在生成工程时,出现如下错误:
Opening project creator from C:/Users/XXX/ModusToolbox/tools_3.2/project-creator/project-creator.exe Project Creator Status: Project: Hello_World_1 Location: D:/Infineon/03/Hello_World_1 Status: failed Messages: [1]: [INFO] Log file= "C:/Users/XXX/AppData/Local/Temp/device-configurator-cli/device-configurator-cli-20240626.170103.333-14676.log" [2]: [INFO] Command line= "C:/Users/XXX/ModusToolbox/tools_3.2/device-configurator/device-configurator-cli.exe --build D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus --readonly" [3]: [INFO] Log file= "C:/Users/XXX/AppData/Local/Temp/hardware-config-server/hardware-config-server-20240626.170104.542-5352.log" [4]: [INFO] Command line= "C:/Users/XXX/ModusToolbox/tools_3.2/hardware-config-server/hardware-config-server.exe --config D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus" [5]: [INFO] Library paths: "D:/Infineon/03/mtb_shared/mtb-pdl-cat1/release-v3.10.1/props.json;C:/Users/XXX/.modustoolbox/global/device-db/release-v4.16.0/props.json" [6]: Error loading file. The design file was locked by another host. The file is locked by "闂佽法鍠愰弸濠氬箯閻戣姤鏅搁柡鍌樺�栫�氳瀵� [D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus] [7]: Failed to load 'D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus'. [8]: Failed to export the "Hello_World_1" application to Eclipse IDE for ModusToolbox闁筹拷 Unable to import the project: Hello_World_1. Try "Import Existing Application" from the quick-panel. If issues persist, retry project creator. No new/valid projects found. |
1个回答
ModusToolbox™ 3.2 Dashboard工程生成错误的原因可能有以下几点:
1. 权限问题:请确保您有足够的权限访问指定的文件夹和文件。尝试以管理员身份运行ModusToolbox™ 3.2 Dashboard。 2. 路径问题:检查项目路径(D:/Infineon/03/Hello_World_1)是否正确,以及文件夹是否存在。如果路径或文件夹不存在,请创建相应的文件夹或更改路径。 3. 项目名称问题:检查项目名称(Hello_World_1)是否符合命名规范,不包含非法字符或空格。 4. 软件安装问题:确保ModusToolbox™ 3.2已正确安装,所有依赖组件都已安装并更新到最新版本。 5. 系统兼容性问题:检查您的操作系统是否与ModusToolbox™ 3.2兼容。如果存在兼容性问题,请尝试在兼容的操作系统上运行。 6. 项目配置问题:检查项目配置文件(如Makefile、project.yml等)是否正确配置,没有错误或遗漏。 7. 其他潜在问题:如果以上方法都无法解决问题,可能存在其他未知的错误。您可以尝试查看ModusToolbox™ 3.2的日志文件,查找更详细的错误信息,或者联系技术支持寻求帮助。 请按照这些步骤逐一排查问题,找到导致工程生成错误的原因,并进行相应的解决。 |
只有小组成员才能发言,加入小组>>
TLE9879_BLDC电机启动需要用手拨一下才能转动,怎么解决?
2957 浏览 2 评论
3992 浏览 9 评论
请问TLE5012B_E1000 启动后为什么位置不能正确获取
3469 浏览 9 评论
1126 浏览 8 评论
3405 浏览 7 评论
284浏览 2评论
136浏览 2评论
248浏览 2评论
2971浏览 2评论
如果是打开已有的dave工程,怎么查看这个工程选择的mcu型号?
283浏览 2评论
GMT+8, 2024-9-1 07:46 , Processed in 0.575226 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
