电子发烧友论坛|
我用IIC写东西,仅仅是写,读都不要,初始化的时候直接写,却一开始就总线忙(风驰里面的IIC代码),具体如下:
<1>main /*************/ (大概就是这意思,工程太大,我把主要涉及的搬上来) {INIT_TAS5756();} <2> void INIT_TAS5756(void) //初始化从器件 { I2C_MASTERMODE_Init(STANDARDSPEED); //初始化IIC u8NumOfReg = sizeof(tas5756_LR_init)/sizeof(Struct_Tas5756); for(i=0;ivoid I2C_MASTERMODE_Init(I2C_SpeedMode_TypeDef I2C_Speed) //IIC的初始化函数 { I2C_Init(I2C_Speed, I2C1_SLAVE_ADDRESS7, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, CLK_GetClockFreq()/1000000); I2C_Cmd(ENABLE); } <4>void I2C_EERROM_WriteOnePage(u8* pBuffer, u8 WriteAddr, u8 NumByteToWrite) //IIC写的函数 { /* 等待空闲 */ while(I2C_GetFlagStatus(I2C_FLAG_BUSBUSY)); //什么都没干,这一句就卡住了 /* 发起始位 */ I2C_GenerateSTART(ENABLE); /* 测试EV5 ,检测从器件返回一个应答信号*/ while(!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT)); /* 设置I2C从器件地址,I2C主设备为写模式*/ I2C_Send7bitAddress(WriteAddr, I2C_DIRECtiON_TX); //I2C_Send7bitAddress(EEPROM_ADDRESS, I2C_DIRECTION_TX); /* 测试EV6 ,检测从器件返回一个应答信号*/ while(!I2C_CheckEvent(I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)); //I2C_SendData((u8)(WriteAddr)); /* 测试EV8 ,检测从器件返回一个应答信号*/ while (!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING)); /* 不断往从设备写数据*/ while(NumByteToWrite--) { I2C_SendData(*pBuffer); /*指针指向下一个地址*/ pBuffer++; /* 测试EV6 ,检测从器件返回一个应答信号*/ while (!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_AcknowledgeConfig(I2C_ACK_CURR); } /* 发结束位*/ I2C_GenerateSTOP(ENABLE); } <5>FlagStatus I2C_GetFlagStatus(I2C_Flag_TypeDef I2C_Flag) //总线忙的函数,就是卡在这 { uint8_t tempreg = 0; uint8_t regindex = 0; FlagStatus bitstatus = RESET; /* Check the parameters */ assert_param(IS_I2C_FLAG_OK(I2C_Flag)); /* Read flag register index */ regindex = (uint8_t)((uint16_t)I2C_Flag >> 8); /* Check SRx index */ switch (regindex) { /* Returns whether the status register to check is SR1 */ case 0x01: tempreg = (uint8_t)I2C->SR1; break; /* Returns whether the status register to check is SR2 */ case 0x02: tempreg = (uint8_t)I2C->SR2; break; /* Returns whether the status register to check is SR3 */ case 0x03: tempreg = (uint8_t)I2C->SR3; break; default: break; } /* Check the status of the specified I2C flag */ if ((tempreg (uint8_t)I2C_Flag ) != 0) { /* Flag is set */ bitstatus = SET; //只能跑到这了, } else { /* Flag is reset */ bitstatus = RESET; //一直到不了这个,iic一直忙 } /* Return the flag status */ return bitstatus; } |
1个回答
I2C总线一直忙的原因可能有以下几点:
1. 总线冲突:在I2C总线上可能存在多个设备,如果它们同时尝试通信,可能会导致总线忙。确保其他设备没有在相同时间进行通信。 2. 硬件问题:检查I2C总线连接是否正确,以及是否有短路或断路的情况。 3. 软件问题:检查I2C初始化和通信代码是否正确。以下是一些建议: a. 确保I2C初始化函数(如I2C_MASTERMODE_Init)正确设置I2C速率、时钟等参数。 b. 在初始化函数中,检查是否正确设置了I2C从设备的地址。 c. 在写入数据之前,确保I2C总线处于空闲状态。可以使用I2C_IsBusBusy()函数检查。 d. 在写入数据时,确保使用正确的I2C通信协议,如I2C_Write()或I2C_MasterWrite()。 4. 从设备问题:检查从设备(如TAS5756)是否正常工作,以及其地址和通信协议是否与主设备匹配。 5. 电源问题:确保I2C总线上的所有设备都有足够的电源供应。 针对您提供的代码片段,我建议您: 1. 检查I2C_MASTERMODE_Init函数中的参数设置,确保它们正确无误。 2. 在INIT_TAS5756函数中,添加I2C_IsBusBusy()检查,确保总线空闲后再进行通信。 3. 如果可能,请提供更完整的代码,以便更准确地诊断问题。 4. 如果问题仍然存在,尝试使用其他I2C通信库或示例代码,以排除库本身的问题。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1892浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2165浏览 3评论
/9
GMT+8, 2025-12-1 21:33 , Processed in 0.414223 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1060
