今天早上我跑了Crystal磁盘标记(CDM)来比较原来的三星魔术师结果和CDM结果都很棒!
所以我重新考虑了三星魔术师的结果,他们也是规格,这是他们比较的方式:
读写
三星规格3500max 1500
CDM 3325 1539
魔术师3282 1535
所以我回到了BIOS,现在它正在使用x4速度8GT / s。
这就是我认为发生的事情。
我在NUC上安装了Windows 10,带有新的驱动器和内存。
此时正在使用Windows NVMe控制器。
然后我下载并运行了三星魔术师基准测试。
第二天早上,我找到并安装了三星NVMe控制器。
我没有重新运行三星魔术师。
在我安装新驱动程序后的第几天,我第一次进入BIOS探索。
我想我取消选中M2盒子以查看会发生什么变化,看看我是否可以选择4个PCIe通道而不是显示的2个,
我意识到它只是一个启用M2复选框,然后我再次重新检查它并退出BIOS而不保存。
我认为这是可能的,因为我在BIOS中的行为,即使我没有保存任何更改,它在重新启动时从2到4通道PCIe重新配置。
你觉得怎么样?
对不起任何混乱,希望我没有对这个模型NUC施加任何阴影,我喜欢它!
以上来自于谷歌翻译
以下为原文
This morning I ran Crystal disk mark (CDM) to compare to the original Samsung magician results and the CDM results were great!
So I reran the Samsung magician results and they were to spec also, here's how they compare:
Read Write
Samsung spec 3500max 1500
CDM 3325 1539
Magician 3282 1535
So I went back into the bios and now it's showing using x4 speed 8GT/s.
Here's what I think happened. I installed Windows 10 on the NUC with new drive and memory. At this time the Windows NVMe controller was being used. Then I downloaded and ran the Samsung magician benchmark.
The next morning I found and installed the Samsung NVMe controller. I did not rerun Samsung magician.
The first time I went into the bios to poke around was days after the new driver was installed. I think I unchecked the M2 box to see what would change, to see if I could choose 4 PCIe lanes vs the 2 shown,
and I realized it was just an enable M2 checkbox, then I rechecked it again and exited the bios without saving.
I think it's possible due to my actions in the bios, even though I didn't save any changes, that it reconfigured on reboot from 2 to 4 lane PCIe.
What do you think happened?
Sorry for any confusion and hopefully I haven't cast any shadows over this model NUC, I love it!
读写
三星规格3500max 1500
CDM 3325 1539
魔术师3282 1535
这就是我认为发生的事情。
然后我下载并运行了三星魔术师基准测试。
我没有重新运行三星魔术师。
你觉得怎么样?
以上来自于谷歌翻译
以下为原文
Read Write
CDM 3325 1539
Magician 3282 1535
举报
