使用AT2.4版本编译,启用CONFIG_AT_DRIVER_COMMAND_SUPPORT编译下载后,发送命令AT+DRVADC=0,0正常响应,发送命令AT+DRVPWMINIT=10000,10,17没有正确回复,回复值为ready
AT+DRVPWMINIT=100 [11:10:10.617]收←◆� 启动打印信息: ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:6276 load:0x40078000,len:16216 load:0x40080400,len:3632 entry 0x40080664 [0;32mI (27) boot: ESP-IDF v4.3.2-553-g588436db47 2nd stage bootloader[0m [0;32mI (27) boot: compile time 09:55:26[0m [0;32mI (27) boot: chip revision: 1[0m [0;32mI (31) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m [0;32mI (38) boot.esp32: SPI Speed : 40MHz[0m [0;32mI (43) boot.esp32: SPI Mode : DIO[0m [0;32mI (47) boot.esp32: SPI Flash Size : 4MB[0m [0;32mI (52) boot: Enabling RNG early entropy source...[0m [0;32mI (57) boot: Partition Table:[0m [0;32mI (61) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (68) boot: 0 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (76) boot: 1 otadata OTA data 01 00 00010000 00002000[0m [0;32mI (83) boot: 2 nvs WiFi data 01 02 00012000 0000e000[0m [0;32mI (90) boot: 3 at_customize unknown 40 00 00020000 000e0000[0m [0;32mI (98) boot: 4 ota_0 OTA app 00 10 00100000 00180000[0m [0;32mI (105) boot: 5 ota_1 OTA app 00 11 00280000 00180000[0m [0;32mI (113) boot: End of partition table[0m [0;32mI (117) boot_comm: chip revision: 1, min. application chip revision: 0[0m [0;32mI (124) esp_image: segment 0: paddr=00100020 vaddr=3f400020 size=1e6a8h (124584) map[0m [0;32mI (178) esp_image: segment 1: paddr=0011e6d0 vaddr=3ffbdb60 size=01948h ( 6472) load[0m [0;32mI (181) esp_image: segment 2: paddr=00120020 vaddr=400d0020 size=1103e4h (1115108) map[0m [0;32mI (587) esp_image: segment 3: paddr=0023040c vaddr=3ffbf4a8 size=02318h ( 8984) load[0m [0;32mI (591) esp_image: segment 4: paddr=0023272c vaddr=40080000 size=1dfe4h (122852) load[0m [0;32mI (644) esp_image: segment 5: paddr=00250718 vaddr=400c0000 size=00064h ( 100) load[0m [0;32mI (644) esp_image: segment 6: paddr=00250784 vaddr=50000000 size=00010h ( 16) load[0m [0;32mI (664) boot: Loaded app from partition at offset 0x100000[0m [0;32mI (664) boot: Disabling RNG early entropy source...[0m no external 32k oscillator, disable it now. module_name:WROOM-32 max tx power=78,ret=0 2.4.1 AT命令发送: AT+RST ATE1 AT+DRVPWMINIT=10000,10,17 AT+DRVPWMINIT=10000,10,17 AT+DRVPWMINIT=10000,10,17 AT命令响应: ready AT OK AT+RST OK ready AT+DRVPWMINIT=100 [11:10:10.617]收←◆� |
1个回答
以下是可能的原因和解决方案:
1. 命令格式错误:请确保您发送的AT命令格式正确。对于AT+DRVPWMINIT命令,正确的格式应该是:AT+DRVPWMINIT=,,。根据您的描述,命令应该是:AT+DRVPWMINIT=0,10000,10,17。 2. 参数值超出范围:请检查您提供的参数值是否在允许的范围内。例如,PWM_ID、频率和占空比可能需要满足特定的条件。 3. 驱动支持问题:确保您的硬件平台支持所需的驱动功能。如果硬件平台不支持,您可能需要修改硬件或使用其他驱动。 4. 固件问题:可能是固件中存在bug或配置错误。您可以尝试更新固件或检查配置选项。 5. 串口通信问题:请检查您的串口通信设置,确保波特率、数据位、停止位和奇偶校验位设置正确。 6. 日志信息分析:从您提供的日志信息来看,设备在2016年6月8日进行了重置,并且使用了SPI快速闪存引导。这可能表明设备在启动过程中存在问题。您可以进一步分析日志信息,查找可能的问题原因。 |
只有小组成员才能发言,加入小组>>
474浏览 6评论
398浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
378浏览 5评论
384浏览 4评论
354浏览 4评论
GMT+8, 2024-9-29 06:36 , Processed in 0.697312 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
