详细的时序报告由“trce”程序生成。
如果这样运行,那么这将导致.twr文件(人类可读)和.twx文件。
使用“timingan”工具可以查看时序分析结果(甚至可以生成非常有限的自定义报告)。
当然,这一切都集成在Project Navigator中 - 一旦完成设计,你可以打开交互式计时报告查看器(我不记得菜单中你找到机制的确切位置,但它在列表中
运行地点和路线后可用的选项)。
Avrum
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Detailed timing reports are generated by the "trce" program. If this is run, then this will result in a .twr file (which is human readable) and a .twx file. Timing analysis results can be viewed (and even very limited customized reports can be generated) using the "timingan" tool.
Of course, this is all integrated in to the Project Navigator - you can open the interactive timing report viewer once you have finished implementing the design (I don't remember exactly where in the menus you find the mechanism, but it is in the list of options available after running place and route).
Avrum
View solution in original post
详细的时序报告由“trce”程序生成。
运行地点和路线后可用的选项)。
Avrum
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Avrum
举报
