赛灵思
直播中
彭望琼
7年用户 153经验值
私信 关注
[问答]
Xilinx DCM无法正确模拟来获得16.67MHz时钟
对于我的Spartan 3演示板,我尝试使用Xilinx IP - 架构向导 - 单DCM v9.1i从板载50.0MHz时钟生成16.67MHz时钟。
出于某种原因,我无法模拟该代码来验证我可以通过将50.0MHz除以3来获得16.67MHz时钟。这就是我所拥有的:
库ieee;使用ieee.std_logic_1164.ALL;使用ieee.numeric_std.ALL;库UNISIM;使用UNISIM.Vcomponents.ALL;实体test2是端口(CLKIN_IN:在std_logic中; CLKDV_OUT:输出std_logic; CLKIN_IBUFG_OUT:输出std_logic; CLK0_OUT:输出
std_logic; LOCKED_OUT:out std_logic); end test2; test2的架构BEHAVIORAL是信号CLKDV_BUF:std_logic;
信号CLKFB_IN:std_logic;
信号CLKIN_IBUFG:std_logic;
信号CLK0_BUF:std_logic;
信号GND_BIT:std_logic;开始GND_BIT CLKIN_IBUFG_OUT CLK0_OUT CLKDV_BUFG_INST:BUFG端口映射(I => CLKDV_BUF,O => CLKDV_OUT);
CLKIN_IBUFG_INST:IBUFG端口映射(I => CLKIN_IN,O => CLKIN_IBUFG);
CLK0_BUFG_INST:BUFG端口映射(I => CLK0_BUF,O => CLKFB_IN);
DCM_INST:DCM通用映射(CLK_FEEDBACK =>“1X”,CLKDV_DIVIDE => 3.0,CLKFX_DIVIDE => 1,CLKFX_MULtiPLY => 4,CLKIN_DIVIDE_BY_2 => FALSE,CLKIN_PERIOD => 20.000,CLKOUT_PHASE_SHIFT =>“无”,DESKEW_ADJUST =>“SYSTEM_SYNCHRONOUS
“,DFS_FREQUENCY_MODE =>”LOW“,DLL_FREQUENCY_MODE =>”LOW“,DUTY_CYCLE_CORRECTION => TRUE,FACTORY_JF => x”8080“,PHASE_SHIFT => 0,STARTUP_WAIT => FALSE)端口映射(CLKFB => CLKFB_IN,CLKIN =>
CLKIN_IBUFG,DSSEN => GND_BIT,PSCLK => GND_BIT,PSEN => GND_BIT,PSINCDEC => GND_BIT,RST => GND_BIT,CLKDV => CLKDV_BUF,CLKFX =>开路,CLKFX180 =>开路,CLK0 => CLK0_BUF,CLK2X =>
open,CLK2X180 => open,CLK90 => open,CLK180 => open,CLK270 => open,LOCKED => LOCKED_OUT,PSDONE => open,STATUS => open);
结束行为;
试验台:
库ieee;使用ieee.std_logic_1164.ALL;使用ieee.numeric_std.ALL;库UNISIM;使用UNISIM.Vcomponents.ALL;实体test2_tb是结束test2_tb; test2_tb的体系结构tb是组件test2端口(CLKIN_IN:在std_logic中; CLKDV_OUT:out std_logic
; CLKIN_IBUFG_OUT:out std_logic; CLK0_out:out std_logic; LOCKED_OUT:out std_logic); end component; signal CLKIN_IN,CLKDV_OUT,CLKIN_IBUFG_OUT,CLK0_out,LOCKED_OUT:std_logic; begin U1:test2 port map(CLKIN_IN,CLKDV_OUT,CLKIN_IBUFG_OUT,CLK0_out,LOCKED_OUT)
- ,CLK2X_OUT);进程开始CLKIN_IN等待30 ns;
CLKIN_IN等待30 ns;
结束过程;
结束
当我在modelsim中运行它时,我收到一条错误消息:
在C:/Xilinx92i/vhdl/src/unisims/unisim_VITAL.vhd第6272行处理Determ_clock_delay中的致命错误
不知道发生了什么!!
我在Clock_div输出上没有得到任何东西。
请告诉我这里缺少的东西..
谢谢,
史蒂夫
回帖(1)
李娓仑
2019-8-15 10:13:51
不得不将modelsim分辨率设置为1ps,现在一切正常...... !!
举报
更多回帖
