大家好,
我搜索了几个关于初始化BRAM的线程,但我找不到答案。 我使用的是Vivado 2015.4。 我写了一个coe文件,想把coe文件加载到BRAM中。 首先,我添加一个BRAM IP,然后加载coe文件,这一步成功。 第二,我重新重新打包IP,并且警告coe文件不存在。 但该文件确实存在于该文件夹中。 有人可以帮我解决问题吗? 谢谢! 以上来自于谷歌翻译 以下为原文 Hello everyone, I search several threads about initializing BRAM, but I cannot find the answer. I use Vivado 2015.4. I write a coe file and want to load the coe file into BRAM. First, I add a BRAM IP and then load coe file, this step is succeed. second, I re-repackage the IP and there is a warning that the coe file does not exist. But the file really exists at the folder. Can someone help me solve the problem? Thank you! |
3个回答
你好@ zzhcwj1992
看起来BMG IP与IP打包器的打包引起了问题。 打开IP打包程序项目并检查COE文件是否填充在component.xml文件中的“文件组”下。 如果它不存在,请尝试将其添加到文件组部分。 我建议您使用xpm_memory宏而不是BMG IP,您可以在其中提供mem文件作为输入。 请参阅http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug953-vivado-7series-libraries.pdf的第2章。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @zzhcwj1992 It looks like the packaging of the BMG IP with IP packager is causing problem. Open the IP packager project and check if the COE file is populated under "file groups" in component.xml file. If it is not present try adding it to file groups section. I would suggest you to use xpm_memory macro instead of BMG IP where you can provide mem file as input. Refer to chapter-2 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug953-vivado-7series-libraries.pdf Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
你好@ vemulad
我打开“文件组”并选择“合并文件”。 tran50_b.coe有错误,错误是“找不到coe文件”。 以上来自于谷歌翻译 以下为原文 Hi @vemulad I open the "file groups" and choose "merge files". there is an error for tran50_b.coe and the error is "cannot find coe file". |
你好@ zzhcwj1992
在快照中,coe文件在verilog sysnthesis部分中显示两次。 尝试删除这两个文件,并使用右键菜单中的选项手动添加COE文件。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi @zzhcwj1992 Inthe snapshot, the coe file is shown twice in verilog sysnthesis section. Try removing both these files and manually add the COE file using option in right click menu. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
只有小组成员才能发言,加入小组>>
2320 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2366 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
651浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
458浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
218浏览 1评论
666浏览 0评论
1859浏览 0评论
GMT+8, 2024-9-27 18:43 , Processed in 1.079155 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
