电子发烧友论坛
2个回答
都是标准的C代码,其他平台你直接移植就是了。
PCM3168A是一款四通道模拟输入和输出的音频编解码器,支持I2S和SPI接口。以下是一份基于SPI接口的PCM3168A初始化及应用的使用例程。这个例程假设你已经配置好了SPI接口。
1. 初始化SPI接口: 首先,你需要初始化SPI接口。这通常涉及到设置SPI的时钟速率、CPOL、CPHA等参数。以下是一个示例代码: ```c #include #include static struct spi_device *pcm3168_spi; static int __init pcm3168_init(void) { struct spi_master *master; struct spi_board_info info; int ret; master = spi_busnum_to_master(0); if (!master) { printk(KERN_ERR "PCM3168: No SPI master foundn"); return -ENODEV; } memset(&info, 0, sizeof(info)); info.modalias = "pcm3168"; info.bus_num = 0; info.chip_select = 0; info.max_speed_hz = 1000000; // 1 MHz info.mode = SPI_MODE_0; pcm3168_spi = spi_new_device(master, &info); if (!pcm3168_spi) { printk(KERN_ERR "PCM3168: Failed to add devicen"); return -ENODEV; } ret = spi_setup(pcm3168_spi); if (ret < 0) { printk(KERN_ERR "PCM3168: Failed to setup SPI devicen"); return ret; } return 0; } static void __exit pcm3168_exit(void) { spi_unregister_device(pcm3168_spi); } module_init(pcm3168_init); module_exit(pcm3168_exit); MODULE_LICENSE("GPL"); MODULE_AUTHOR("Your Name"); MODULE_DESCRIPTION("PCM3168A SPI driver"); ``` 2. 初始化PCM3168A: 接下来,你需要初始化PCM3168A。这通常涉及到发送一些初始化命令,以配置音频格式、采样率等参数。以下是一个示例代码: ```c #include #include #define PCM3168_REG_FORMAT_CONTROL 0x00 #define PCM3168_REG_POWER_CONTROL 0x02 #define PCM3168_REG_FILTER_CONTROL 0x04 #define PCM3168_REG_CLOCK_CONTROL 0x06 #define PCM3168_REG_INTERFACE_CONTROL 0x08 #define PCM3168_REG_MISC_CONTROL 0x0A static int pcm3168_write_reg(struct spi_device *spi, u8 reg, u16 value) { u8 buf[3] = {reg, value & 0xFF, (value >> 8) & 0xFF}; return spi_write(spi, buf, sizeof(buf)); } static int pcm3168_init_device(struct spi_device *spi) { int ret; // Set audio format to 24-bit I2S ret = pcm3168_write_reg(spi, PCM3168_REG_FORMAT_CONTROL, 0x0000); if (ret < 0) { return ret; } // Enable all channels ret = pcm3168_write_reg(spi, PCM3168_REG_POWER_CONTROL, 0x0F0F); if (ret < 0) { return ret; } // Configure filter settings ret = pcm3168_write_reg(spi, PCM3168_REG_FILTER_CONTROL, 0x0000); if (ret < 0) { return ret; } // Configure clock settings ret = pcm3168_write_reg(spi, PCM3168_REG_CLOCK_CONTROL, 0x0000); if (ret < 0) { return ret; } // Configure interface settings ret = pcm3168_write_reg(spi, PCM3168_REG_INTERFACE_CONTROL, 0x0000); if (ret < 0) { return ret; } // Configure miscellaneous settings ret = pcm3168_write_reg(spi, PCM3168_REG_MISC_CONTROL, 0x0000); if (ret < 0) { return ret; } return 0; } ``` 3. 配置PCM3168A时隙: PCM3168A的时隙配置取决于你的音频格式和采样率。通常,你需要根据这些参数计算时隙大小。以下是一个示例代码: ```c static int pcm3168_config_tsi(struct spi_device *spi, int sample_rate, int bits_per_sample) { int ret; u16 format_control; // Calculate format control value based on sample rate and bits per sample format_control = (sample_rate == 48000) ? |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 01:20 , Processed in 0.545590 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
514
