您好,我正在寻找有关工具引入的XILINXD_LICENSE_FILE变量的信息。
是否有可用的矩阵文件。 以上来自于谷歌翻译 以下为原文 Hello, I'm looking for information on when support of the XILINXD_LICENSE_FILE variable was introduced for tools. Is there a matrix file available. |
4个回答
你好@ steveholzer
我认为它来自ISE 11.x,因为基于证书的许可是从ISE 11.x开始的 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @steveholzer I think it is from ISE 11.x because certificate based licensing had been started from ISE 11.x Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
你好@ steveholzer
我认为它来自ISE 11.x,因为基于证书的许可是从ISE 11.x开始的 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @steveholzer I think it is from ISE 11.x because certificate based licensing had been started from ISE 11.x Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
感谢您的答复。 我能够找到旧版ISE和Vivado版本的发行说明,并能够确认XILINXD_LICENSE_FILE变量在我们环境中可用的版本的使用情况。 问候, 史蒂夫 以上来自于谷歌翻译 以下为原文 Hello Vinay, Thank you for the reply. I was able to locate release notes for older ISE and Vivado versions and was able to confirm the usage of the XILINXD_LICENSE_FILE variable for the versions that we have available in our environment. Regards, Steve |
嗨@ steveholzer,
如果您的查询已得到解决,请通过将“接受为解决方案”标记为导致您解决方案的答案来关闭此主题。 谢谢和问候,Arpan 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @steveholzer, If your query is addressed please close this thread by marking "Accept as solution" to the answer that led you to solution. Thanks and Regards, Arpan Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2178 浏览 7 评论
2616 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2084 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2210 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
446浏览 1评论
1539浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
515浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-11 06:12 , Processed in 1.115113 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
