电子发烧友论坛|
本人参考了“gatt_security_server” 和“gatt_server”,还有蓝牙串口程序https://github.com/sideridispas/CERTH_I ... 2_ble_UART,写了一个带有蓝牙串口和普通UUID的蓝牙程序,现在要求对这个蓝牙进行加密,经本人殚精竭虑,仍不得要领。现在只实现了在苹果手机app测试时,第一次点击“连接”,可以正常连接通信,但是,断开程序后,除非在手机蓝牙配置里把该设备给忽略,否则第二次及以后不管是否重启都不能再次连接上。请问如何给两个服务的蓝牙加密?
下文是我的部分代码:Code: Select all tatic char *esp_key_type_to_str(esp_ble_key_type_t key_type){ char *key_str = NULL; switch(key_type) { case ESP_LE_KEY_NONE: key_str = "ESP_LE_KEY_NONE"; break; case ESP_LE_KEY_PENC: key_str = "ESP_LE_KEY_PENC"; break; case ESP_LE_KEY_PID: key_str = "ESP_LE_KEY_PID"; break; case ESP_LE_KEY_PCSRK: key_str = "ESP_LE_KEY_PCSRK"; break; case ESP_LE_KEY_PLK: key_str = "ESP_LE_KEY_PLK"; break; case ESP_LE_KEY_LLK: key_str = "ESP_LE_KEY_LLK"; break; case ESP_LE_KEY_LENC: key_str = "ESP_LE_KEY_LENC"; break; case ESP_LE_KEY_LID: key_str = "ESP_LE_KEY_LID"; break; case ESP_LE_KEY_LCSRK: key_str = "ESP_LE_KEY_LCSRK"; break; default: key_str = "INVALID BLE KEY TYPE"; break; } return key_str;}static void show_bonded_devices(void){ int dev_num = esp_ble_get_bond_device_num(); esp_ble_bond_dev_t *dev_list = (esp_ble_bond_dev_t *)malloc(sizeof(esp_ble_bond_dev_t) * dev_num); esp_ble_get_bond_device_list(&dev_num, dev_list); ESP_LOGI(FLOW_SERVICE, "Bonded devices number : %dn", dev_num); ESP_LOGI(FLOW_SERVICE, "Bonded devices list : %dn", dev_num); for (int i = 0; i < dev_num; i++) { esp_log_buffer_hex(FLOW_SERVICE, (void *)dev_list.bd_addr, sizeof(esp_bd_addr_t)); } free(dev_list);}void gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param) { static uint8_t printf_cnt=0; esp_bd_addr_t bd_addr; printf("%d.adv_config_done= %d , event = %d n",++printf_cnt,adv_config_done,event); switch (event) { /* #ifdef CONFIG_SET_RAW_ADV_DATA case ESP_GAP_BLE_ADV_DATA_RAW_SET_COMPLETE_EVT: adv_config_done &= (~ADV_CONFIG_FLAG); if (adv_config_done == 0){ esp_ble_gap_start_advertising(&ble_adv_params); } break; case ESP_GAP_BLE_SCAN_RSP_DATA_RAW_SET_COMPLETE_EVT: adv_config_done &= (~SCAN_RSP_CONFIG_FLAG); if (adv_config_done == 0){ esp_ble_gap_start_advertising(&ble_adv_params); } break; #else*/ case ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT: adv_config_done &= (~ADV_CONFIG_FLAG); if (adv_config_done == 0){ esp_ble_gap_start_advertising(&ble_adv_params); } break; case ESP_GAP_BLE_SCAN_RSP_DATA_SET_COMPLETE_EVT: adv_config_done &= (~SCAN_RSP_CONFIG_FLAG); if (adv_config_done == 0){ esp_ble_gap_start_advertising(&ble_adv_params); } break; // #endif case ESP_GAP_BLE_ADV_START_COMPLETE_EVT: /* advertising start complete event to indicate advertising start successfully or failed */ if (param->adv_start_cmpl.status != ESP_BT_STATUS_SUCCESS) { ESP_LOGE(FLOW_SERVICE, "advertising start failed"); }else{ // ESP_LOGI(FLOW_SERVICE, "advertising start successfully"); } break; case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT: if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS) { ESP_LOGE(FLOW_SERVICE, "advertising stop failed"); } else { ESP_LOGI(FLOW_SERVICE, "stop adv successfullyn"); } break; case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT://连接完成事件 /* ESP_LOGI(FLOW_SERVICE, "status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d", param->update_conn_params.status, param->update_conn_params.min_int, param->update_conn_params.max_int, param->update_conn_params.conn_int, param->update_conn_params.latency, param->update_conn_params.timeout);*/ break; case