examples code:
#include #include #include "sdkconfig.h" #include "esp_log.h" #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "freertos/semphr.h" #include "esp_adc/adc_continuous.h" #define EXAMPLE_ADC_UNIT ADC_UNIT_1 #define _EXAMPLE_ADC_UNIT_STR(unit) #unit #define EXAMPLE_ADC_UNIT_STR(unit) _EXAMPLE_ADC_UNIT_STR(unit) #define EXAMPLE_ADC_CONV_MODE ADC_CONV_SINGLE_UNIT_1 #define EXAMPLE_ADC_ATTEN ADC_ATTEN_DB_0 #define EXAMPLE_ADC_BIT_WIDTH SOC_ADC_DIGI_MAX_BITWIDTH #if CONFIG_IDF_TARGET_ESP32 || CONFIG_IDF_TARGET_ESP32S2 #define EXAMPLE_ADC_OUTPUT_TYPE ADC_DIGI_OUTPUT_FORMAT_TYPE1 #define EXAMPLE_ADC_GET_CHANNEL(p_data) ((p_data)->type1.channel) #define EXAMPLE_ADC_GET_DATA(p_data) ((p_data)->type1.data) #else #define EXAMPLE_ADC_OUTPUT_TYPE ADC_DIGI_OUTPUT_FORMAT_TYPE2 #define EXAMPLE_ADC_GET_CHANNEL(p_data) ((p_data)->type2.channel) #define EXAMPLE_ADC_GET_DATA(p_data) ((p_data)->type2.data) #endif #define EXAMPLE_READ_LEN 256 #if CONFIG_IDF_TARGET_ESP32 static adc_channel_t channel[2] = {ADC_CHANNEL_6, ADC_CHANNEL_7}; #else static adc_channel_t channel[2] = {ADC_CHANNEL_2, ADC_CHANNEL_3}; #endif static TaskHandle_t s_task_handle; static const char *TAG = "EXAMPLE"; static bool IRAM_ATTR s_conv_done_cb(adc_continuous_handle_t handle, const adc_continuous_evt_data_t *edata, void *user_data) { BaseType_t mustYield = pdFALSE; //Notify that ADC continuous driver has done enough number of conversions vTaskNotifyGiveFromISR(s_task_handle, &mustYield); return (mustYield == pdTRUE); } static void continuous_adc_init(adc_channel_t *channel, uint8_t channel_num, adc_continuous_handle_t *out_handle) { adc_continuous_handle_t handle = NULL; adc_continuous_handle_cfg_t adc_config = { .max_store_buf_size = 1024, .conv_frame_size = EXAMPLE_READ_LEN, }; ESP_ERROR_CHECK(adc_continuous_new_handle(&adc_config, &handle)); adc_continuous_config_t dig_cfg = { .sample_freq_hz = 20 * 1000, .conv_mode = EXAMPLE_ADC_CONV_MODE, .format = EXAMPLE_ADC_OUTPUT_TYPE, }; adc_digi_pattern_config_t adc_pattern[SOC_ADC_PATT_LEN_MAX] = {0}; dig_cfg.pattern_num = channel_num; for (int i = 0; i < channel_num; i++) { adc_pattern[i].atten = EXAMPLE_ADC_ATTEN; adc_pattern[i].channel = channel[i] & 0x7; adc_pattern[i].unit = EXAMPLE_ADC_UNIT; adc_pattern[i].bit_width = EXAMPLE_ADC_BIT_WIDTH; ESP_LOGI(TAG, "adc_pattern[%d].atten is :%"PRIx8, i, adc_pattern[i].atten); ESP_LOGI(TAG, "adc_pattern[%d].channel is :%"PRIx8, i, adc_pattern[i].channel); ESP_LOGI(TAG, "adc_pattern[%d].unit is :%"PRIx8, i, adc_pattern[i].unit); } dig_cfg.adc_pattern = adc_pattern; ESP_ERROR_CHECK(adc_continuous_config(handle, &dig_cfg)); *out_handle = handle; } void app_main(void) { esp_err_t ret; uint32_t ret_num = 0; uint8_t result[EXAMPLE_READ_LEN] = {0}; memset(result, 0xcc, EXAMPLE_READ_LEN); s_task_handle = xTaskGetCurrentTaskHandle(); adc_continuous_handle_t handle = NULL; continuous_adc_init(channel, sizeof(channel) / sizeof(adc_channel_t), &handle); adc_continuous_evt_cbs_t cbs = { .on_conv_done = s_conv_done_cb, }; ESP_ERROR_CHECK(adc_continuous_register_event_callbacks(handle, &cbs, NULL)); ESP_ERROR_CHECK(adc_continuous_start(handle)); while(1) { /** * This