.160552] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4 [ 1.168945] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5 [ 1.178314] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00 [ 1.206665] brd: module loaded [ 1.221221] loop: module loaded [ 1.225006] i2c-core: driver [tsl2550] using legacy suspend method [ 1.231567] i2c-core: driver [tsl2550] using legacy resume method [ 1.238220] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write [ 1.302825] No daughter card found [ 1.306549] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write [ 1.372833] The board is a AM335x Starter Kit. [ 1.379028] omap_hsmmc.0: alias fck already exists [ 1.384948] omap_hsmmc.1: alias fck already exists [ 1.392120] _regulator_get: l3_main.0 supply vdd_core not found, using dummy regulator [ 1.400695] am335x_opp_update: physical regulator not present for core(-22) [ 1.408752] registered am33xx_sr device [ 1.416748] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.424468] omap2-nand driver initializing [ 1.429199] OneNAND driver initializing [ 1.436096] CAN device driver interface [ 1.440185] CAN bus driver for Bosch D_CAN controller 1.0 [ 1.492919] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 [ 1.499481] davinci_mdio davinci_mdio.0: detected phy mask fffffffd [ 1.507232] davinci_mdio.0: probed [ 1.510864] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown [ 1.519104] u***core: registered new interface driver zd1201 [ 1.525482] u***core: registered new interface driver cdc_ether [ 1.532043] u***core: registered new interface driver cdc_eem [ 1.538452] u***core: registered new interface driver dm9601 [ 1.544494] cdc_ncm: 04-Aug-2011 [ 1.548278] u***core: registered new interface driver cdc_ncm [ 1.554321] Initializing USB Mass Storage driver... [ 1.559967] u***core: registered new interface driver u***-storage [ 1.566406] USB Mass Storage support registered. [ 1.572265] mousedev: PS/2 mouse device common for all mice [ 1.580444] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0 [ 1.588165] i2c /dev entries driver [ 1.592712] Linux video capture interface: v2.00 [ 1.598358] u***core: registered new interface driver uvcvideo [ 1.604522] USB Video Class driver (1.1.1) [ 1.611877] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 1.618835] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator [ 1.628173] cpuidle: using governor ladder [ 1.633728] cpuidle: using governor menu [ 1.643463] omap4_aes_mod_init: loading AM33X AES driver [ 1.649291] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02 [ 1.656738] omap4_aes_probe: probe() done [ 1.661468] omap4_sham_mod_init: loading AM33X SHA/MD5 driver [ 1.667877] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03 [ 1.692565] omap4_sham_probe: probe() done [ 1.702484] u***core: registered new interface driver u***hid [ 1.708465] u***hid: USB HID core driver [ 1.714385] u***core: registered new interface driver snd-u***-audio [ 1.724761] ALSA device list: [ 1.727905] No soundcards found. [ 1.731536] oprofile: hardware counters not available [ 1.736999] oprofile: using timer interrupt. [ 1.741577] nf_conntrack version 0.5.0 (3957 buckets, 15828 max) [ 1.748931] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.754852] TCP cubic registered [ 1.758300] NET: Registered protocol family 17 [ 1.763092] can: controller area network core (rev 20090105 abi 8) [ 1.769836] NET: Registered protocol family 29 [ 1.774597] can: raw protocol (rev 20090105) [ 1.779113] can: broadcast manager protocol (rev 20090105 t) [ 1.785217] Registering the dns_resolver key type [ 1.790344] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 1.798553] ThumbEE CPU extension supported. [ 1.803222] mux: Failed to setup hwmod io irq -22 [ 1.809570] Power Management for AM33XX family [ 1.814697] Trying to load am335x-pm-firmware.bin (60 secs timeout) [ 1.821594] Copied the M3 firmware to UMEM [ 1.826141] Cortex M3 Firmware Version = 0x181 [ 1.831237] _regulator_get: deviceless supply vdd_core not found, using dummy regulator [ 1.839904] smartreflex smartreflex: am33xx_sr_probe: cannot determine opp [ 1.847259] smartreflex: probe of smartreflex failed with error -22 [ 1.854949] sr_init: platform driver register failed [ 1.867279] clock: disabling unused clocks to save power [ 1.889434] mmc1: new high speed MMC card at address 0001 [ 1.896942] mmcblk0: mmc1:0001 P1XXXX 3.60 GiB [ 1.902313] mmcblk0boot0: mmc1:0001 P1XXXX partition 1 16.0 MiB [ 1.908966] mmcblk0boot1: mmc1:0001 P1XXXX partition 2 16.0 MiB [ 1.918640] mmcblk0: p1 p2 [ 1.927581] mmcblk0boot1: unknown partition table [ 1.936645] mmcblk0boot0: unknown partition table [ 1.950836] Detected MACID=d0:ff:50:b1:33:91 [ 1.957611] cpsw: Detected MACID = d0:ff:50:b1:33:93 [ 1.965087] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) [ 1.979248] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem [ 1.986541] EXT3-fs (mmcblk0p2): write access will be enabled during recovery [ 2.384277] kjournald starting. Commit interval 5 seconds [ 2.390258] EXT3-fs (mmcblk0p2): recovery complete [ 2.399475] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode [ 2.406921] VFS: Mounted root (ext3 filesystem) readonly on device 179:2. [ 2.415161] Freeing init memory: 236K INIT: version 2.88 booting Error opening /dev/fb0: No such device Starting udev Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or d irectory bootlogd. [ 8.546875] EXT3-fs (mmcblk0p2): using internal journal ALSA: Restoring mixer settings... /usr/***in/alsactl: load_state:1686: No soundcards found... Configuring network interfaces... [ 9.592834] PHY 0:00 not found udhcpc (v1.20.2) started Sending discover... Sending discover... Sending discover... No lease, failing done. Tue Jun 25 23:08:00 UTC 2013 INIT: Entering runlevel: 5 Starting system message bus: dbus. Starting telnet daemon. Starting syslogd/klogd: done Starting thttpd. Stopping Bootlog daemon: bootlogd. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyO0 Arago 2013.05 am335x-evm ttyO0 am335x-evm login: root root@am335x-evm:~# udhcpc -i eth1 udhcpc (v1.20.2) started [ 29.021118] net eth1: CPSW phy found : id is : 0x2000a211 Sending discover... [ 31.015197] PHY: 0:01 - Link is Up - 100/Full Sending discover... Sending discover... Sending discover... 还请各位大牛帮帮忙指点一下!不胜感激!!! |
1个回答
秦工客气了,这一版和上一版硬件改动如下: 1、sy***oot的配置有原来的01 00000000 011100和01 00000000 00110,改为01 00000000 011100和01 00000000 01100,默认是01 00000000 011100 MMC1,MMC0,UART0,USB0配置; 2、ETH在上一版中PFBOUT,PFBIN1,PFBIN2在PCB上是没有连起来,后来用飞线连起来,在这一版中PCB上有连起来; 3、使用的是MT47H128M16RT25E,该芯片的Speed Grade为-25E,data rate 为800MHz |
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 18:57 , Processed in 0.556122 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2347