ESP_GAP_BLE_AUTH_CMPL_EVT: { memcpy(bd_addr, param->ble_security.auth_cmpl.bd_addr, sizeof(esp_bd_addr_t)); ESP_LOGI(FLOW_SERVICE, "remote BD_ADDR: %08x%04x", (bd_addr[0] << 24) + (bd_addr[1] << 16) + (bd_addr[2] << 8) + bd_addr[3], (bd_addr[4] << 8) + bd_addr[5]); ESP_LOGI(FLOW_SERVICE, "address type = %d", param->ble_security.auth_cmpl.addr_type); ESP_LOGI(FLOW_SERVICE, "pair status = %s",param->ble_security.auth_cmpl.success ? "success" : "fail"); if(!param->ble_security.auth_cmpl.success) { ESP_LOGI(FLOW_SERVICE, "fail reason = 0x%x",param->ble_security.auth_cmpl.fail_reason); is_connected = false; printf("failn"); } else { printf("successn"); is_connected = true; show_bonded_devices(); } break; } case ESP_GAP_BLE_KEY_EVT: //shows the ble key info share with peer device to the user. // esp_bd_addr_t bd_addr1; memcpy(bd_addr, param->ble_security.auth_cmpl.bd_addr, sizeof(esp_bd_addr_t)); ESP_LOGI(FLOW_SERVICE, "remote BD_ADDR: %08x%04x", (bd_addr[0] << 24) + (bd_addr[1] << 16) + (bd_addr[2] << 8) + bd_addr[3], (bd_addr[4] << 8) + bd_addr[5]); ESP_LOGI(FLOW_SERVICE, "address type = %d", param->ble_security.auth_cmpl.addr_type); ESP_LOGI(FLOW_SERVICE, "pair status = %s",param->ble_security.auth_cmpl.success ? "success" : "fail"); if(!param->ble_security.auth_cmpl.success) { ESP_LOGI(FLOW_SERVICE, "fail reason = 0x%x",param->ble_security.auth_cmpl.fail_reason); is_connected = false; printf("failn"); } else { printf("successn"); is_connected = true; //show_bonded_devices(); } show_bonded_devices(); // ESP_LOGI(FLOW_SERVICE, "key type = %s", esp_key_type_to_str(param->ble_security.ble_key.key_type)); break; case ESP_GAP_BLE_PASSKEY_REQ_EVT: /* passkey request event */ //ESP_LOGI(FLOW_SERVICE, "ESP_GAP_BLE_PASSKEY_REQ_EVT"); //esp_ble_passkey_reply(heart_rate_profile_tab[HEART_PROFILE_APP_IDX].remote_bda, true, 0x00); break; case ESP_GAP_BLE_OOB_REQ_EVT: /* OOB request event */ //ESP_LOGI(FLOW_SERVICE, "ESP_GAP_BLE_OOB_REQ_EVT"); break; case ESP_GAP_BLE_LOCAL_IR_EVT: /* BLE local IR event */ //ESP_LOGI(FLOW_SERVICE, "ESP_GAP_BLE_LOCAL_IR_EVT"); break; case ESP_GAP_BLE_LOCAL_ER_EVT: /* BLE local ER event */ // ESP_LOGI(FLOW_SERVICE, "ESP_GAP_BLE_LOCAL_ER_EVT"); break; case ESP_GAP_BLE_NC_REQ_EVT: /* The app will receive this evt when the IO has DisplayYesNO capability and the peer device IO also has DisplayYesNo capability. show the passkey number to the user to confirm it with the number displayed by peer deivce. */ //ESP_LOGI(FLOW_SERVICE, "ESP_GAP_BLE_NC_REQ_EVT, the passkey Notify number:%d", param->ble_security.key_notif.passkey); break; case ESP_GAP_BLE_SEC_REQ_EVT: /* send the positive(true) security response to the peer device to accept the security request. If not accept the security request, should sent the security response with negative(false) accept value*/ esp_ble_gap_security_rsp(param->ble_security.ble_req.bd_addr, true); break; case ESP_GAP_BLE_PASSKEY_NOTIF_EVT: ///the app will receive this evt when the IO has Output capability and the peer device IO has Input capability. ///show the passkey number to the user to input it in the peer deivce. // ESP_LOGI(FLOW_SERVICE, "The passkey Notify number:%d", param->ble_security.key_notif.passkey); break; case ESP_GAP_BLE_REMOVE_BOND_DEV_COMPLETE_EVT: { //ESP_LOGD(FLOW_SERVICE, "ESP_GAP_BLE_REMOVE_BOND_DEV_COMPLETE_EVT status = %d", param->remove_bond_dev_cmpl.status); ESP_LOGI(FLOW_SERVICE, "ESP_GAP_BLE_REMOVE_BOND_DEV"); //ESP_LOGI(FLOW_SERVICE, "-----ESP_GAP_BLE_REMOVE_BOND_DEV----"); esp_log_buffer_hex(FLOW_SERVICE, (void *)param->remove_bond_dev_cmpl.bd_addr, sizeof(esp_bd_addr_t)); //ESP_LOGI(FLOW_SERVICE, "------------------------------------"); break; } case ESP_GAP_BLE_SET_LOCAL_PRIVACY_COMPLETE_EVT: if (param->local_privacy_cmpl.status != ESP_BT_STATUS_SUCCESS){ ESP_LOGE(FLOW_SERVICE, "config local privacy failed, error status = %x", param->local_privacy_cmpl.status); break; } esp_err_t ret = esp_ble_gap_config_adv_data(&ble_uart_adv_data); if (ret){ ESP_LOGE(FLOW_SERVICE, "config adv data failed, error code = %x", ret); }else{ adv_config_done |= ADV_CONFIG_FLAG; } ret = esp_ble_gap_config_adv_data(&flow_sevice_adv_data); if (ret){ ESP_LOGE(FLOW_SERVICE, "config adv data failed, error code = %x", ret); }else{ adv_config_done |= SCAN_RSP_CONFIG_FLAG; } default: break; }}void example_prepare_write_event_env(esp_gatt_if_t gatts_if, prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param){ ESP_LOGI(FLOW_SERVICE, "prepare write, handle = %d, value len = %d", param->write.handle, param->write.len); esp_gatt_status_t status = ESP_GATT_OK; if (prepare_write_env->prepare_buf == NULL) { prepare_write_env->prepare_buf = (uint8_t *)malloc(PREPARE_BUF_MAX_SIZE * sizeof(uint8_t)); prepare_write_env->prepare_len = 0; if (prepare_write_env->prepare_buf == NULL) { ESP_LOGE(FLOW_SERVICE, "%s, gatt_server prep no mem", __func__); status = ESP_GATT_NO_RESOURCES; } } else { if(param->write.offset > PREPARE_BUF_MAX_SIZE) { status = ESP_GATT_INVALID_OFFSET; } else if ((param->write.offset + param->write.len) > PREPARE_BUF_MAX_SIZE) { status = ESP_GATT_INVALID_ATTR_LEN; } } /*send response when param->write.need_rsp is true */ if (param->write.need_rsp){ esp_gatt_rsp_t *gatt_rsp = (esp_gatt_rsp_t *)malloc(sizeof(esp_gatt_rsp_t)); if (gatt_rsp != NULL){ gatt_rsp->attr_value.len = param->write.len; gatt_rsp->attr_value.handle = param->write.handle; gatt_rsp->attr_value.offset = param->write.offset; gatt_rsp->attr_value.auth_req = ESP_GATT_AUTH_REQ_NONE; memcpy(gatt_rsp->attr_value.value, param->write.value, param->write.len); esp_err_t response_err = esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, status, gatt_rsp); if (response_err != ESP_OK){ ESP_LOGE(FLOW_SERVICE, "send response error"); } free(gatt_rsp); }else{ ESP_LOGE(FLOW_SERVICE, "%s, malloc failed", __func__); } } if (status != ESP_GATT_OK){ return; } memcpy(prepare_write_env->prepare_buf + param->write.offset, param->write.value, param->write.len); prepare_write_env->prepare_len += param->write.len;}void example_exec_write_event_env(prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param){ if (param->exec_write.exec_write_flag == ESP_GATT_PREP_WRITE_EXEC && prepare_write_env->prepare_buf){ esp_log_buffer_hex(FLOW_SERVICE, prepare_write_env->prepare_buf, prepare_write_env->prepare_len); }else{ ESP_LOGI(FLOW_SERVICE,"ESP_GATT_PREP_WRITE_CANCEL"); } if (prepare_write_env->prepare_buf) { free(prepare_write_env->prepare_buf); prepare_write_env->prepare_buf = NULL; } prepare_write_env->prepare_len = 0;}static void flow_service_gatts_profile_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param) { if(event!