大家好,
我目前正在开发一个涉及 TC275 Lite Kit 微控制器的项目,在 GPIO 初始化和 LED 控制代码方面遇到了一些问题。 我试图实现: 1. LED2 闪烁,LED1 关闭。 2. 按下按钮 3. LED1 闪烁,LED2 关闭。 这是我的代码,没有加入闪烁功能: #include "IfxPort.h"#define LED1 MODULE_P00,5#define LED2 MODULE_P00,6#define BUTTON MODULE_P00,7void init_GPIOs(void){ IfxPort_setPinMode(LED1, IfxPort_Mode_outputPushPullGeneral); IfxPort_setPinMode(LED2, IfxPort_Mode_outputPushPullGeneral); IfxPort_setPinMode(BUTTON, IfxPort_Mode_inputPullUp); IfxPort_setPinState(LED1, IfxPort_State_high); // Turn LED1 on IfxPort_setPinState(LED2, IfxPort_State_low); // Turn LED2 off}void control_LED(void){ static int state = 0; // 0 means LED1 is on, LED2 is off. 1 means LED1 is off, LED2 is on. static int buttonPressed = 0; if (IfxPort_getPinState(BUTTON) == 0 buttonPressed == 0) { buttonPressed = 1; // Register the button press // Toggle the state if (state == 0) { IfxPort_setPinState(LED1, IfxPort_State_low); IfxPort_setPinState(LED2, IfxPort_State_high); state = 1; } } if (IfxPort_getPinState(BUTTON) == 1 buttonPressed == 1) { buttonPressed = 0; // Reset the button press }} 我正试图将 LED 灯的闪烁融入其中: #include "IfxPort.h"#include "Bsp.h"#define LED1 MODULE_P00,5#define LED2 MODULE_P00,6#define BUTTON MODULE_P00,7#define WAIT_TIME1 500 // milliseconds#define WAIT_TIME2 300void init_GPIOs(void){ IfxPort_setPinModeOutput(LED1, IfxPort_OutputMode_pushPull, IfxPort_OutputIdx_general); IfxPort_setPinModeOutput(LED2, IfxPort_OutputMode_pushPull, IfxPort_OutputIdx_general); IfxPort_setPinMode(BUTTON, IfxPort_Mode_inputPullUp); IfxPort_setPinState(LED1, IfxPort_State_high); // Turn LED1 on IfxPort_setPinState(LED2, IfxPort_State_low); // Turn LED2 off}void control_LED(void){ static int state = 0; // 0 means LED1 is on, LED2 is off. 1 means LED1 is off, LED2 is on. IfxPort_togglePin(LED1); waitTime(IfxStm_getTicksFromMilliseconds(BSP_DEFAULT_TIMER, WAIT_TIME1)); static int buttonPressed = 0; if (IfxPort_getPinState(BUTTON) == 0 buttonPressed == 0) { buttonPressed = 1; // Register the button press // Toggle the state if (state == 0) { IfxPort_setPinState(LED1, IfxPort_State_low); IfxPort_setPinState(LED2, IfxPort_State_high); state = 1; IfxPort_togglePin(LED2); waitTime(IfxStm_getTicksFromMilliseconds(BSP_DEFAULT_TIMER, WAIT_TIME2)); } } if (IfxPort_getPinState(BUTTON) == 1 buttonPressed == 1) { buttonPressed = 0; // Reset the button press }} 调试时,我收到这些错误: 我试着自己修复错误,但没有成功。 |
1个回答
l); IfxPort_setPinMode(LED2, IfxPort_Mode_outputPushPullGeneral); IfxPort_setPinMode(BUTTON, IfxPort_Mode_inputPullDown); } void ledControl(void) { IfxPort_setPinState(LED1, IfxPort_PinState_low); IfxPort_setPinState(LED2, IfxPort_PinState_high); } void buttonPress(void) { IfxPort_setPinState(LED1, IfxPort_PinState_high); IfxPort_setPinState(LED2, IfxPort_PinState_low); } int main(void) { init_GPIOs(); while(1) { ledControl(); if(IfxPort_getPinState(BUTTON) == IfxPort_PinState_high) { buttonPress(); } } return 0; }
首先,我们需要在代码中添加一个闪烁功能。我们可以通过使用定时器或者循环延时来实现这个功能。这里我将使用循环延时的方法来实现LED的闪烁。 1. 在代码中定义两个全局变量,用于控制LED闪烁的时间和状态: ```c volatile uint32_t led1_blink_time = 0; volatile uint32_t led2_blink_time = 0; ``` 2. 修改`ledControl()`函数,添加LED闪烁功能: ```c void ledControl(void) { static uint8_t led1_state = 0; static uint8_t led2_state = 1; if (led1_blink_time > 0) { led1_blink_time--; if (led1_blink_time == 0) { led1_state = !led1_state; led1_blink_time = 500; // 闪烁间隔时间,单位为ms } } if (led2_blink_time > 0) { led2_blink_time--; if (led2_blink_time == 0) { led2_state = !led2_state; led2_blink_time = 500; // 闪烁间隔时间,单位为ms } } IfxPort_setPinState(LED1, led1_state ? IfxPort_PinState_high : IfxPort_PinState_low); IfxPort_setPinState(LED2, led2_state ? IfxPort_PinState_high : IfxPort_PinState_low); } ``` 3. 修改`buttonPress()`函数,当按下按钮时,切换LED的闪烁状态: ```c void buttonPress(void) { led1_blink_time = 500; // 启动LED1闪烁 led2_blink_time = 0; // 停止LED2闪烁 } ``` 4. 在`main()`函数中,添加一个延时函数,以便在循环中实现延时效果。这里使用一个简单的循环延时: ```c void delay_ms(uint32_t ms) { uint32_t i, j; for (i = 0; i < ms; i++) { for (j = 0; j < 1234; j++); } } ``` 5. 在`main()`函数的循环中,调用`delay_ms()`函数: ```c int main(void) { init_GPIOs(); while(1) { ledControl(); delay_ms(1); // 延时1ms,以便实现闪烁效果 if(IfxPort_getPinState(BUTTON) == IfxPort_PinState_high) { buttonPress(); } } return 0; } ``` 现在,您的代码应该可以实现LED1和LED2的闪烁控制功能,以及按下按钮时切换LED闪烁状态的功能。请注意,这里的延时函数可能不是非常精确,您可以根据需要调整循环次数以实现更精确的延时。 |
只有小组成员才能发言,加入小组>>
TLE9879_BLDC电机启动需要用手拨一下才能转动,怎么解决?
3428 浏览 2 评论
4006 浏览 9 评论
请问TLE5012B_E1000 启动后为什么位置不能正确获取
3492 浏览 9 评论
1140 浏览 8 评论
3420 浏览 7 评论
304浏览 2评论
160浏览 2评论
266浏览 2评论
3436浏览 2评论
如果是打开已有的dave工程,怎么查看这个工程选择的mcu型号?
306浏览 2评论
GMT+8, 2024-9-16 13:33 , Processed in 0.514042 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