is to show you the way to use the ADC continuous mode driver event callback. * This `ulTaskNotifyTake` will block when the data processing in the task is fast. * However in this example, the data processing (print) is slow, so you barely block here. * * Without using this event callback (to notify this task), you can still just call * `adc_continuous_read()` here in a loop, with/without a certain block timeout. */ ulTaskNotifyTake(pdTRUE, portMAX_DELAY); char unit[] = EXAMPLE_ADC_UNIT_STR(EXAMPLE_ADC_UNIT); while (1) { ret = adc_continuous_read(handle, result, EXAMPLE_READ_LEN, &ret_num, 0); if (ret == ESP_OK) { ESP_LOGI("TASK", "ret is %x, ret_num is %"PRIu32" bytes", ret, ret_num); for (int i = 0; i < ret_num; i += SOC_ADC_DIGI_RESULT_BYTES) { adc_digi_output_data_t *p = (adc_digi_output_data_t*)&result[i]; uint32_t chan_num = EXAMPLE_ADC_GET_CHANNEL(p); uint32_t data = EXAMPLE_ADC_GET_DATA(p); /* Check the channel number validation, the data is invalid if the channel num exceed the maximum channel */ if (chan_num < SOC_ADC_CHANNEL_NUM(EXAMPLE_ADC_UNIT)) { ESP_LOGI(TAG, "Unit: %s, Channel: %"PRIu32", Value: %"PRIx32, unit, chan_num, data); } else { ESP_LOGW(TAG, "Invalid data [%s_%"PRIu32"_%"PRIx32"]", unit, chan_num, data); } } /** * Because printing is slow, so every time you call `ulTaskNotifyTake`, it will immediately return. * To avoid a task watchdog timeout, add a delay here. When you replace the way you process the data, * usually you don't need this delay (as this task will block for a while). */ vTaskDelay(1); } else if (ret == ESP_ERR_TIMEOUT) { //We try to read `EXAMPLE_READ_LEN` until API returns timeout, which means there's no available data break; } } } ESP_ERROR_CHECK(adc_continuous_stop(handle)); ESP_ERROR_CHECK(adc_continuous_deinit(handle)); } adc1 怎么读取都是 4095 如果通道接地就为0,实在无解求指导 |
1个回答
以下是一些建议和可能的原因:
1. 确保您已经正确初始化了ADC和DMA。在您的代码中,您需要调用`esp_adc_new_ll()`函数来初始化ADC,并使用`esp_dma_new_descriptor()`函数来初始化DMA。 2. 检查您的ADC配置。确保您已经设置了正确的ADC通道、分辨率和采样速率。例如: ```c adc_config_t adc_config = { .adc_num = EXAMPLE_ADC_UNIT, .adc_bits = 12, // 12位分辨率 .adc_atten = 0, // 无衰减 .adc_channel = 0, // ADC通道0 }; ``` 3. 确保您已经正确配置了DMA传输。在您的代码中,您需要设置DMA传输的源地址、目标地址、传输大小和传输模式。例如: ```c dma_descriptor_t *dma_descriptor = malloc(sizeof(dma_descriptor_t)); dma_descriptor_init(dma_descriptor); dma_descriptor_set_src(dma_descriptor, &adc1_io_num); dma_descriptor_set_dst(dma_descriptor, &adc_value, sizeof(adc_value)); dma_descriptor_set_length(dma_descriptor, 1); dma_descriptor_set_size(dma_descriptor, DMA_SIZE_WORD); dma_descriptor_set_burst(dma_descriptor, false); ``` 4. 检查您的ADC读取逻辑。确保您在DMA传输完成后读取ADC值。例如: ```c while (1) { xSemaphoreTake(dma_sem, portMAX_DELAY); uint32_t adc_value = *(uint32_t *)dma_descriptor_get_dst(dma_descriptor); ESP_LOGI("ADC", "ADC value: %d", adc_value); } ``` |
只有小组成员才能发言,加入小组>>
313浏览 6评论
270浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
259浏览 5评论
265浏览 4评论
241浏览 4评论
GMT+8, 2024-6-26 22:58 , Processed in 0.787115 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