=5) {printf("flowevent = %d n",event);} switch (event) { case ESP_GATTS_REG_EVT: { esp_err_t set_dev_name_ret = esp_ble_gap_set_device_name(BLE_DEVICE_NAME); if (set_dev_name_ret){ ESP_LOGE(FLOW_SERVICE, "set device name failed, error code = %x", set_dev_name_ret); } //config adv data esp_err_t ret = esp_ble_gap_config_adv_data(&flow_sevice_adv_data); ESP_LOGI(BLE_UART_SERVICE, "ble_uart_adv_data"); if (ret){ ESP_LOGE(BLE_UART_SERVICE, "config adv data failed, error code = %x", ret); } adv_config_done |= ADV_CONFIG_FLAG; //config scan response data ret = esp_ble_gap_config_adv_data(&ble_uart_adv_data); // ESP_LOGI(FLOW_SERVICE, "flow_sevice_adv_data"); if (ret){ ESP_LOGE(FLOW_SERVICE, "config scan response data failed, error code = %x", ret); } adv_config_done |= SCAN_RSP_CONFIG_FLAG; esp_ble_gap_config_local_privacy(true); esp_err_t create_attr_ret = esp_ble_gatts_create_attr_tab(flow_service_gatt_db, gatts_if, HRS_IDX_NB, SVC_INST_ID); if (create_attr_ret){ ESP_LOGE(FLOW_SERVICE, "create attr table failed, error code = %x", create_attr_ret); } } break; case ESP_GATTS_READ_EVT: // ESP_LOGI(FLOW_SERVICE, "---ESP_GATTS_READ_EVT"); break; case ESP_GATTS_WRITE_EVT: break; case ESP_GATTS_EXEC_WRITE_EVT: // ESP_LOGI(FLOW_SERVICE, "ESP_GATTS_EXEC_WRITE_EVT"); example_exec_write_event_env(&prepare_write_env, param); break; case ESP_GATTS_MTU_EVT: //ESP_LOGI(FLOW_SERVICE,"ESP_GATTS_MTU_EVT"); // ESP_LOGI(FLOW_SERVICE, "ESP_GATTS_MTU_EVT, MTU %d", param->mtu.mtu); break; case ESP_GATTS_CONF_EVT: // ESP_LOGI(FLOW_SERVICE, "ESP_GATTS_CONF_EVT, status = %d", param->conf.status); break; case ESP_GATTS_START_EVT: // ESP_LOGI(FLOW_SERVICE, "SERVICE_START_EVT, status %d, service_handle %d", param->start.status, param->start.service_handle); break; case ESP_GATTS_CONNECT_EVT: esp_ble_set_encryption(param->connect.remote_bda, ESP_BLE_SEC_ENCRYPT_MITM); break; case ESP_GATTS_DISCONNECT_EVT: is_connected = false; esp_ble_gatts_stop_service(flow_handle_table[SMART_FLOW_SVC]); //ESP_LOGI(FLOW_SERVICE, "ESP_GATTS_DISCONNECT_EVT, reason = %d", param->disconnect.reason); // esp_ble_gap_start_advertising(&ble_adv_params); /* esp_err_t set_dev_name_ret = esp_ble_gap_set_device_name(BLE_DEVICE_NAME); if (set_dev_name_ret){ ESP_LOGE(FLOW_SERVICE, "set device name failed, error code = %x", set_dev_name_ret); }*/ //config adv data esp_err_t ret = esp_ble_gap_config_adv_data(&flow_sevice_adv_data); ESP_LOGI(BLE_UART_SERVICE, "ble_uart_adv_data"); if (ret){ ESP_LOGE(BLE_UART_SERVICE, "config adv data failed, error code = %x", ret); } adv_config_done |= ADV_CONFIG_FLAG; //config scan response data ret = esp_ble_gap_config_adv_data(&ble_uart_adv_data); // ESP_LOGI(FLOW_SERVICE, "flow_sevice_adv_data"); if (ret){ ESP_LOGE(FLOW_SERVICE, "config scan response data failed, error code = %x", ret); } adv_config_done |= SCAN_RSP_CONFIG_FLAG; esp_ble_gap_config_local_privacy(true); esp_err_t create_attr_ret = esp_ble_gatts_create_attr_tab(flow_service_gatt_db, gatts_if, HRS_IDX_NB, SVC_INST_ID); if (create_attr_ret){ ESP_LOGE(FLOW_SERVICE, "create attr table failed, error code = %x", create_attr_ret); } break; case ESP_GATTS_CREAT_ATTR_TAB_EVT:{ //ESP_LOGI(FLOW_SERVICE,"ESP_GATTS_CREAT_ATTR_TAB_EVT"); if (param->add_attr_tab.status != ESP_GATT_OK){ ESP_LOGE(FLOW_SERVICE, "create attribute table failed, error code=0x%x", param->add_attr_tab.status); } else if (param->add_attr_tab.num_handle != HRS_IDX_NB){ ESP_LOGE(FLOW_SERVICE, "create attribute table abnormally, num_handle (%d) doesn't equal to HRS_IDX_NB(%d)", param->add_attr_tab.num_handle, HRS_IDX_NB); } else { // ESP_LOGI(FLOW_SERVICE, "create attribute table successfully, the number handle = %dn",param->add_attr_tab.num_handle); memcpy(flow_handle_table, param->add_attr_tab.handles, sizeof(flow_handle_table)); esp_ble_gatts_start_service(flow_handle_table[SMART_FLOW_SVC]); } break; } case ESP_GATTS_STOP_EVT:break; case ESP_GATTS_OPEN_EVT:break; case ESP_GATTS_CANCEL_OPEN_EVT:break; case ESP_GATTS_CLOSE_EVT:break; case ESP_GATTS_LISTEN_EVT:break; case ESP_GATTS_CONGEST_EVT:break; case ESP_GATTS_UNREG_EVT:break; case ESP_GATTS_DELETE_EVT:break; default: break; }}void ble_uart_gatts_profile_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param) { esp_err_t ret; printf("ble_uart_event = %d n",event); switch (event) { case ESP_GATTS_REG_EVT: // ESP_LOGI(BLE_UART_SERVICE, "REGISTER_APP_EVT, status %d, app_id %d", param->reg.status, param->reg.app_id); gl_profile_tab[BLE_UART_SERCIVE_ID].service_id.is_primary = true; gl_profile_tab[BLE_UART_SERCIVE_ID].service_id.id.inst_id = 0x00; gl_profile_tab[BLE_UART_SERCIVE_ID].service_id.id.uuid.len = ESP_UUID_LEN_128; for (uint8_t pos=0;posread.conn_id, param->read.trans_id, param->read.handle); gatts_check_callback(event, gatts_if, param); break; } case ESP_GATTS_WRITE_EVT: { // ESP_LOGI(BLE_UART_SERVICE, "GATT_WRITE_EVT, conn_id %d, trans_id %d, handle %dn", param->write.conn_id, param->write.trans_id, param->write.handle); // ESP_LOGI(BLE_UART_SERVICE, "GATT_WRITE_EVT, value len %d, value %08xn", param->write.len, *(uint32_t *)param->write.value);// esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, ESP_GATT_OK, NULL); gatts_check_callback(event, gatts_if, param); break; } case ESP_GATTS_EXEC_WRITE_EVT: break; case ESP_GATTS_MTU_EVT: //ESP_LOGI(BLE_UART_SERVICE,"ESP_GATTS_MTU_EVT"); //ESP_LOGI(BLE_UART_SERVICE, "ESP_GATTS_MTU_EVT, MTU %d", param->mtu.mtu); break; case ESP_GATTS_CONF_EVT: break; case ESP_GATTS_UNREG_EVT: break; case ESP_GATTS_CREATE_EVT: //ESP_LOGI(BLE_UART_SERVICE, "1-CREATE_SERVICE_EVT, status %d, service_handle %dn", param->create.status, param->create.service_handle); gl_profile_tab[BLE_UART_SERCIVE_ID].service_handle = param->create.service_handle; gl_profile_tab[BLE_UART_SERCIVE_ID].char_uuid.len = ble_uart_char[0].char_uuid.len; gl_profile_tab[BLE_UART_SERCIVE_ID].char_uuid.uuid.uuid16 = ble_uart_char[0].char_uuid.uuid.uuid16; esp_ble_gatts_start_service(gl_profile_tab[BLE_UART_SERCIVE_ID].service_handle); gatts_add_char(); break; case ESP_GATTS_ADD_INCL_SRVC_EVT: break; case ESP_GATTS_ADD_CHAR_EVT: { // ESP_LOGI(BLE_UART_SERVICE, "ADD_CHAR_EVT, status 0x%X, attr_handle %d, service_handle %dn", // param->add_char.status, param->add_char.attr_handle, param->add_char.service_handle); gl_profile_tab[BLE_UART_SERCIVE_ID].char_handle = param->add_char.attr_handle; if (param->add_char.status==ESP_GATT_OK) { gatts_check_add_char(param->add_char.char_uuid,param->add_char.attr_handle); } break; } case ESP_GATTS_ADD_CHAR_DESCR_EVT: //ESP_LOGI(BLE_UART_SERVICE, "ADD_DESCR_EVT char, status %d, attr_handle %d, service_handle %dn", // param->add_char.status, param->add_char.attr_handle, param->add_char.service_handle); // ESP_LOGI(BLE_UART_SERVICE, "ADD_DESCR_EVT desc, status %d, attr_handle %d, service_handle %dn", // param->add_char_descr.status, param->add_char_descr.attr_handle, param->add_char_descr.service_handle); if (param->add_char_descr.status==ESP_GATT_OK) { gatts_check_add_descr(param->add_char.char_uuid,param->add_char.attr_handle); } break; case