嗨,
我认为您可以选择在使用coregen向导Block Memory Generator时为BRAM选择初始化值。
查看本指南的第31页-http://www.xilinx.com/support/documentation/user_guides/ug473_7Series_Memory_Resources.pdf
和链接第10页-http://www.xilinx.com/support/documentation/ip_documentation/blk_mem_gen/v8_2/pg058-blk-mem-gen.pdf
祝你好运!
谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi,
I think you have the option to select the initilazation values for the BRAM's when you use coregen wizard Block Memory Generator.
Check Pg 31 of this guide - http://www.xilinx.com/support/documentation/user_guides/ug473_7Series_Memory_Resources.pdf
and Pg 10 of this link - http://www.xilinx.com/support/documentation/ip_documentation/blk_mem_gen/v8_2/pg058-blk-mem-gen.pdf
Good Luck!
Thanks,
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
嗨,
祝你好运!
以上来自于谷歌翻译
以下为原文
Hi,
Good Luck!
Thanks,
Anirudh
举报
