英特尔
直播中
陈芮雪
8年用户 227经验值
私信 关注
[问答]
使用DisplayPort NUC8I7HVK4 + ASUS VZ27AQ显示器时随机屏幕消隐
NUC8I7HVK4配备华硕VZ27AQ显示器。
生物:2.2.25
Windows 10 Pro 64位
通过DisplayPort连接
AMD驱动程序版本:24.20.11021.1000
我玩的任何游戏都会让显示器空白几秒钟。
似乎是随机发生的。
似乎与负载无关,因为粉丝在发生时不一定很难。
发生在较旧的游戏中:Divinity:Original Sin Enhanced。
奇点的灰烬 - 升级。
进行故障排除的步骤:
将缩放模式设置为完整面板
在Bios中禁用IGP
使用HDMI播放时不会出现同样的问题。
但是没有freesync作为我的监视器需要DisplayPort才能工作。
将Bios重置为出厂默认值
奇点灰烬中的传感器。
负载onCPU约为20%
GPU处于51摄氏度左右
两个显示适配器的卸载驱动程序,因此显示适配器仅显示:Microsoft Basic Display Adapter
已安装英特尔图形驱动程序
重启电脑
安装Amd diriver。
重启电脑。
还在发生。
接下来是什么?
Foigal
以上来自于谷歌翻译
以下为原文
NUC8I7HVK4 with ASUS VZ27AQ monitor.
Bios: 2.2.25
Windows 10 Pro 64bit
Connected via DisplayPort
AMD Driver version: 24.20.11021.1000
Any game I play I see the monitor blank for a few seconds.
Seems to happen randomly. Doesn;t seem related to load as fans are not necessarily going hard when it happens.
Happens in older game: Divinity: Original Sin Enhanced.
Ashes of Singularity - Escalation.
Step taken to troubleshoot:
Set Scaling Mode to Full Panel
Disabled IGP in Bios
Playing with HDMI doesn't show the same problem. But no freesync as my monitor requires DisplayPort for that to work.
Rest Bios to factory defaults
CHecked sensors during Ashes of Singularity.
Load onCPUs was around 20%
GPU was at around 51 degrees C
Uninstalled drivers for both display adapters so display adapters only showing: Microsoft Basic Display Adapter
Installed Intel Graphics driver
Restarted pc
Install Amd diriver.
Restarted pc.
Still happening.
What next?
Foigal
回帖(10)
汤宇
2018-11-20 11:52:58
您好Foigal,感谢您与社区论坛联系。在这种情况下,我们正在对您遇到的问题进行进一步调查。同时,请向我提供系统支持实用程序将生成的.txt文件。
要附加文件,您必须单击响应框右下角的“附加”选项。我希望尽快收到您的回复.Regards,Diego S.
以上来自于谷歌翻译
以下为原文
Hello Foigal,
Thank you for contacting our community forums.
In this case, we are performing further investigation regarding the issue that you are experiencing.
In the meantime, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the “Attach” option on the bottom right-hand corner of the response box.
I hope to hear from you soon.
Regards,
Diego S.
举报
李玉鑫
2018-11-20 12:12:55
你好迭戈,
这是SSU输出。
弗格斯
SSI.txt.zip
6.5 K.
以上来自于谷歌翻译
以下为原文
Hi Diego,
Here is the SSU output.
