电子发烧友论坛|
你是指ADS8364的高点供电部分只用个+5V吗?这样的话会限制输入信号的大小。
首先,我们来回答关于ADS8634的HVSS和HVDD是否可以接到5V电压上的问题。
ADS8634是一款高速、低功耗、12位模数转换器(ADC),其供电电压范围为2.0V至5.5V。HVSS和HVDD分别是其高压供电和高压地引脚。根据ADS8634的数据手册,HVDD和HVSS的电压范围为-0.3V至5.5V。因此,将5V电压接到HVDD和HVSS上是可行的。 接下来,我们提供一个关于ADS8634编程实例。 以下是一个使用ADS8634的简单示例,假设我们使用一个微控制器(如STM32)来读取ADC值。我们将使用SPI接口进行通信。 1. 初始化SPI接口和GPIO引脚: ```c SPI_HandleTypeDef hspi1; void MX_SPI1_Init(void) { hspi1.Instance = SPI1; hspi1.Init.Mode = SPI_MODE_MASTER; hspi1.Init.Direction = SPI_DIRECTION_2LINES; hspi1.Init.DataSize = SPI_DATASIZE_8BIT; hspi1.Init.CLKPolarity = SPI_POLARITY_LOW; hspi1.Init.CLKPhase = SPI_PHASE_1EDGE; hspi1.Init.NSS = SPI_NSS_SOFT; hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_16; hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB; hspi1.Init.TIMode = SPI_TIMODE_DISABLE; hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE; hspi1.Init.CRCPolynomial = 10; if (HAL_SPI_Init(&hspi1) != HAL_OK) { Error_Handler(); } } void MX_GPIO_Init(void) { GPIO_InitTypeDef GPIO_InitStruct = {0}; __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); // Configure CS pin as output GPIO_InitStruct.Pin = GPIO_PIN_0; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); // Configure other necessary GPIO pins } ``` 2. 编写读取ADC值的函数: ```c uint16_t ADS8634_ReadADC(void) { uint8_t tx_data[3] = {0x01, 0x00, 0x00}; // Command to read ADC value uint8_t rx_data[3] = {0}; // Set CS low HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_RESET); // Send command and receive ADC value HAL_SPI_TransmitReceive(&hspi1, tx_data, rx_data, 3, HAL_MAX_DELAY); // Set CS high HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_SET); // Convert received data to 12-bit ADC value uint16_t adc_value = (rx_data[1] << 4) | (rx_data[2] >> 4); return adc_value; } ``` 3. 在主函数中调用读取ADC值的函数: ```c int main(void) { HAL_Init(); SystemClock_Config(); MX_GPIO_Init(); MX_SPI1_Init(); while (1) { uint16_t adc_value = ADS8634_ReadADC(); // Process the ADC value } } ``` 这个示例展示了如何使用STM32微控制器通过SPI接口读取ADS8634的ADC值。请注意,您需要根据您的硬件配置和需求对代码进行相应的调整。 |
只有小组成员才能发言,加入小组>>
577 浏览 0 评论
1639 浏览 0 评论
2075 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1530 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1368 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1782浏览 29评论
2810浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1740浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1652浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1668浏览 13评论
/9
GMT+8, 2025-12-9 06:31 , Processed in 0.540749 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
448
