引用: jerry1978 发表于 2018-11-1 08:57
请在此线程中附上英特尔®系统支持实用程序将生成的TXT文件:https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
文件已附加。
/比约恩
您好,我终于找到了解决这个问题的方法。
它试图解决DVD和程序的另一个问题。程序员建议我尝试以安全模式启动,然后程序工作。然后我有了尝试蓝光光盘无法工作的想法
在正常模式下,现在可以播放它!许多驱动程序在安全模式下关闭,然后在正常模式下尝试关闭相同的设备。
但它没有帮助。所以必须有别的东西,我首先试图关闭BitDefender防病毒程序。这样做后,它与蓝光光盘一起使用!!!你有时会得到建议试图关闭
故障排除时的防病毒软件。这看起来很长。
它解释了为什么它适用于其他一些计算机和Windows版本。
没有安装BitDefender!
BitDefender在检测到驱动器时在后台启动新设备扫描。
它会以某种方式干扰DVD程序。
停止扫描并且程序正常工作。
因此,您可以将BP60NB10添加到支持的光驱的列表中,并注意无法播放UHD蓝光光盘。
这些信息有点超出范围,但值得一提。
使用最新版本的BIOS(1.0)进行UHD蓝光光盘的背光复制既不可能。
由于一个错误,它可能与早期版本(“UHD友好驱动器”)。
但是LG已经在最新版本的BIOS中对此进行了更正,而驱动器现在是“UHD不友好驱动器”:-(。最好的问候/Björn
以上来自于谷歌翻译
以下为原文
Hello,
I've finally found the solution to this problem. It came when tried to solve another problem with a DVD and a program.
I was advised by the programmers to try to boot in Safe Mode and then the program worked.
Then I got the idea to try a Blu-ray disc that did not work in normal mode and now it was possible to play it!
A number of drivers were turned off in Safe Mode and then tried in normal mode to turn off the same devices. But it did'nt help.
So there must be something else and I first tried to shut down the BitDefender antivirus program.
After doing this, it worked with the Blu-ray Disc !!!
You sometimes get the advice to try to turn off antivirus software when troubleshooting.
Here it seemed quite long-sought.
It explains why it works on some other computers and windows versions. There is no BitDefender installed!
BitDefender launches a new device scan, in the background, when it detects the Drive. It interfere in some way with the DVD program. Stopp the scan and the program works.
So you can add the BP60NB10 to the list of supported Optical Drives with a note that UHD Blu-ray disccan't be played.
This information is a bit outside the scope but it could be worth to mention. It will neither be possible either to make a backcopy of a UHD Blu-ray Disc with the latest version of the BIOS (1.0).
It was possible with earlier versions (was "a UHD friendly Drive") because of a bug. But LG has corrected this in the latest version of BIOS and the Drive is now "a UHD unfriendly Drive" :-(.
Best Regards / Björn
文件已附加。
/比约恩
您好,我终于找到了解决这个问题的方法。
故障排除时的防病毒软件。这看起来很长。
没有安装BitDefender!
它会以某种方式干扰DVD程序。
停止扫描并且程序正常工作。
这些信息有点超出范围,但值得一提。
以上来自于谷歌翻译
以下为原文
Hello,
举报
