遇到另一个线程中的一些人看到NUC8I7HNK(在NUC8I7HNK上安装ESXi - 失败)的相同问题。
得到相同的错误“关闭固件服务......使用”简单偏移“UEFT RTS映射策略” 似乎BIOS升级修复了NUC的HVK型号上的相同问题,因此想知道英特尔是否正在调查NUC8i7BEH上的问题并计划BIOS更新来解决此问题? 购买NUC,内存和驱动器的目的是安装ESX,就像我在旧的NUC7i7BNH上运行一样,效果很好。 其他人是否看到这个问题? 想听听英特尔的任何人的意见吗? 真的很令人沮丧等待新的NUC出来只是发现ESX无法安装在它上面这是NUC的一个非常常见的用例。 以上来自于谷歌翻译 以下为原文 Running into the same issue that some of the folks in another thread are seeing with the NUC8I7HNK (Installing ESXi on NUC8I7HNK - failing ). Getting the same error “Shutting down firmware services…..Using “simple offset” UEFT RTS mapping policy” It seems that a BIOS upgrade fixed the same problem on the HVK model of that NUC so want to know if Intel is investigating the issue on the NUC8i7BEH and planning a BIOS update to fix this issue? Bought the NUC, memory and drive with the intent of installing ESX as I had on my older NUC7i7BNH which worked great. Are other seeing this issue? Would like to hear from anyone at Intel if this is being looked at? Really frustrating waiting for the new NUC's to come out only to find out that ESX cannot install on it which is a pretty common use case for the NUCs. |
3个回答
HelloRotox,感谢您在英特尔®社区发帖。我可以看到您在NUC中安装ESXi时遇到问题。首先,我想提一下,我们正在调查此问题,以便找到最佳方法
解决它。 但是,在此期间,我想收集一些系统信息,请提供我在NUC中安装的操作系统。 此外,我想知道您要安装的ESXi版本。我希望收到您的回复.Regards,David VIntel客户支持技术人员与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello Rotox, Thank you for posting on the Intel ® communities. I can see that you are experiencing a problem when installing ESXi in the NUC. First, I would like to mention that we are currently looking into this in order to find the best way to address it. However, in the meantime, I would like to gather some information of the system, please provide me with the operating system installed in the NUC. Also, I would like to know the ESXi version you are trying to install. I hope to hear from you. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-15 08:02 嗨大卫, 感谢您的答复。 很高兴知道它正在被关注。 如其他线程中所述,ESXi是我们尝试安装的操作系统。 尝试了6.7和6.5版本,并在使用安装程序启动时收到相同的错误消息。 如果您需要任何其他信息,请与我们联系。 以上来自于谷歌翻译 以下为原文 Hi David, Thanks for your response. Good to know its being looked at. As mentioned in the other thread, ESXi is the operating system that we are trying to install. Have tried both 6.7 and 6.5 versions and received the same error message upon booting with the installer. Let me know if you require any additional information. |
HelloRotox,感谢您的回复。我了解,我会继续对此进行监控,并会在有新内容时尽快通知您。我感谢您的耐心。请注意,David VIntel客户支持技术人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello Rotox, Thank you for your response. I understand, I will continue monitoring this and will let you know whenever there is something new as soon as possible. I appreciate your patience. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation |
只有小组成员才能发言,加入小组>>
397浏览 0评论
GMT+8, 2024-10-11 09:45 , Processed in 0.895582 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