Fergus
举报
汤宇
2018-11-20 12:24:37
引用: cd340823 发表于 2018-11-20 13:54
你好迭戈,
这是SSU输出。
弗格斯
您好Foigal,感谢您的回复。根据您的报告,我们希望您执行某些更新。您当前的BIOS是.0037而最新版本是.0049请逐步更新您的BIOS,您可以跳转到.0040
:https://downloadcenter.intel.com/download/27808/BIOS-Update-HNKBLi70-86A-然后转到.0044:https://downloadcenter.intel.com/download/27889/BIOS-Update-HNKBLi70-86A
- 最后到.0049(最新):https://downloadcenter.intel.com/download/28073/BIOS-Update-HNKBLi70-86A-为了更新它,您可以遵循以下任何一种方法:https:// www
.intel.com / content / www / us / en / support / articles / 000005636 / mini-pcs.html同样,为了解决问题,我们需要您卸载系统所具有的当前图形驱动程序(两者都是英特尔®
和Radeon *),直到基本的Microsoft *显示驱动程序暴露(请确保您将在没有Internet访问的情况下执行此操作)之后,为了进行故障排除,请安装最新的Intel®HDGraphics Driver for
Windows®10:https://downloadcenter.intel.com/download/28079/Intel-HD-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUCs-NUC8i7HxKx?product = 126143
要执行此操作,请继续执行此更新步骤:将文件解压缩到指定的位置或文件夹。打开设备管理器:对于Windows 10:右键单击Windows开始图标当提示用户帐户控制权限时,单击是。展开显示
适配器部分。右键单击英特尔®图形条目,然后选择更新驱动程序软件。单击浏览计算机以查找驱动程序软件。单击我从计算机上的设备驱动程序列表中选择。单击“从磁盘安装”。单击“浏览”并选择目录
找到驱动程序文件。单击确定,最后单击下一步。现在正在安装驱动程序。重新启动计算机。完成后,请按照相同的步骤更新适用于Windows®10的Radeon™RX Vega M图形驱动程序:https
://downloadcenter.intel.com/download/28080/Radeon-RX-Vega-M-Graphics-Driver-for-Windows-
10-64位对于Intel-NUCs-NUC8i7HxKx?产品= 126143我希望很快收到您的回复,请告诉我们结果.Regards,Diego S.
以上来自于谷歌翻译
以下为原文
Hello Foigal,
 Thank you for your response.
Based on your report, there are certain updates that we would like you to perform.
Your current BIOS is .0037 while the latest version is .0049
Please update your BIOS gradually, you can jump to .0040:
And then to .0044:
https://downloadcenter.intel.com/download/27889/BIOS-Update-HNKBLi70-86A-
Finally to .0049 (latest):
In order to update it, you can follow any of these methods:
https://www.intel.com/content/www/us/en/support/articles/000005636/mini-pcs.html
As well, In order to isolate the issue we will need you to uninstall the current graphic drivers that your system has (both Intel® and Radeon*), until the basic Microsoft*display driver is exposed (please make sure that you will do it with no internet access)
After that, for troubleshooting purposes please install the latest Intel® HD Graphics Driver for Windows® 10:
https://downloadcenter.intel.com/download/28079/Intel-HD-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUCs-NUC8i7HxKx?product=126143
In order to do it, please go ahead and perform this update steps:
Unzip the file to a designated location or folder.
Open Device Manager:
For Windows 10: Right-click Windows Start icon
Click yes when prompted for permission from User Account Control.
Expand the Display adapters section.
Right-click the Intel® graphics entry and select Update Driver Software.
Click Browse my computer for driver software.
Click Let me pick from a list of device drivers on my computer.
Click Have Disk.
Click Browse and select the directory where the driver files are located.
Click OK, and finally click Next.
Drivers are now being installed.
Restart your computer.
Once that is done, please follow the same steps to update your Radeon™ RX Vega M Graphics Driver for Windows® 10:
https://downloadcenter.intel.com/download/28080/Radeon-RX-Vega-M-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUCs-NUC8i7HxKx?product=126143
I hope to hear from you soon, please let us know the outcome.
Regards,
Diego S.
举报
陈芮雪
2018-11-20 12:34:56
:https://downloadcenter.intel.com/download/27808/BIOS-Update-HNKBLi70-86A-然后转到.0044:https://downloadcenter.intel.com/download/27889/BIOS-Update-HNKBLi70- ...
3个渐进式Bios更新了吗?
不插电的局域网
卸载两个显示驱动程序,以便在设备管理器中显示Microsoft Basic Display Adapter。
已安装从您的链接下载的英特尔驱动程序。
重启电脑
安装了Radeon驱动程序
重启电脑
兰德SSU
附上报告
已经在Ashes of Singularity进行了测试,没有屏幕空白。
我会在几天内继续播放和更新,或者如果我看到更多的屏幕消隐。
SSI2.txt.zip
6.7 K.
以上来自于谷歌翻译
以下为原文
Did the 3 progressive Bios updates.
Unplugged LAN
Uninstalled both display drivers so Microsoft Basic Display Adapter showing in Device Manager.
Installed the Intel Driver downloaded from your link.
Restarted pc
Installed Radeon driver
Restarted pc
Rand SSU
Attached report
Have tested in Ashes of Singularity and no screen blanks.
I will continue playing and update in a few days or if I see more screen blanking.
举报
更多回帖