ESP_GATTS_DELETE_EVT: break; case ESP_GATTS_START_EVT: //ESP_LOGI(BLE_UART_SERVICE, "SERVICE_START_EVT, status %d, service_handle %dn", // param->start.status, param->start.service_handle); break; case ESP_GATTS_STOP_EVT: break; case ESP_GATTS_CONNECT_EVT: esp_ble_set_encryption(param->connect.remote_bda, ESP_BLE_SEC_ENCRYPT_MITM); /*ESP_LOGI(BLE_UART_SERVICE, "SERVICE_START_EVT, conn_id %d, remote %02x:%02x:%02x:%02x:%02x:%02x: n", param->connect.conn_id, param->connect.remote_bda[0], param->connect.remote_bda[1], param->connect.remote_bda[2], param->connect.remote_bda[3], param->connect.remote_bda[4], param->connect.remote_bda[5]);*/ //gl_profile_tab[BLE_UART_SERCIVE_ID].conn_id = param->connect.conn_id; // esp_ble_set_encryption(param->connect.remote_bda, ESP_BLE_SEC_ENCRYPT_MITM); break; case ESP_GATTS_DISCONNECT_EVT: is_connected = false; esp_ble_gatts_stop_service(gl_profile_tab[BLE_UART_SERCIVE_ID].service_handle); esp_ble_gap_start_advertising(&ble_adv_params); gl_profile_tab[BLE_UART_SERCIVE_ID].service_id.is_primary = true; gl_profile_tab[BLE_UART_SERCIVE_ID].service_id.id.inst_id = 0x00; gl_profile_tab[BLE_UART_SERCIVE_ID].service_id.id.uuid.len = ESP_UUID_LEN_128; for (uint8_t pos=0;posreg.status == ESP_GATT_OK) { gl_profile_tab[param->reg.app_id].gatts_if = gatts_if; } else { ESP_LOGI(BLE_UART_SERVICE, "Reg app failed, app_id %04x, status %dn", param->reg.app_id, param->reg.status); return; } } do { int idx; for (idx = 0; idx < PROFILE_NUM; idx++) { if (gatts_if == ESP_GATT_IF_NONE || /* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */ gatts_if == gl_profile_tab[idx].gatts_if) { if (gl_profile_tab[idx].gatts_cb) { gl_profile_tab[idx].gatts_cb(event, gatts_if, param); } } } } while (0);}void main_app(){ esp_err_t ret; ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT)); esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT(); ret = esp_bt_controller_init(&bt_cfg); if (ret) { ESP_LOGE(BLE_UART_SERVICE, "%s init controller failed: %s", __func__, esp_err_to_name(ret)); return; } ret = esp_bt_controller_enable(ESP_BT_MODE_BLE); /* esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT(); ret = esp_bt_controller_init(&bt_cfg);/// if (ret) { ESP_LOGE(BLE_UART_SERVICE, "%s initialize controller failedn", __func__); return; } ret = esp_bt_controller_enable(ESP_BT_MODE_BTDM); if (ret) { ESP_LOGE(BLE_UART_SERVICE, "%s enable controller failedn", __func__); return; }*/ ret = esp_bluedroid_init(); if (ret) { ESP_LOGE(BLE_UART_SERVICE, "%s init bluetooth failedn", __func__); return; } ret = esp_bluedroid_enable(); if (ret) { ESP_LOGE(BLE_UART_SERVICE, "%s enable bluetooth failedn", __func__); return; } ret = esp_ble_gatt_set_local_mtu(500); if (ret){ ESP_LOGE(BLE_UART_SERVICE, "set local MTU failed, error code = %x", ret); } esp_ble_gatts_register_callback(gatts_event_handler); esp_ble_gap_register_callback(gap_event_handler); esp_ble_gatts_app_register(PROFILE_FLOW_SERVICE_ID); esp_ble_gatts_app_register(BLE_UART_SERCIVE_ID); /* set the security iocap & auth_req & key size & init key response key parameters to the stack*/ esp_ble_auth_req_t auth_req = ESP_LE_AUTH_BOND; //bonding with peer device after authentication esp_ble_io_cap_t iocap = ESP_IO_CAP_NONE; //set the IO capability to No output No input uint8_t key_size = 8; //the key size should be 7~16 bytes uint8_t init_key = ESP_BLE_ENC_KEY_MASK | ESP_BLE_ID_KEY_MASK; uint8_t rsp_key = ESP_BLE_ENC_KEY_MASK | ESP_BLE_ID_KEY_MASK; esp_ble_gap_set_security_param(ESP_BLE_SM_AUTHEN_REQ_MODE, &auth_req, sizeof(uint8_t)); esp_ble_gap_set_security_param(ESP_BLE_SM_IOCAP_MODE, &iocap, sizeof(uint8_t)); esp_ble_gap_set_security_param(ESP_BLE_SM_MAX_KEY_SIZE, &key_size, sizeof(uint8_t)); /* If your BLE device act as a Slave, the init_key means you hope which types of key of the master should distribut to you, and the response key means which key you can distribut to the Master; If your BLE device act as a master, the response key means you hope which types of key of the slave should distribut to you, and the init key means which key you can distribut to the slave. */ esp_ble_gap_set_security_param(ESP_BLE_SM_SET_INIT_KEY, &init_key, sizeof(uint8_t)); esp_ble_gap_set_security_param(ESP_BLE_SM_SET_RSP_KEY, &rsp_key, sizeof(uint8_t)); } 其中,配置文件 static struct gatts_profile_inst gl_profile_tab[PROFILE_NUM] = { [PROFILE_FLOW_SERVICE_ID] = { .gatts_cb = flow_service_gatts_profile_event_handler, .gatts_if = ESP_GATT_IF_NONE, /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */ }, [BLE_UART_SERCIVE_ID] = { .gatts_cb = ble_uart_gatts_profile_event_handler, /* This demo does not implement, similar as profile A */ .gatts_if = ESP_GATT_IF_NONE, /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */ }, }; 串口配置如下Code: Select all static struct gatts_char_inst ble_uart_char[GATTS_CHAR_NUM] = { { .char_uuid.len = ESP_UUID_LEN_128, // RX .char_uuid.uuid.uuid128 = { 0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x02, 0x00, 0x40, 0x6E }, .char_perm = ESP_GATT_PERM_WRITE_ENCRYPTED|ESP_GATT_PERM_READ_ENCRYPTED,//ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, .char_property = ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_NOTIFY, .char_val = &RX_gatts_demo_char_val, .char_control = NULL, .char_handle = 0, .char_read_callback=RX_char_read_handler, .char_write_callback=RX_char_write_handler, //.descr_uuid.len = ESP_UUID_LEN_16, //.descr_uuid.uuid.uuid16 = ESP_GATT_UUID_CHAR_CLIENT_CONFIG,//2902 //.descr_perm=ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, //.descr_val = NULL,//&RX_gatts_demo_descr_val, //.descr_control=NULL, //.descr_handle=0, //.descr_read_callback=RX_descr_read_handler, //.descr_write_callback=RX_descr_write_handler }, { .char_uuid.len = ESP_UUID_LEN_128, // TX .char_uuid.uuid.uuid128 = { 0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x03, 0x00, 0x40, 0x6E }, .char_perm = ESP_GATT_PERM_WRITE_ENCRYPTED|ESP_GATT_PERM_READ_ENCRYPTED,//ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, .char_property = ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_NOTIFY, .char_val = &TX_gatts_demo_char_val, .char_control=NULL, .char_handle=0, .char_read_callback=TX_char_read_handler, .char_write_callback=TX_char_write_handler, /*.descr_uuid.len = ESP_UUID_LEN_16, .descr_uuid.uuid.uuid16 = ESP_GATT_UUID_CHAR_CLIENT_CONFIG, // ESP_GATT_UUID_CHAR_DESCRIPTION, .descr_perm=ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, .descr_val = NULL,//&TX_gatts_demo_descr_val, .descr_control=NULL, .descr_handle=0,*/ //.descr_read_callback=TX_descr_read_handler, //.descr_write_callback=TX_descr_write_handler }}; 另一个服务配置如下Code: Select all /* Full Database Description - Used to add attributes into the database */static const esp_gatts_attr_db_t flow_service_gatt_db[HRS_IDX_NB] ={ // Service Declaration服务声明 [SMART_FLOW_SVC] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ, sizeof(uint16_t), sizeof(SMART_FLOW_UUID), (uint8_t *)&SMART_FLOW_UUID}}, /* Characteristic Declaration *///特征值声明 [HEATER_CHAR_A] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ, sizeof(heater_temperature), sizeof(heater_temperature), (uint8_t *)&char_prop_read_notify_broadcast}}, /* Characteristic Value */ [HEATER_VALUE_A] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&FLOW_VALUE_UUID, ESP_GATT_PERM_WRITE_ENCRYPTED|ESP_GATT_PERM_READ_ENCRYPTED,//ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, sizeof(heater_temperature), sizeof(heater_temperature), (uint8_t *)&heater_temperature}}, /* Characteristic Declaration */ [FLOW_CHAR_B] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, sizeof(flow_value), sizeof(flow_value), (uint8_t *)&char_prop_read_notify_broadcast}}, /* Characteristic Value */ [FLOW_VALUE_B] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&HEATER_TEM_UUID, ESP_GATT_PERM_WRITE_ENCRYPTED|ESP_GATT_PERM_READ_ENCRYPTED,//ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, sizeof(flow_value), sizeof(flow_value), (uint8_t *)&flow_value}}, /* Characteristic Declaration */ [BATTERY_CHAR_C] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, sizeof(battery_value), sizeof(battery_value), (uint8_t *)&char_prop_read_notify_broadcast}}, /* Characteristic Value */ [BATTERY_VALUE_C] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&BATTARY_UUID, ESP_GATT_PERM_WRITE_ENCRYPTED|ESP_GATT_PERM_READ_ENCRYPTED,//ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE, sizeof(battery_value), sizeof(battery_value), (uint8_t *)&battery_value}},}; 不加密时,运行良好,现在要求连接通信过程进行加密,请问有什么方法? 出现的问题是,第一次连接时设备可以加密,如gatt_security_server一样,但断线重连之后就连接不上了。用nrf connect 连接也是一样。谢谢大家。 |
1个回答
为了实现蓝牙加密,您需要使用蓝牙安全协议,如配对和加密。以下是一些建议和步骤,帮助您实现蓝牙加密:
1. 确保您的设备支持蓝牙安全功能。这通常在设备的蓝牙配置文件中定义。 2. 在您的代码中,首先需要实现配对过程。配对是建立安全连接的第一步。您可以使用ESP32的`esp_ble_gap_set_security_param`函数来设置配对参数。 3. 在配对过程中,您需要设置PIN码。这可以通过`esp_ble_gap_set_pin`函数实现。您可以设置一个固定PIN码或使用随机PIN码。 4. 在配对成功后,您可以使用`esp_ble_set_encryption`函数来设置加密参数。这将确保数据传输过程中的安全性。 5. 在您的代码中,实现一个回调函数来处理配对和加密事件。这将帮助您在配对和加密过程中获取状态信息。 6. 在您的应用程序中,确保在连接设备之前检查设备是否已配对和加密。如果设备未配对或未加密,您可以提示用户进行配对和加密。 7. 对于您提到的连接问题,可能是因为设备在配对后没有正确保存配对信息。您需要确保在配对成功后,使用`esp_ble_gap_config_local_icon`函数来保存配对信息。 以下是一个简单的示例代码,展示了如何设置配对和加密参数: ```c #include "esp_bt.h" #include "esp_gap_ble_api.h" #include "esp_ble_gap.h" void app_main() { // 初始化蓝牙 esp_bt_controller_init(); esp_bt_controller_enable(ESP_BT_MODE_BTDM); // 设置配对参数 esp_ble_gap_set_security_param(ESP_BLE_SM_AUTHEN_REQ_MODE, ESP_BLE_SM_AUTHEN_REQ_BOND, 0); esp_ble_gap_set_security_param(ESP_BLE_SM_IOCAP_MODE, ESP_BLE_IO_CAP_OUT, 0); esp_ble_gap_set_security_param(ESP_BLE_SM_MAX_KEY_SIZE, 16, 0); // 设置PIN码 esp_ble_gap_set_pin(ESP_BLE_PIN_TYPE_VARIABLE, "123456", 6, 0); // 设置加密参数 esp_ble_set_encryption(ESP_BLE_SEC_ENCRYPT_MITM, 0); // 其他初始化代码... } ``` 请注意,这只是一个示例,您需要根据您的具体需求和设备进行调整。希望这些建议能帮助您实现蓝牙加密。 |
只有小组成员才能发言,加入小组>>
472 浏览 0 评论
998 浏览 0 评论
1713 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1370 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1289浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2390浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2581浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-15 09:48 , Processed in 0.676441 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2802
